#11
On Mar 16, 1:47 pm, Andrew Sarangan wrote:
On Mar 16, 3:41 pm, wrote: On Mar 15, 10:57 pm, wrote: I think the more bottom rudder you give in a turn, the more the nose will appear to move lower against a given horizon. All the rudder does is pull the plane around an axis from ear-to-ear. The rudder is intended to control adverse yaw, not to turn the airplane. Banking the airplane turns it. Some airplanes, the "idiot- proof" ones, sometimes need no rudder at all in a turn. Dan Actually, I beg to differ. Banking rotates the airplane about its longitudinal axis. Yawing rotates about its vertical axis. Neither of these causes the airplane to change heading. It is the aerodynamic forces that streamlines the airplane with the relative wind is what makes it turn (ie weather vaning). For comparison, think of the space shuttle banking or yawing in orbit. This does not change its heading because there is no streamlining effect. http://www.av8n.com/how/htm/4forces.html#note64 Section 4.3 http://www.av8n.com/how/htm/yaw.html#sec-yaw-stability Section 8.2 The bank moves the airplane sideways. The fin, moved sideways, points the airplane in the new direction. The rudder controls adverse yaw, which tends to drag the nose away from the turn. Dan |
On Mar 16, 5:41*pm, wrote:
http://www.av8n.com/how/htm/4forces.html#note64* * *Section 4.3 http://www.av8n.com/how/htm/yaw.html#sec-yaw-stability* Section 8.2 * * *The bank moves the airplane sideways. The fin, moved sideways, points the airplane in the new direction. The rudder controls adverse yaw, which tends to drag the nose away from the turn. Overcoming adverse yaw is only one of the reasons your reference gives for using the rudder in a coordinated turn. The other is "You use the rudder to change your heading (i.e. to overcome yaw-wise inertia, i.e. to provide yaw-wise acceleration)" (section 8.8). As the reference you cite explains, even apart from adverse yaw, relying on weathervaning to realign the plane would not result in as smooth a turn as properly coordinated use of the rudder. |
On Mar 15, 4:38*pm, William Hung wrote:
I have heard definitions for both, but I'm still confused. *Anyone care to elaborate? Wil A lot of good inputs, I'm going to need some time... Thanks all, Wil |
On Mar 16, 2:42*pm, wrote:
On Mar 15, 9:23 pm, wrote: Except when the control system is misrigged like a plane I flew recently. In order to get a coordinated turn, I had to give "top" rudder in a turn. That's wrong. * * Is that the one in which I suggested a broken rudder bar spring? Anything come of that? * * * Dan Yeah, I think so. Another person also emailed me private and said the same. The chief pilot and other instructors at the FBO got an email from me. Never heard anything back. Maybe they checked it out and decided I was wrong; or maybe I found a problem and they don't want to comment on it in a traceable way. I think I'll switch to their 172, rather than fly that 150. On the other hand maybe they have fixed it and I just don't know about it. |
points the airplane in the new direction. The rudder controls adverse yaw, which tends to drag the nose away from the turn. * * * Dan- Hide quoted text - - Show quoted text - I'd say that the rudder controls yaw, period. You can change heading using the rudder. I've done it (hah, especially a lot as a student trying to practice power on stalls), and it stands to reason considering the force vectors acting on a fuselage that is yawed into the relative wind. I've never tried to do what Bertie describes though. But I will next time I'm up. Nevertheless I follow the school that says the elevator is really the main turn control (Langewiesche, Stowell, and many others). |
Let's see what is it that you are experiencing. Before flight with the
plane sitting on level ground (at least as much as you can tell). Is the ball centered? As you taxi and make small heading changes, does the ball move freely in the raceway? In the practice area. Slow to 60 Kts, pitch up and add full power, maintain 60 kts. You should immediately notice the ball go right and you will need right rudder to center the ball. Keep the plane from changing heading. Be sure to keep the wings level. Now notice as you enter into a left turn, you DO NOT need to step on the left rudder (you only maintain enough left rudder pressure to keep slack out of the cable system) until you have released all the pressure from the right rudder, then as you increase bank further you can add left rudder. In fact you MIGHT not need left rudder at all. Keep the ball centered all the time. Is that what you are seeing? Now, In a glide situation, things should be more symmetrical. Lower the nose, reduce power to say 1200 rpm, maintain 60 kts. As you bank right and left the rudder pressures required to keep the ball centered each way should be about the same. Do you see this effect? Please report if you know, or try it the next time you go out. -- Regards, BobF. wrote in message ... On Mar 16, 2:42 pm, wrote: On Mar 15, 9:23 pm, wrote: Except when the control system is misrigged like a plane I flew recently. In order to get a coordinated turn, I had to give "top" rudder in a turn. That's wrong. Is that the one in which I suggested a broken rudder bar spring? Anything come of that? Dan Yeah, I think so. Another person also emailed me private and said the same. The chief pilot and other instructors at the FBO got an email from me. Never heard anything back. Maybe they checked it out and decided I was wrong; or maybe I found a problem and they don't want to comment on it in a traceable way. I think I'll switch to their 172, rather than fly that 150. On the other hand maybe they have fixed it and I just don't know about it. |
On Mar 16, 3:44 pm, wrote:
I'd say that the rudder controls yaw, period. You can change heading using the rudder. I've done it (hah, especially a lot as a student trying to practice power on stalls), and it stands to reason considering the force vectors acting on a fuselage that is yawed into the relative wind. I've never tried to do what Bertie describes though. But I will next time I'm up. Nevertheless I follow the school that says the elevator is really the main turn control (Langewiesche, Stowell, and many others). Which makes a lot of sense. It's just that numerous authors hold the theory that if the left vector is angled, the direction of flight is altered and the fin points the nose in the new direction. And as I said, some airplanes are so "well" designed (read: simple to fly) that no rudder input is needed at all to keep the ball centered while going into the turn, or keeping it there once established in the turn. Aileron geometry is such that adverse yaw is completely eliminated. Elevator is still necessary to counter the nose-drop as drag piles up, and there's no argument from me that it contributes to the turn, especially a steep turn. I can just imagine that some clever engineer will soon design an airplane that needs no elevator input in a turn. The R182 (colloquially known as the 182RG) is already a really tame airplane in a steep turn; I don't know how they did it, but steep turns in it are so easy, with an absolute minimum of back pressure. And that's with a forward CG, too. Dan |
On Mar 16, 6:44 pm, wrote:
I'd say that the rudder controls yaw, period. You can change heading using the rudder. I've done it (hah, especially a lot as a student trying to practice power on stalls), and it stands to reason considering the force vectors acting on a fuselage that is yawed into the relative wind. I've never tried to do what Bertie describes though. But I will next time I'm up. Nevertheless I follow the school that says the elevator is really the main turn control (Langewiesche, Stowell, and many others). Yes, but (oh those exceptions)... Rudder comes in handy for very small changes in course (such as required on an ILS). It's nearly impossible to bank 2 degrees, but very easy to correct 2 degrees with rudder. Dan Mc |
![]() -- Regards, BobF. "Dan" wrote in message ... On Mar 16, 6:44 pm, wrote: I'd say that the rudder controls yaw, period. You can change heading using the rudder. I've done it (hah, especially a lot as a student trying to practice power on stalls), and it stands to reason considering the force vectors acting on a fuselage that is yawed into the relative wind. I've never tried to do what Bertie describes though. But I will next time I'm up. Nevertheless I follow the school that says the elevator is really the main turn control (Langewiesche, Stowell, and many others). Yes, but (oh those exceptions)... Rudder comes in handy for very small changes in course (such as required on an ILS). You know, yaw right! Seriously, I've used this technique a lot. Works particularly well on large airplanes. I get mixed responses from DFE's however and check with them before I turn a student loose on him. Some don't mind it and another ripped one of students apart because of it. It's nearly impossible to bank 2 degrees, but very easy to correct 2 degrees with rudder. Dan Mc |
Looking for Wing Tip Skids | [email protected] | Soaring | 2 | June 23rd 07 02:48 PM |
slips to landing in PTS | BB | Soaring | 6 | April 17th 07 05:58 AM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
About forward slips | Mxsmanic | Piloting | 77 | November 2nd 06 11:35 PM |
High skids vs low skids | JKimmel | Rotorcraft | 0 | February 8th 06 01:15 AM |
