The term "coffin corner" has the term "critical mach" in the formula. I've
never been at critical mach at such a low altitude. A little to fast for an approach. So now you're telling me that the term "coffin corner" has been high jacked to mean something different. Wouldn't be the first time! -- BobF. "Dudley Henriques" wrote in message ... Bob F. wrote: WrongO againO. The "coffin corner" is an altitude (point on a chart where the stall speed and Mach come together) with a max power setting. If you go faster, you get mach buffet. If you go to slow, you stall. If you reduce power setting, you stall. If you nose over to recover, you mach buffet. With your example I can see why you're confused. I'm not confused and neither are you. :-)) The coffin corner YOU are describing can be found in the flight envelope of the U2 (as well as other airplanes) at high altitude cruise. The coffin corner I'm describing can be found on a dragged in approach AT LOW ALTITUDE with the aircraft behind where the flight test community defines the area of reverse command; that being below the airspeed for maximum endurance. The corner is reached as you get the airplane low enough on the approach where the sink rate can't be stopped with power as maximum is already applied. The ONLY way out of the corner is to reduce angle of attack. If the proximity between the aircraft and the ground won't allow that angle of attack reduction, you hve what we call the "coffin corner". -- Dudley Henriques |
Bob F. wrote:
The term "coffin corner" has the term "critical mach" in the formula. I've never been at critical mach at such a low altitude. A little to fast for an approach. So now you're telling me that the term "coffin corner" has been high jacked to mean something different. Wouldn't be the first time! Yes, that is exactly right. In the engineering sense I as well as you, have always heard he term used in the sense you are using it. In the world of high performance singles, especially in the figher community, terms are often "stolen" or used in conversation so often that they eventually become generic in the industry. The term "Coffin Corner" as relates to "dragging it in" has been a mainstay in our industry since the 50's. The F100 crash at Edwards in 56 solidified the term to posterity. A young pilot named Barty Brooks augured in when his nose wheel malfunctioned. He got so far behind the curve on approach he couldn't lower the nose to recover the sink. The subsequent crash has been used to demonstrate area of reverse command issues t both the Naval and Air Force Test Pilot Schools for as long as I can remember. Actually, the other use of the term as well had it's origins within the test community as do most terms like "coffin corner" :-) Both are correct. I'm sure Bertie will eventually pop in and remind us both of the blind men feeling the elephant. I agree with him actually.That one's becoming one of my favorite Usenet analogies :-)) -- Dudley Henriques |
Thinking about stalls | WingFlaps | Piloting | 43 | April 12th 08 09:35 PM |
Stalls?? | Ol Shy & Bashful | Piloting | 155 | February 22nd 08 03:24 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
