On Mar 14, 9:27 am, WingFlaps wrote:
On Mar 15, 12:08 am, Dan wrote: On Mar 13, 9:57 pm, WingFlaps wrote: On Mar 14, 2:46 pm, Dan wrote: On Mar 13, 8:50 pm, WingFlaps wrote: On Mar 14, 1:00 pm, wrote: On Mar 13, 1:37 pm, WingFlaps wrote: Nope, if the airspeed is constant, the lift from the two wings is not the same. This is thought provoking discussion I was hoping to start! Can you see why lift does not equal weight in both cases? Common misconception: that a climbing wing is generating more lift than a descending wing. If the flight paths are both straight lines, whether climbing or descending, the lift is the same in both cases. As Jim said, only a change in the direction of flight will change the lift/weight ratio. A G-meter (such as in our Citabrias) will prove it. If the airspeeds are the same and the flight paths are both straight, the AOAs are both the same, too. But change the speeds while leaving the flight paths alone, and the AOA will change. It's why the airplane has a nose-high attitude in level slow flight as opposed to a lower nose attitude in level cruise. Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb. Cheers The trust vector is added to the lift vector in a climb, as the drag is added to weight. Are you saying that wing lift does not change with attitude in a non- accelerating frame? Cheers Of course it does. However -- In a climb thrust acts contrary to drag some component of weight (depending on the angle of climb). Thus the angle of attack is not *necessarily* equal to the angle of climb. I'm sorry but I'm having trouble understanding where you are coming from. In my equations above I wrote that D=Tcos(alpha) and this is based on the idea that W,D and L are 3 orthogonal forces. Of course you can rewrite them non orthogonally if you please but my expression makes good sense (to me anyway). This is why: Imagine a jet in a steady vertical climb (alpha=90 degrees). My equation says D=0 so how can that be? The answer is that this simplified (wing + engine) model is really only considering induced drag and that the thrust line is close to 0 AOA (not bad approximations IMHO). For induced drag to be zero, wing LIFT _must_ be zero and so we see that Weight =Tsin(90) + L - W=T -exactly as it should be for a vertical climb! The pilot has reduced AOA to zero, the wing produces NO lift and the plane climbs vertically. Again, I say L should be dropped to zero for a true steady vertical climb and L=W only in straight and level flight or if the plane is gliding (T=0). In all steady climbs LW and all descents LW. I was a bit surprised when I realized that to be in a steady climb the pilot must be operating the plane in a condition where wing lift and AOA are actually lower than in straight and level -all thanks to a component of thrust adding to lift !!! Although the effect may not be large for low power planes (TW) , if what I'm saying makes sense, one may see some advantages in this approach -e.g. why increasing power leads to a nice steady climb or cutting power causes the nose to drop and a descent to begin... Cheers Consider -- if you are straight and level at 150 knots with a 3 degree AOA and you increase the angle of attack to 8 degrees, with no change in power, what happens? |
On Mar 15, 10:32*am, Dan wrote:
On Mar 14, 9:27 am, WingFlaps wrote: On Mar 15, 12:08 am, Dan wrote: On Mar 13, 9:57 pm, WingFlaps wrote: On Mar 14, 2:46 pm, Dan wrote: On Mar 13, 8:50 pm, WingFlaps wrote: On Mar 14, 1:00 pm, wrote: On Mar 13, 1:37 pm, WingFlaps wrote: Nope, if the airspeed is constant, the lift from the two wings is not the same. This is thought provoking discussion I was hoping to start! Can you see why lift does not equal weight in both cases? * * * Common misconception: that a climbing wing is generating more lift than a descending wing. If the flight paths are both straight lines, whether *climbing or descending, the lift is the same in both cases. As Jim said, only a change in the direction of flight will change the lift/weight ratio. A G-meter (such as in our Citabrias) will prove it. * * * If the airspeeds are the same and the flight paths are both straight, the AOAs are both the same, too. But change the speeds while leaving the flight paths alone, and the AOA will change. It's why the airplane has a nose-high attitude in level slow flight as opposed to a lower nose attitude in level cruise. Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb. Cheers The trust vector is added to the lift vector in a climb, as the drag is added to weight. Are you saying that wing lift does not change with attitude in a non- accelerating frame? Cheers Of course it does. However -- In a climb thrust acts contrary to drag some component of weight (depending on the angle of climb). Thus the angle of attack is not *necessarily* equal to the angle of climb. I'm sorry but I'm having trouble understanding where you are coming from. In my equations above I wrote that D=Tcos(alpha) and this is based on the idea that W,D and L are 3 orthogonal forces. Of course you can rewrite them non orthogonally if you please but my expression makes good sense (to me anyway). This is why: Imagine a jet in a steady vertical climb (alpha=90 degrees). My equation says D=0 so how can that be? The answer is that this simplified (wing + engine) model is really only considering induced drag and that the thrust line is close to 0 AOA (not bad approximations IMHO). For induced drag to be zero, wing LIFT _must_ be zero and so we see that Weight =Tsin(90) + L - *W=T -exactly as it should be for a vertical climb! The pilot has reduced AOA to zero, the wing produces NO lift and the plane climbs vertically. Again, I say L should be dropped to zero for a true steady vertical climb and L=W only in straight and level flight or if the plane is gliding (T=0). In all steady climbs LW and all descents LW. I was a bit surprised when I realized that *to be in a steady climb the pilot must be operating the plane in a condition where wing lift and AOA *are actually lower than in straight and level -all thanks to a component of thrust adding to lift !!! Although the effect may not be large for low power planes (TW) , if what I'm saying makes sense, one may see some advantages in this approach -e.g. why increasing power leads to a nice steady climb or cutting power causes the nose to drop and a descent to begin... Cheers Consider -- if you are straight and level at 150 knots with a 3 degree AOA and you increase the angle of attack to 8 degrees, with no change in power, what happens?- Hide quoted text - You initially increase lift so the plane starts to acclerate in the vertical plane and the increased drag starts to slow you down -so your airspeed also comes back. As the airspeed deacys lift starts to drop (with V^2) and, if you have enough power on to establish a steady climb at 8 degrees AOA, you achieve a new state where you have a lower airspeed and the vertical component of lift from the wing is slightly less than before you started the climb -the lost lift is replaced by the engine thrust component. If you don't get it, keep thinking about the steady vertical climb -what is the force that opposes weight? It's thrust pure and simple right? That force is a sine function of angle... OK? Cheers |
On Mar 14, 5:59 pm, WingFlaps wrote:
On Mar 15, 10:32 am, Dan wrote: On Mar 14, 9:27 am, WingFlaps wrote: On Mar 15, 12:08 am, Dan wrote: On Mar 13, 9:57 pm, WingFlaps wrote: On Mar 14, 2:46 pm, Dan wrote: On Mar 13, 8:50 pm, WingFlaps wrote: On Mar 14, 1:00 pm, wrote: On Mar 13, 1:37 pm, WingFlaps wrote: Nope, if the airspeed is constant, the lift from the two wings is not the same. This is thought provoking discussion I was hoping to start! Can you see why lift does not equal weight in both cases? Common misconception: that a climbing wing is generating more lift than a descending wing. If the flight paths are both straight lines, whether climbing or descending, the lift is the same in both cases. As Jim said, only a change in the direction of flight will change the lift/weight ratio. A G-meter (such as in our Citabrias) will prove it. If the airspeeds are the same and the flight paths are both straight, the AOAs are both the same, too. But change the speeds while leaving the flight paths alone, and the AOA will change. It's why the airplane has a nose-high attitude in level slow flight as opposed to a lower nose attitude in level cruise. Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb. Cheers The trust vector is added to the lift vector in a climb, as the drag is added to weight. Are you saying that wing lift does not change with attitude in a non- accelerating frame? Cheers Of course it does. However -- In a climb thrust acts contrary to drag some component of weight (depending on the angle of climb). Thus the angle of attack is not *necessarily* equal to the angle of climb. I'm sorry but I'm having trouble understanding where you are coming from. In my equations above I wrote that D=Tcos(alpha) and this is based on the idea that W,D and L are 3 orthogonal forces. Of course you can rewrite them non orthogonally if you please but my expression makes good sense (to me anyway). This is why: Imagine a jet in a steady vertical climb (alpha=90 degrees). My equation says D=0 so how can that be? The answer is that this simplified (wing + engine) model is really only considering induced drag and that the thrust line is close to 0 AOA (not bad approximations IMHO). For induced drag to be zero, wing LIFT _must_ be zero and so we see that Weight =Tsin(90) + L - W=T -exactly as it should be for a vertical climb! The pilot has reduced AOA to zero, the wing produces NO lift and the plane climbs vertically. Again, I say L should be dropped to zero for a true steady vertical climb and L=W only in straight and level flight or if the plane is gliding (T=0). In all steady climbs LW and all descents LW. I was a bit surprised when I realized that to be in a steady climb the pilot must be operating the plane in a condition where wing lift and AOA are actually lower than in straight and level -all thanks to a component of thrust adding to lift !!! Although the effect may not be large for low power planes (TW) , if what I'm saying makes sense, one may see some advantages in this approach -e.g. why increasing power leads to a nice steady climb or cutting power causes the nose to drop and a descent to begin... Cheers Consider -- if you are straight and level at 150 knots with a 3 degree AOA and you increase the angle of attack to 8 degrees, with no change in power, what happens?- Hide quoted text - You initially increase lift so the plane starts to acclerate in the vertical plane and the increased drag starts to slow you down -so your airspeed also comes back. As the airspeed deacys lift starts to drop (with V^2) and, if you have enough power on to establish a steady climb at 8 degrees AOA, you achieve a new state where you have a lower airspeed and the vertical component of lift from the wing is slightly less than before you started the climb -the lost lift is replaced by the engine thrust component. If you don't get it, keep thinking about the steady vertical climb -what is the force that opposes weight? It's thrust pure and simple right? That force is a sine function of angle... OK? Cheers I know the answer..wasn't sure if you were thinking beyond the slide rule. |
On Mar 15, 11:08*am, Dan wrote:
On Mar 14, 5:59 pm, WingFlaps wrote: On Mar 15, 10:32 am, Dan wrote: On Mar 14, 9:27 am, WingFlaps wrote: On Mar 15, 12:08 am, Dan wrote: On Mar 13, 9:57 pm, WingFlaps wrote: On Mar 14, 2:46 pm, Dan wrote: On Mar 13, 8:50 pm, WingFlaps wrote: On Mar 14, 1:00 pm, wrote: On Mar 13, 1:37 pm, WingFlaps wrote: Nope, if the airspeed is constant, the lift from the two wings is not the same. This is thought provoking discussion I was hoping to start! Can you see why lift does not equal weight in both cases? * * * Common misconception: that a climbing wing is generating more lift than a descending wing. If the flight paths are both straight lines, whether *climbing or descending, the lift is the same in both cases. As Jim said, only a change in the direction of flight will change the lift/weight ratio. A G-meter (such as in our Citabrias) will prove it. * * * If the airspeeds are the same and the flight paths are both straight, the AOAs are both the same, too. But change the speeds while leaving the flight paths alone, and the AOA will change. It's why the airplane has a nose-high attitude in level slow flight as opposed to a lower nose attitude in level cruise. Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb. Cheers The trust vector is added to the lift vector in a climb, as the drag is added to weight. Are you saying that wing lift does not change with attitude in a non- accelerating frame? Cheers Of course it does. However -- In a climb thrust acts contrary to drag some component of weight (depending on the angle of climb). Thus the angle of attack is not *necessarily* equal to the angle of climb. I'm sorry but I'm having trouble understanding where you are coming from. In my equations above I wrote that D=Tcos(alpha) and this is based on the idea that W,D and L are 3 orthogonal forces. Of course you can rewrite them non orthogonally if you please but my expression makes good sense (to me anyway). This is why: Imagine a jet in a steady vertical climb (alpha=90 degrees). My equation says D=0 so how can that be? The answer is that this simplified (wing + engine) model is really only considering induced drag and that the thrust line is close to 0 AOA (not bad approximations IMHO). For induced drag to be zero, wing LIFT _must_ be zero and so we see that Weight =Tsin(90) + L - *W=T -exactly as it should be for a vertical climb! The pilot has reduced AOA to zero, the wing produces NO lift and the plane climbs vertically. Again, I say L should be dropped to zero for a true steady vertical climb and L=W only in straight and level flight or if the plane is gliding (T=0). In all steady climbs LW and all descents LW. I was a bit surprised when I realized that *to be in a steady climb the pilot must be operating the plane in a condition where wing lift and AOA *are actually lower than in straight and level -all thanks to a component of thrust adding to lift !!! Although the effect may not be large for low power planes (TW) , if what I'm saying makes sense, one may see some advantages in this approach -e.g. why increasing power leads to a nice steady climb or cutting power causes the nose to drop and a descent to begin... Cheers Consider -- if you are straight and level at 150 knots with a 3 degree AOA and you increase the angle of attack to 8 degrees, with no change in power, what happens?- Hide quoted text - You initially increase lift so the plane starts to acclerate in the vertical plane and the increased drag starts to slow you down -so your airspeed also comes back. As the airspeed deacys lift starts to drop (with V^2) and, if you have enough power on to establish a steady climb at 8 degrees AOA, you achieve a new state where you have a lower airspeed and the vertical component of lift from the wing is slightly less than before you started the climb -the lost lift is replaced by the engine thrust component. If you don't get it, keep thinking about the steady vertical climb -what is the force that opposes weight? It's thrust pure and simple right? That force is a sine function of angle... OK? Cheers I know the answer..wasn't sure if you were thinking beyond the slide rule.- Hide quoted text - You used slide rules too? Good on ya! So, you agree that vertical lift is lower in a steady climb -if so is the wing closer to a stall when climbing or descending at the same speed -is this as thought provoking as I hoped? Cheers |
On Mar 14, 6:42 pm, WingFlaps wrote:
On Mar 15, 11:08 am, Dan wrote: On Mar 14, 5:59 pm, WingFlaps wrote: On Mar 15, 10:32 am, Dan wrote: On Mar 14, 9:27 am, WingFlaps wrote: On Mar 15, 12:08 am, Dan wrote: On Mar 13, 9:57 pm, WingFlaps wrote: On Mar 14, 2:46 pm, Dan wrote: On Mar 13, 8:50 pm, WingFlaps wrote: On Mar 14, 1:00 pm, wrote: On Mar 13, 1:37 pm, WingFlaps wrote: Nope, if the airspeed is constant, the lift from the two wings is not the same. This is thought provoking discussion I was hoping to start! Can you see why lift does not equal weight in both cases? Common misconception: that a climbing wing is generating more lift than a descending wing. If the flight paths are both straight lines, whether climbing or descending, the lift is the same in both cases. As Jim said, only a change in the direction of flight will change the lift/weight ratio. A G-meter (such as in our Citabrias) will prove it. If the airspeeds are the same and the flight paths are both straight, the AOAs are both the same, too. But change the speeds while leaving the flight paths alone, and the AOA will change. It's why the airplane has a nose-high attitude in level slow flight as opposed to a lower nose attitude in level cruise. Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb. Cheers The trust vector is added to the lift vector in a climb, as the drag is added to weight. Are you saying that wing lift does not change with attitude in a non- accelerating frame? Cheers Of course it does. However -- In a climb thrust acts contrary to drag some component of weight (depending on the angle of climb). Thus the angle of attack is not *necessarily* equal to the angle of climb. I'm sorry but I'm having trouble understanding where you are coming from. In my equations above I wrote that D=Tcos(alpha) and this is based on the idea that W,D and L are 3 orthogonal forces. Of course you can rewrite them non orthogonally if you please but my expression makes good sense (to me anyway). This is why: Imagine a jet in a steady vertical climb (alpha=90 degrees). My equation says D=0 so how can that be? The answer is that this simplified (wing + engine) model is really only considering induced drag and that the thrust line is close to 0 AOA (not bad approximations IMHO). For induced drag to be zero, wing LIFT _must_ be zero and so we see that Weight =Tsin(90) + L - W=T -exactly as it should be for a vertical climb! The pilot has reduced AOA to zero, the wing produces NO lift and the plane climbs vertically. Again, I say L should be dropped to zero for a true steady vertical climb and L=W only in straight and level flight or if the plane is gliding (T=0). In all steady climbs LW and all descents LW. I was a bit surprised when I realized that to be in a steady climb the pilot must be operating the plane in a condition where wing lift and AOA are actually lower than in straight and level -all thanks to a component of thrust adding to lift !!! Although the effect may not be large for low power planes (TW) , if what I'm saying makes sense, one may see some advantages in this approach -e.g. why increasing power leads to a nice steady climb or cutting power causes the nose to drop and a descent to begin... Cheers Consider -- if you are straight and level at 150 knots with a 3 degree AOA and you increase the angle of attack to 8 degrees, with no change in power, what happens?- Hide quoted text - You initially increase lift so the plane starts to acclerate in the vertical plane and the increased drag starts to slow you down -so your airspeed also comes back. As the airspeed deacys lift starts to drop (with V^2) and, if you have enough power on to establish a steady climb at 8 degrees AOA, you achieve a new state where you have a lower airspeed and the vertical component of lift from the wing is slightly less than before you started the climb -the lost lift is replaced by the engine thrust component. If you don't get it, keep thinking about the steady vertical climb -what is the force that opposes weight? It's thrust pure and simple right? That force is a sine function of angle... OK? Cheers I know the answer..wasn't sure if you were thinking beyond the slide rule.- Hide quoted text - You used slide rules too? Good on ya! So, you agree that vertical lift is lower in a steady climb -if so is the wing closer to a stall when climbing or descending at the same speed -is this as thought provoking as I hoped? Cheers Slide rules -- oh so long ago! Though I can still spin a whiz wheel... Vertical lift may be equal to lift in a descent, or in straight and level. N'est pas? Dan Mcc |
On Mar 15, 1:31*pm, Dan wrote:
On Mar 14, 6:42 pm, WingFlaps wrote: On Mar 15, 11:08 am, Dan wrote: On Mar 14, 5:59 pm, WingFlaps wrote: On Mar 15, 10:32 am, Dan wrote: On Mar 14, 9:27 am, WingFlaps wrote: On Mar 15, 12:08 am, Dan wrote: On Mar 13, 9:57 pm, WingFlaps wrote: On Mar 14, 2:46 pm, Dan wrote: On Mar 13, 8:50 pm, WingFlaps wrote: On Mar 14, 1:00 pm, wrote: On Mar 13, 1:37 pm, WingFlaps wrote: Nope, if the airspeed is constant, the lift from the two wings is not the same. This is thought provoking discussion I was hoping to start! Can you see why lift does not equal weight in both cases? * * * Common misconception: that a climbing wing is generating more lift than a descending wing. If the flight paths are both straight lines, whether *climbing or descending, the lift is the same in both cases. As Jim said, only a change in the direction of flight will change the lift/weight ratio. A G-meter (such as in our Citabrias) will prove it. * * * If the airspeeds are the same and the flight paths are both straight, the AOAs are both the same, too. But change the speeds while leaving the flight paths alone, and the AOA will change. It's why the airplane has a nose-high attitude in level slow flight as opposed to a lower nose attitude in level cruise. Hi Dan see my rely to Jim. In fact, lift is reduced in a steady climb. Cheers The trust vector is added to the lift vector in a climb, as the drag is added to weight. Are you saying that wing lift does not change with attitude in a non- accelerating frame? Cheers Of course it does. However -- In a climb thrust acts contrary to drag some component of weight (depending on the angle of climb). Thus the angle of attack is not *necessarily* equal to the angle of climb. I'm sorry but I'm having trouble understanding where you are coming from. In my equations above I wrote that D=Tcos(alpha) and this is based on the idea that W,D and L are 3 orthogonal forces. Of course you can rewrite them non orthogonally if you please but my expression makes good sense (to me anyway). This is why: Imagine a jet in a steady vertical climb (alpha=90 degrees). My equation says D=0 so how can that be? The answer is that this simplified (wing + engine) model is really only considering induced drag and that the thrust line is close to 0 AOA (not bad approximations IMHO). For induced drag to be zero, wing LIFT _must_ be zero and so we see that Weight =Tsin(90) + L - *W=T -exactly as it should be for a vertical climb! The pilot has reduced AOA to zero, the wing produces NO lift and the plane climbs vertically. Again, I say L should be dropped to zero for a true steady vertical climb and L=W only in straight and level flight or if the plane is gliding (T=0). In all steady climbs LW and all descents LW. I was a bit surprised when I realized that *to be in a steady climb the pilot must be operating the plane in a condition where wing lift and AOA *are actually lower than in straight and level -all thanks to a component of thrust adding to lift !!! Although the effect may not be large for low power planes (TW) , if what I'm saying makes sense, one may see some advantages in this approach -e.g. why increasing power leads to a nice steady climb or cutting power causes the nose to drop and a descent to begin... Cheers Consider -- if you are straight and level at 150 knots with a 3 degree AOA and you increase the angle of attack to 8 degrees, with no change in power, what happens?- Hide quoted text - You initially increase lift so the plane starts to acclerate in the vertical plane and the increased drag starts to slow you down -so your airspeed also comes back. As the airspeed deacys lift starts to drop (with V^2) and, if you have enough power on to establish a steady climb at 8 degrees AOA, you achieve a new state where you have a lower airspeed and the vertical component of lift from the wing is slightly less than before you started the climb -the lost lift is replaced by the engine thrust component. If you don't get it, keep thinking about the steady vertical climb -what is the force that opposes weight? It's thrust pure and simple right? That force is a sine function of angle... OK? Cheers I know the answer..wasn't sure if you were thinking beyond the slide rule.- Hide quoted text - You used slide rules too? Good on ya! So, you agree that vertical lift is lower in a steady climb -if so is the wing closer to a stall when climbing or descending at the same speed -is this as thought provoking as I hoped? Cheers Slide rules -- oh so long ago! Though I can still spin a whiz wheel... Vertical lift may be equal to lift in a descent, or in straight and level. N'est pas? Yes, but not equal to weight unless thrust is purely horizontal. Not sure about the French tho' is that slang for n'est-ce pas? Cheers |
Stalls?? | Ol Shy & Bashful | Piloting | 155 | February 22nd 08 03:24 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
