#81
On Feb 10, 12:57 am, cavalamb himself wrote:
wrote: On Feb 9, 2:10 pm, Anthony W wrote: I was wondering about that too. The compression ratio doesn't seem high enough to require that. Perhaps a thicker head gasket could be used to lower the CR so it would run on auto-premium to make it cheaper to operate. ... I once owned a McCulloch two-stroke four-cylinder drone engine that had been modified this way to derate it from 72 hp to 50 and to allow it to run smoother at a lower RPM. Terrible engine, commonly used years ago in Bensen's gyrocopters. They'd been built by McCulloch for the military, who used them in target drones for anti- aircraft gunners to practice shooting down, so the engine was designed for a 15-minute service life or something like that. In homebuilts, they vibrated like mad, and the mag would get hot and quit. The carburetor throttle shaft would wear the thin carb barrel walls out in no time flat and leak air. But cheap they were, light, and plentiful. Couple pictures of one, and one of a Franklin drone engine, too: http://www.barnstormers.com/EVENTS/0...museum-21.html Dan Perhaps, like teh VW, a spacer at teh bottom of the cylinder can be used to adjust compression? I know someone who added a third piston ring to his pistons. He said he got 95 hp, didn't say for how long, and I don't think he ever ran it full bore for very long. -- FF |
#82
![]() "Fred the Red Shirt" wrote in message ... On Feb 10, 12:57 am, cavalamb himself wrote: wrote: On Feb 9, 2:10 pm, Anthony W wrote: I was wondering about that too. The compression ratio doesn't seem high enough to require that. Perhaps a thicker head gasket could be used to lower the CR so it would run on auto-premium to make it cheaper to operate. ... I once owned a McCulloch two-stroke four-cylinder drone engine that had been modified this way to derate it from 72 hp to 50 and to allow it to run smoother at a lower RPM. Terrible engine, commonly used years ago in Bensen's gyrocopters. They'd been built by McCulloch for the military, who used them in target drones for anti- aircraft gunners to practice shooting down, so the engine was designed for a 15-minute service life or something like that. In homebuilts, they vibrated like mad, and the mag would get hot and quit. The carburetor throttle shaft would wear the thin carb barrel walls out in no time flat and leak air. But cheap they were, light, and plentiful. Couple pictures of one, and one of a Franklin drone engine, too: http://www.barnstormers.com/EVENTS/0...museum-21.html Dan Perhaps, like teh VW, a spacer at teh bottom of the cylinder can be used to adjust compression? I know someone who added a third piston ring to his pistons. He said he got 95 hp, didn't say for how long, and I don't think he ever ran it full bore for very long. -- FF Many years ago a friend of mine built a racing sports car around a McCullogh drone engine coupled to a VW transaxle with a flipped ring gear so the engine could mount in front of the axle. We balanced the engine and ported and relieved it. Changed to carb out for an old one barrel Pontiac carb and it put out about 120 HP on a dyno at 12000 rpm. ( no valve float! ) The resulting car turned a quarter mile at the drag strip between 10.2 and 10.4 seconds. Not bad at all for a two place automobile with 66 cubic inches of engine! Highflyer 2008 Pinckneyville Rec Aviation Flyin The annual flyin time is coming around again! I finally got to where I could find things in the hangar again, which is a sure indication that it is time to start flyin preparations! The local motels will be filling up fast again so you may want to get your reservations in as soon as you can if you want a close motel room. WHEN: May 16, 17, and 18 this year. Once again, it is the full weekend prior to the Memorial Day official weekend. This has become the traditional historical date for the flyin. It allows folks to plan well ahead to this incredible trek. For many it becomes the cross country trip that they talk about to everyone that will hold still long enough to listen. WHE Pinckneyville DuQuoin Airport, Pinckneyville, Illinois. PJY is the airport identifier. Put K in front if you have a fussy GPS. We are about 80 miles southeast of the Arch in St. Louis. There is a 4001 foot ( have to be over 4000 feet for jets! ) north-south runway ( 18L – 36R ) with an 1800 foot grass runway parallel to the northern half. ( 18R – 36L ) . There is no taxiway. This an access taxiway perpendicular to the runways. We do have instrument approachs again, but they are GPS approachs only. WHAT: The annual t here day get together of the diehards on the rec.aviation newsgroups. Buddy rides all day and hangar flying all night. Other entertainment as happens. Beer, soda, and good food. The PJY barbeque is world renowned, as are the uniquely HOT Italian sausages served on Thursday night. The Red Lady should be flying this year. WHO: Pilots, about to be Pilots, wannabe Pilots, and anybody else who is willing to put up with a bunch of wild eyed folks who talk about airplanes and flying all day and all night. COST: This is not one of those "break the bank" flyins. Highflyer and Mary try to keep the costs in line so that we can have a good time without being rich. We do that because a lot of people who come to the flyin own airplanes. We all know that people who own an airplane are not rich anymore! We try to collect $25 from everyone to defray the cost of the beverages and the groceries. We do breakfast, lunch, and dinner every day. Usually we have baby back ribs, steak, and chicken on Saturday night. Friday night we have something good. No one goes hungry. We do have something for vegetarians. ACCOMODATIONS: Pitch a tent next to your airplane if you like. There is no charge for camping on the field. We have a couple of bathrooms, but no showers. Generally, if someone really would like to shower one of the folks in a motel can help you out. We do have a garden hose. There are places you can park a camper or motorhome near the action. If you are really nice, we can even run you out an extension cord for an electrical hookup. No sewer hookups though. If you want a motel there are several in the area now. The preferred flyin motel is the Mainstreet Inn, in Pinckneyville. The lady who runs it always puts up with our group graciously. One year she even shortsheeted every bed in the place, for a small bribe! Her phone number is 618-357-2128. The rates are quite reasonable. A little fancier is the local Oxbow Bed and Breakfast. This is between the airport and town, right on the edge of town. A number of our folks stay there every year they come and speak very highly of the establishment. Their phone number is 618-357-9839. We always manage to arrange some kind of transportation to and from both of these places. If they are full there are other motels in the area and transportation can usually be managed with no particular problems. HOW: Flying to PJY is the primo way to arrive. If that doesn't work many fly commercial to St. Louis and rent a car for the last 90 miles from the airport. Whatever works for you works for us! Pinckneyville airport is right on Illinois 127 just six miles south of the town of Pinckneyville. Route 127 is exit 50 off of I-64. The airport is about 30 miles south of I-64. Please send an email to Mary at so that she can get some idea how many steaks to buy for Saturday night dinner! It makes it a lot easier when we have some idea of how many people to plan for meals. |
#83
![]() in the usual VW car engine the harmonic charactersitics of the crankshaft are such that the destructive vibration occurs a few thousand revs above the max possible rpm so the engine never experiences a problem. in aircraft installations with large heavy propellors attached to the shaft the harmonic range occurs at a lower RPM. particularly with large 3 bladed ground adjustable composite props the destructive harmonic range comes down to about 3,200rpm. most VW's would run at around those revs so the problem becomes an unavoidable one. the destructive harmonics are indetectable in the cockpit above the normal engine vibrations but in the engine's interior those harmonics deliver hammer like blows to the crank web. the hollow area above the centre of the internal web gets a fair shaking and develops a fine hairline fatigue crack. this crack leaks copious amounts of oil and of course there is no way of welding oily electron so the case becomes junk. It certainly should be possible to degrease the case by vapor condensation. Tricloroethane was the solvent of choice before the enviro-nazis got hold of things. the problem can be avoided completely by using lightweight fixed two bladed wooden props. Better idea is to put a flywheel on the engine and use a redrive that provides some isolation to the engine from its load. The marine industry figured this out in the 1950s and the inboard/outdrive is nearly universal now. |
#84
![]() The maximum SUSTAINABLE power available from ANY air-cooled engine is determined by the engine's ability to cool itself -- to couple its waste-heat to the atmosphere. And with a carburetted, spark-ignited, gasoline-fueled engine there is a LOT of waste heat to be managed since such engines are no more than 25% efficient when it comes to converting the heat of combustion into torque at the crankshaft. That means that for every horsepower measured at the crank you must generate at least four horsepower's-worth of heat in combustion. These basic rules of thermodynamics are made even worse by two additional factors, the first being 'Economy of Scale' in that smaller engines are LESS thermally efficient than larger engines, and the basic definition of Standard Day conditions -- 59.9 degrees on the Fahrenheit scale and an atmospheric pressure of 29.92 inches of mercury -- a fairly cool day. With those laws of physics as preamble the next factor worthy of note is the physical dimensions of the Volkswagen cylinder head and the fact that ALL VW heads have the same exterior dimensions. This is because they must fit under the stock VW engine shrouding. No manufacturer of VW heads, either stock or after-market, offers a head having more fin area. Indeed, most after-market heads have LESS, due either to thickening of the combustion chamber wall or even eliminating one of the eight fins -- and in a few cases they have done both. I think the Scat single unit heads have somewhat more as do the 356 Porsche heads after '59 or so. Both require different sheet metal in the car. All -- ALL -- Volkswagen heads in common use today are derived from the heads developed for the 1300cc engine; their external physical dimensions remained exactly the same for the later 1500 and 1600 engines. The output of the 1300 engine was approximately 40hp and could SUSTAIN that level of output indefinitely under Standard Day conditions. This engine was bored-out to 83mm to produce the 1500 engine, then over-bored to 85.5mm to create the 1600 (actual displacement 1584cc), the maximum output of which was 57bhp for carburetted models, achieved in the 1971 model year. But that level of output could only be sustained for a bit less than FOUR MINUTES, until the cylinder head temperature exceeded safe levels, again under Standard Day conditions. So what's this 'safe level' of CHT? About 450 degrees on the Fahrenheit scale. This reflects the fact that VW heads are made of CAST aluminum (as opposed to a forging) and the fact aluminum is a 'white short' metal, meaning it becomes frangible when its temperature enters the 'plastic' range. A characteristic of white-short metals is that when heated they fracture like a cube of sugar when subjected to stress. The floor of the frangible range is a bit higher for a forging -- about 550F according to Pratt-Whitney -- but can be as low as 400F in a casting, depending upon the alloy. You could always go to an iron or bronze (if TEL is eschewed) head..... A common thread used to impress technologically naive buyers is tales of driving a Volkswagen bug or bus for hours on end with the throttle wide open. The fact the engine was was probably producing LESS THAN TWENTY HORSEPOWER goes unsaid. This involves the Horsepower Myth and generally leaves a large black question mark hanging over the heads of those without an engineering background but it needs to be touched upon since ignorance can be as deadly as a machine gun when it comes to aviation. The Horsepower Myth was create by James Watt in order to sell his modified Newcommen steam engine to mine owners. To do so he added the element of TIME to the power equation and from that day to this the general public has been comfortable with the idea that 'horsepower' represents a given quanta of energy... which it does... but only within a defined unit of TIME. And from that day to this, that arithmetical loophole has been used by those eager to prey upon technologically naive consumers. Indeed, in the early days of aviation those predations cost so many lives that government agencies had to step in, requiring the manufacturers of aircraft engines to justify their claims of power and durability. ------------------------------------------------------ All of which tends to leave the average homebuilder with more questions than answers. Fortunately, the ENGINES themselves are incapable of lying, especially when it comes to FUEL CONSUMPTION. The Specific Fuel Consumption (SFC) of all -- ALL -- air-cooled, gasoline-fueled, normally aspirated Otto-cycle engines is clumped near the 0.5 mark, meaning it takes about 0.5 POUNDS of 'gasoline' (*) per HOUR to produce ONE HORSEPOWER'S worth of torque at the crankshaft. For aviation gasoline that works out to about 12bhp per gallon per hour. For a 103hp engine that works out to 8.58 gph. Liquid cooling is simply so superior that the air cooled gasoline-and even (see Deutz) diesel-is a museum piece per se. That said the Harley conversion seems to be working out better than anyone would have thought. |
#85
![]() Bill Daniels The cooling systems on motorcycle engines do not have sufficient coolant flow to keep the head from over heating under prolonged running at 3/4 to full output. The water craft and snowmobile engines may have better flow but these also have access to lower temp coolant. Honda makes a personal water craft that has a hot little 4 banger engine that I thought might do the job. It would take some testing to see what it's sustained power level would be. Car engines now are designed for full throttle continuous operation because that's how the Germans run them. Actually another application that does that, is the common school bus. Underpowered, they are run flat out for a long time sometimes. Most now use diesels that are way too heavy to fly, but when they ran Chevies, they ran a regular old four bolt forged crank SBC. |
#86
On Feb 6, 1:20 pm, cavalamb himself wrote:
RST Engineering wrote: Come on, Bob. How do you expect the EAA to make a buck out of something as useful as this? Sheesh, man, cherchez le dinero. Jim Indeed, these things are so simple -- and so fundamental to engines -- that it is difficult to understand why the EAA does NOT endorse a program of publicly testing engines at its annual convention. Endorsement would equate to liability. BEsides, EAA has never really been about the reality of it - they sell the dream. Fantasy, even. |
#87
![]() I didn't verify it but according to a History channel show on Tucker. After too many failures of the Tucker engine, Franklin aircraft engines were converted to liquid cooling and proved to be reliable and Tucker bought the Franklin company to be sure and have an uninterrupted supply of engines for his cars. After the bankruptcy, the Franklin engine company was sold off but I don't know who bought it and I assumed they were gone forever. If the Pols are doing a good job at building these new Franklin engines, they sure look like a bargain. Tucker didn't have a lot of common sense. |
#88
![]() "Bret Ludwig" wrote in message ... Car engines now are designed for full throttle continuous operation because that's how the Germans run them. Actually another application that does that, is the common school bus. Underpowered, they are run flat out for a long time sometimes. Most now use diesels that are way too heavy to fly, but when they ran Chevies, they ran a regular old four bolt forged crank SBC. Back in the late 70s I drove a Chevy flatbed dump truck powered by a 350. Always hauled a 8000 lb Ditch Witch and pulled a 16000 lb Case back hoe. Had to run flat on the floor every where I went. Never had any problems, even in summer. Did have a nice sized radiator though. I think of that rig every time I hear someone claim that auto engines won't survive at high power settings. |
#89
![]() "Bret Ludwig" wrote in message ... I didn't verify it but according to a History channel show on Tucker. After too many failures of the Tucker engine, Franklin aircraft engines were converted to liquid cooling and proved to be reliable and Tucker bought the Franklin company to be sure and have an uninterrupted supply of engines for his cars. After the bankruptcy, the Franklin engine company was sold off but I don't know who bought it and I assumed they were gone forever. If the Pols are doing a good job at building these new Franklin engines, they sure look like a bargain. Tucker didn't have a lot of common sense. The Franklin engine company was alive and well in the late 60's in upstate New York. I worked with them when they were developing the new line of Franklin Aircraft engines. These were a twin, a four cylinder and a six cylinder engine that all used the same cylinders and valves. They brought them out first as an engine kit for homebuilders. However that didn't go over very well because at that time there were not all that many homebuilts and most did not want to spend the money for a new engine. Even as a kit. When they finally went under financially the rights to the engines were sold to PZL in poland who continued to produce the engines until recently. Highflyer Highflight Aviation Services Pinckneyville Airport, PJY Note: rec.aviation.homebuilt annual flyin at Pinckneyville is coming up May 16,17, and 18th. See the faq at http://www.ousterhout.net/pjy-faq.html and do let Mary know at so she knows how many groceries to lay in. |
#90
"Highflyer" wrote:
The Franklin engine company was alive and well in the late 60's in upstate New York. I worked with them when they were developing the new line of Franklin Aircraft engines. These were a twin, a four cylinder and a six cylinder engine that all used the same cylinders and valves. They brought them out first as an engine kit for homebuilders. However that didn't go over very well because at that time there were not all that many homebuilts and most did not want to spend the money for a new engine. Even as a kit. When they finally went under financially the rights to the engines were sold to PZL in poland who continued to produce the engines until recently. Do you know who, if anyone, is producing them now? Also, are the guys at this firm: http://www.franklinengines.com/ just U.S. distributers or are they actually making them now? |
HondaJet a reality | [email protected] | Piloting | 3 | July 28th 06 01:50 AM |
Pilot deviations and a new FAA reality | Chip Jones | Piloting | 125 | October 15th 04 07:42 PM |
Pilot deviations and a new FAA reality | Chip Jones | Instrument Flight Rules | 36 | October 14th 04 06:10 PM |
Reality of Tie Down (Tiedown) Space at SNA | Tie Town | Owning | 1 | May 6th 04 07:43 AM |
Reality of Tie Down (Tiedown) Space at SNA | Tie Town | Piloting | 1 | May 6th 04 07:43 AM |
