Airparks; Living On The Beaten Path?
Old March 18th 08, 01:46 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Gig 601XL Builder[_2_]
Default Pitot tube adjustment was Airparks; Living On The Beaten Path?
Highflyer wrote:
"cavelamb himself" wrote in message
All it takes is a little collar on the pitot tube (and a bit of tweaking
the position)
That is how we calibrate the airspeed indicator to get it reading with
reasonable accuracy. Old CG himself taught me that one. :-)
Of course, nowadays, you have to tweak the GPS also!
Anybody have photos of such a collar? Or able to give a good description?
Old March 18th 08, 03:55 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Bertie the Bunyip[_25_]
Gig 601XL Builder wrote in
tweaking
the position)
with reasonable accuracy. Old CG himself taught me that one. :-)
description?
Pretty sure there's one in Tony Bengelis' books. But you just take a
collet and slide it over the tube and then experiment by moving it back
and forth until your ASI is doing what you think is right.
Bertie
Old March 18th 08, 04:43 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Orval Fairbairn[_2_]
description?
Bertie
I tried that on my Johnson Rocket and got it to indicate 200 MPH in
level flight! Of course, it stalled at 100 instead of 60. ;)
All it is is an O-ring or something similar placed ahead of the static
pickup in the pitot/static system. This works only on planes that have a
combined pitot/static head, not on those that have the flush-mounted
static port on the side f the fuselage.
Remove _'s from email address to talk to me.
Old March 18th 08, 05:08 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Orval Fairbairn wrote in
news
description?
back
Bertie
a
Ah, OK, you mean the ones with two tubes, right?
Bertie
Old March 18th 08, 05:30 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Bertie
a
It doesn't matter -- all you have to do is be able to erect an airflow
fence ahead of the static pickup. This is one of the oldest tricks in
aviation -- dating back to at least the Thirties. It enabled salesmen to
sell a lot of "fast" airplanes!
Old March 18th 08, 06:17 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
news
Bertie
static pickup in the pitot/static system. This works only on planes
that have
a
flush-mounted static port on the side f the fuselage.
to sell a lot of "fast" airplanes!
Heh! Yeah, I think I've flown a few of those! I've certainly lown a few
where th eASI was next to useless, anyway.
Bertie
Old March 18th 08, 09:42 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Highflyer
"Gig 601XL Builder" wrote in message
the position)
Put an o-ring over the static tube. Adjust its distance from the static
holes in the side of the tube to adjust the static pressure reference for
your airspeed indicator. It also adjusts the static pressure reference for
the altimeter, which usually uses the same static port.
It doesn't work for the new airplanes th at pick up their static pressure
through a port on the side of the fuselage. :-)
Highflyer
Highflight Aviation Services
rec.aviation.homebuilt annual flyin coming up May 16, 17, and 18.
See the faq at http://www.ousterhout.net/pjy-faq.html and send Mary a note
at so she knows how many groceries to get.
Airparks... .Blueskies. Owning 9 May 8th 06 04:14 PM
Airparks and clubs around Phoenix AZ ? gilan Piloting 3 March 9th 06 01:07 PM
Airparks and clubs around Phoenix AZ ? gilan Owning 3 March 9th 06 01:07 PM
Airparks near Austin TX TIm Gilbert Owning 14 October 3rd 05 03:18 PM
A New, New Direction for a Beaten Dead Horse Shawn Soaring 0 February 25th 05 01:57 PM
