Thinking about stalls
Old March 13th 08, 08:33 PM posted to rec.aviation.piloting
Jim Logajan
Default Thinking about stalls
WingFlaps wrote:
On Mar 14, 9:11*am, Brian wrote:
As for your question above, given that the airplanes are ascending or
decending at constant rates then the lift is equal to the wieght of
the airplane in both cases. If the aircraft are the same wieght then
the lift generated will be the same.
That is not correct.
Hmmm. Brian's statement appears essentially correct - and you are correct
too. The "gotcha" is that the vertical component of the lift force exceeds
the weight only during the transition from level flight to constant
ascending flight. And the lift force is less than the weight during the
transition from level flight to constant descending flight.
But once the vertical speed becomes constant (whether up or down) the
vertical component of lift has to equal the downward force of gravity. If
it didn't, then the aircraft would begin _accelerating_ up or down,
depending on the difference.
Old March 13th 08, 08:37 PM posted to rec.aviation.piloting
WingFlaps
Nope, if the airspeed is constant, the lift from the two wings is not
the same. This is thought provoking discussion I was hoping to start!
Can you see why lift does not equal weight in both cases?
Cheers
Old March 13th 08, 08:59 PM posted to rec.aviation.piloting
Jim Logajan
or decending at constant rates then the lift is equal to the
wieght of the airplane in both cases. If the aircraft are the same
wieght then the lift generated will be the same.
correct too. The "gotcha" is that the vertical component of the lift
force exceeds
the transition from level flight to constant descending flight.
gravity. If it didn't, then the aircraft would begin _accelerating_
up or down, depending on the difference.
I don't wish to be confrontational since you are looking for thought
provoking discussion, but I am pretty sure there is a fair amount of
imprecision, and therefore ambiguity, in your statements. This tends to
make it difficult to get very far in these discussions.
Would it help any if I presented the 2-D equations of force involved?
And perhaps you could do the same?
Old March 14th 08, 12:49 AM posted to rec.aviation.piloting
WingFlaps
force exceeds
And perhaps you could do the same?- Hide quoted text -
Sure here you go:
D=drag
L=lift
W=weight
T=thrust
alpha=angle of thrust
For no acceleration in any plane:
W=Tsin(alpha) + L
D=Tcos(alpha)
What you and many other texts have missed is that the thrust angle
changes...
What this means is that when you make a plane climb at constant speed
you are deliberately reducing lift from from the wing and supplanting
it with engine thrust! To extend this idea further, it is not the
climb per se that may be the problem but a decaying airspeed... The
above equations can be extended to the AOA and airspeed but the
conclusion remains the same.
Now, what about that tricky updraft? Is this thought provoking :-)
Cheers
Old March 14th 08, 12:00 AM posted to rec.aviation.piloting
Common misconception: that a climbing wing is generating more
lift than a descending wing. If the flight paths are both straight
lines, whether climbing or descending, the lift is the same in both
cases. As Jim said, only a change in the direction of flight will
change the lift/weight ratio. A G-meter (such as in our Citabrias)
will prove it.
If the airspeeds are the same and the flight paths are both
straight, the AOAs are both the same, too. But change the speeds while
leaving the flight paths alone, and the AOA will change. It's why the
airplane has a nose-high attitude in level slow flight as opposed to a
lower nose attitude in level cruise.
Dan
Old March 14th 08, 12:50 AM posted to rec.aviation.piloting
WingFlaps
* * * Common misconception: that a climbing wing is generating more
lines, whether *climbing or descending, the lift is the same in both
will prove it.
* * * If the airspeeds are the same and the flight paths are both
Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb.
Cheers
Old March 14th 08, 01:46 AM posted to rec.aviation.piloting
Dan[_10_]
will prove it.
Cheers
The trust vector is added to the lift vector in a climb, as the drag
is added to weight.
Dan Mc
Old March 14th 08, 01:57 AM posted to rec.aviation.piloting
WingFlaps
will prove it.
Cheers
is added to weight.
Are you saying that wing lift does not change with attitude in a non-
accelerating frame?
Cheers
Old March 14th 08, 11:08 AM posted to rec.aviation.piloting
Dan[_10_]
will prove it.
Cheers
is added to weight.
accelerating frame?
Cheers
Of course it does.
However -- In a climb thrust acts contrary to drag some component of
weight (depending on the angle of climb). Thus the angle of attack is
not *necessarily* equal to the angle of climb.
Dan Mc
Stalls?? Ol Shy & Bashful Piloting 155 February 22nd 08 03:24 PM
why my plane stalls Grandss Piloting 22 August 14th 05 07:48 AM
Practice stalls on your own? [email protected] Piloting 34 May 30th 05 05:23 PM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
