WrongO againO. The "coffin corner" is an altitude (point on a chart where
the stall speed and Mach come together) with a max power setting. If you go faster, you get mach buffet. If you go to slow, you stall. If you reduce power setting, you stall. If you nose over to recover, you mach buffet. With your example I can see why you're confused. -- BobF. "Dudley Henriques" wrote in message ... Bob F. wrote: "Generally"?, "most certainly"?, I'd say "in one case". The other way around is correct. That is "if you are in the area of reverse command, you are dragging it in". Notwithstanding that the phrase includes the notion of approaching and/or landing. The coffin corner is also not on the back side of the power curve. It is at the asymptote and you can never get into the back side. That's why it a corner. It is certainly not referred to as "dragging it in" there. Been there with the best test pilots in the world in a 747-400 while I was testing the 400. No one has ever referred to is as that. You're kidding right? I believe you are repeating wht I have said. I said that "dragging it in" generally refers to flying the approach in the area of reverse command or if you will behind the power curve. This is absolutely correct. Coffin corner is the area behind the curve where sink rate can't be stopped with power but requires reduction in angle of attack. For a perfect example of an aircraft in coffin corner, see the Edwards AFB accident involving a young AF pilot who got his F100 so deep into coffin corner behind the curve he couldn't recover the airplane; not enough air under him to reduce the angle of attack. He applied full burner but couldn't fly it out on power alone. Reduction of angle of attack was what he needed and he didn't have the room. THIS is the definition of coffin corner and it most certainly IS in the area of reverse command. -- Dudley Henriques |
Bob F. wrote:
WrongO againO. The "coffin corner" is an altitude (point on a chart where the stall speed and Mach come together) with a max power setting. If you go faster, you get mach buffet. If you go to slow, you stall. If you reduce power setting, you stall. If you nose over to recover, you mach buffet. With your example I can see why you're confused. I'm not confused and neither are you. :-)) The coffin corner YOU are describing can be found in the flight envelope of the U2 (as well as other airplanes) at high altitude cruise. The coffin corner I'm describing can be found on a dragged in approach AT LOW ALTITUDE with the aircraft behind where the flight test community defines the area of reverse command; that being below the airspeed for maximum endurance. The corner is reached as you get the airplane low enough on the approach where the sink rate can't be stopped with power as maximum is already applied. The ONLY way out of the corner is to reduce angle of attack. If the proximity between the aircraft and the ground won't allow that angle of attack reduction, you hve what we call the "coffin corner". -- Dudley Henriques |
The term "coffin corner" has the term "critical mach" in the formula. I've
never been at critical mach at such a low altitude. A little to fast for an approach. So now you're telling me that the term "coffin corner" has been high jacked to mean something different. Wouldn't be the first time! -- BobF. "Dudley Henriques" wrote in message ... Bob F. wrote: WrongO againO. The "coffin corner" is an altitude (point on a chart where the stall speed and Mach come together) with a max power setting. If you go faster, you get mach buffet. If you go to slow, you stall. If you reduce power setting, you stall. If you nose over to recover, you mach buffet. With your example I can see why you're confused. I'm not confused and neither are you. :-)) The coffin corner YOU are describing can be found in the flight envelope of the U2 (as well as other airplanes) at high altitude cruise. The coffin corner I'm describing can be found on a dragged in approach AT LOW ALTITUDE with the aircraft behind where the flight test community defines the area of reverse command; that being below the airspeed for maximum endurance. The corner is reached as you get the airplane low enough on the approach where the sink rate can't be stopped with power as maximum is already applied. The ONLY way out of the corner is to reduce angle of attack. If the proximity between the aircraft and the ground won't allow that angle of attack reduction, you hve what we call the "coffin corner". -- Dudley Henriques |
Bob F. wrote:
The term "coffin corner" has the term "critical mach" in the formula. I've never been at critical mach at such a low altitude. A little to fast for an approach. So now you're telling me that the term "coffin corner" has been high jacked to mean something different. Wouldn't be the first time! Yes, that is exactly right. In the engineering sense I as well as you, have always heard he term used in the sense you are using it. In the world of high performance singles, especially in the figher community, terms are often "stolen" or used in conversation so often that they eventually become generic in the industry. The term "Coffin Corner" as relates to "dragging it in" has been a mainstay in our industry since the 50's. The F100 crash at Edwards in 56 solidified the term to posterity. A young pilot named Barty Brooks augured in when his nose wheel malfunctioned. He got so far behind the curve on approach he couldn't lower the nose to recover the sink. The subsequent crash has been used to demonstrate area of reverse command issues t both the Naval and Air Force Test Pilot Schools for as long as I can remember. Actually, the other use of the term as well had it's origins within the test community as do most terms like "coffin corner" :-) Both are correct. I'm sure Bertie will eventually pop in and remind us both of the blind men feeling the elephant. I agree with him actually.That one's becoming one of my favorite Usenet analogies :-)) -- Dudley Henriques |
![]() Well, the bit of the envelope you're talking about is the low end of the speed envelope fro every airplane. The coffin corner really only applies to high alt/high speed transonic airplanes. When you climb up above transition and reach th ealtitude where the airplane is mach limited the rules changed. I've attached a diagram of a typical flight envelope showing the constant indicated max/min speeds up to transition where they taper in. The point in dashded lines at the top is the point Bob was talking about where both happen at the same time. To maintain a margin a max altitude dictated by a G is determined. Going to fast or sow or pulling too much G at or near max will result in a buffet and loss of lift, just for starters. I've just reposted this because I've gotten some e-mail complaining that the attachment didn't come through. I'll repost that in alt.binaries.pictures.aviation Bertie |
Bertie the Bunyip wrote:
Well, the bit of the envelope you're talking about is the low end of the speed envelope fro every airplane. The coffin corner really only applies to high alt/high speed transonic airplanes. When you climb up above transition and reach th ealtitude where the airplane is mach limited the rules changed. I've attached a diagram of a typical flight envelope showing the constant indicated max/min speeds up to transition where they taper in. The point in dashded lines at the top is the point Bob was talking about where both happen at the same time. To maintain a margin a max altitude dictated by a G is determined. Going to fast or sow or pulling too much G at or near max will result in a buffet and loss of lift, just for starters. I've just reposted this because I've gotten some e-mail complaining that the attachment didn't come through. I'll repost that in alt.binaries.pictures.aviation Bertie If you read my post first mentioning "coffin corner", you will notice I used it as an adjective to describe a "condition" found t the extreme end of the back side of the power curve; this being the "condition" where low altitude and no more power available necessitate a reduction in angle of attack to stop a developing sink rate; a very dangerous situation on any approach. It should be obvious that I never meant to convey that the term "coffin corner" didn't refer to it's classic definition for high altitude critical mach vs stall condition. I will not get into a shouting match with Usenet advasiaries who wish to convey I have no idea what coffin corner is as defined in the aeronautical engineering sense. Good God, I've even heard coffin corner used to define the warnings block on an approach plate! -- Dudley Henriques |
"Bob F." wrote in
: WrongO againO. The "coffin corner" is an altitude (point on a chart where the stall speed and Mach come together) with a max power setting. If you go faster, you get mach buffet. If you go to slow, you stall. If you reduce power setting, you stall. If you nose over to recover, you mach buffet. With your example I can see why you're confused. Acctually, the low side buffet isn't strictly a stall. The proof of this is it happens at a much higher indicated and much lower alpha than a stall at low altitudes. The wing doe lose lift, so in the broadest definition of a a stall the wing stals, but what's actualy happening is that the increased angle of attack you neccesarily have as you reduce speed increases the speed of the air over the wing so that there are localised areas of supersonic flow with an accompanying buffet. So what coffin corner actually is is an onset of mach buffet caused by any combination of speed and alpha. Bertie |
That's exactly right Bertie. I never ran into anyone who knew that except
for a few engineers at Boeing. I'd love to meet you sometime. I was fortunate enough to be able to take all the aero engineering courses they offered. It was great. Most of the instructors were old 707 engineers. I had great respect for them. They had all kinds of rules of thumb that I never hear about. I have a note book full of them. I don't even see reference to them in the the my bible, the NAVWEPS. -- BobF. "Bertie the Bunyip" wrote in message ... "Bob F." wrote in : WrongO againO. The "coffin corner" is an altitude (point on a chart where the stall speed and Mach come together) with a max power setting. If you go faster, you get mach buffet. If you go to slow, you stall. If you reduce power setting, you stall. If you nose over to recover, you mach buffet. With your example I can see why you're confused. Acctually, the low side buffet isn't strictly a stall. The proof of this is it happens at a much higher indicated and much lower alpha than a stall at low altitudes. The wing doe lose lift, so in the broadest definition of a a stall the wing stals, but what's actualy happening is that the increased angle of attack you neccesarily have as you reduce speed increases the speed of the air over the wing so that there are localised areas of supersonic flow with an accompanying buffet. So what coffin corner actually is is an onset of mach buffet caused by any combination of speed and alpha. Bertie |
"Bob F." wrote in
: That's exactly right Bertie. I never ran into anyone who knew that except for a few engineers at Boeing. I'd love to meet you sometime. I was fortunate enough to be able to take all the aero engineering courses they offered. It was great. Most of the instructors were old 707 engineers. I had great respect for them. They had all kinds of rules of thumb that I never hear about. I have a note book full of them. I don't even see reference to them in the the my bible, the NAVWEPS. I got a mole at Boeing. A rocket scientist, in fact. Meganerd. We grew up together. This guy built a Piet in his basement starting at the age of 14. ( I helped) The things he found to do with Estes rockets and various explosives as a teen were numerous and exciting! Especially to the local cops. He's just left Boeing to work for some millionaire on a commercial space flight project. In texas I think. I can't understand why they don't teach this in a bit more detail, though. There are very few airline pilots who understand this nowadays. There's an OK-ish FAA circular on it, but causes and recoveries ae not gone into in any great detail. They seem to be happy to let the FMC look after it. BTW, ever get a yaw damper failure in the 707? I've doen them in the sim in the 727 and they were pretty exciting. I've been told the 707 was worse. Bertie |
Yes, you learn a lot about Dutch rolls real quick. ...and I did experience
a elevator hydraulic cylinder stall once in a 707. That was an experience. -- BobF. "Bertie the Bunyip" wrote in message ... "Bob F." wrote in : That's exactly right Bertie. I never ran into anyone who knew that except for a few engineers at Boeing. I'd love to meet you sometime. I was fortunate enough to be able to take all the aero engineering courses they offered. It was great. Most of the instructors were old 707 engineers. I had great respect for them. They had all kinds of rules of thumb that I never hear about. I have a note book full of them. I don't even see reference to them in the the my bible, the NAVWEPS. I got a mole at Boeing. A rocket scientist, in fact. Meganerd. We grew up together. This guy built a Piet in his basement starting at the age of 14. ( I helped) The things he found to do with Estes rockets and various explosives as a teen were numerous and exciting! Especially to the local cops. He's just left Boeing to work for some millionaire on a commercial space flight project. In texas I think. I can't understand why they don't teach this in a bit more detail, though. There are very few airline pilots who understand this nowadays. There's an OK-ish FAA circular on it, but causes and recoveries ae not gone into in any great detail. They seem to be happy to let the FMC look after it. BTW, ever get a yaw damper failure in the 707? I've doen them in the sim in the 727 and they were pretty exciting. I've been told the 707 was worse. Bertie |
Thinking about stalls | WingFlaps | Piloting | 43 | April 12th 08 09:35 PM |
Stalls?? | Ol Shy & Bashful | Piloting | 155 | February 22nd 08 03:24 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
