The smallest jet aircraft in the world - BD-5J (homebuilt)
Old March 21st 08, 12:32 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
Default The smallest jet aircraft in the world - BD-5J (homebuilt)
On Mar 20, 10:05 pm, "Al G" wrote:
"Richard Isakson" wrote in message
om...
"Anthony W" wrote ...
If I were a much shorter (not to mention thiner) man, I would build a
Mitchell U2 with a 4 pack of those tiny turbines. It would take the
record and look like the space shuttle from behind. ;o)
There's already been a turbine powered Mitchell wing.
Rich
Well, the piston version hasn't done too bad:
Record Task: Altitude (Without Payload)
Start City: Colorado Springs, CO
Finish City:
Performance: 25942 feet (7907 meters)
Class, Subclass, Classification, Group: C, C-1, a/o, I (Piston)
Record Holder(s):
Richard J. Rowley
Date of record: 9/17/1983
Aircraft Make and Model: Mitchell U-2 Superwing
Engine Make and Model: Cuyuna 430D
THAT MItchel Wing is much heavier than a Cri cri
and has a longer wingspan, though the fuselage,
such as it is, may be shorter.
IIRC Cri cri is about a hundred pounds under the FAR 103
wieght limit though of course the stall and max speed are
out of the range.
Neither the U2 or B10 are light enough for FAR 103, though
last I heard there is a prototype ultralight version not
currently flying or fully assembled. I don;t recall if it
was completed and flown then disassembled or what.
FF
Old March 21st 08, 02:40 PM posted to rec.aviation.homebuilt
wright1902glider
On Mar 20, 6:32*pm, Fred the Red Shirt
news:jfWdnXvYkMMcNX_anZ2dnUVZ_quhnZ2d@whidbeytel. com...
IIRC *Cri cri is about a hundred pounds under the FAR 103
out of the range.
currently flying or fully assembled. *I don;t recall if it
For that matter, why not just bolt a pair of AMT's to the kingpost of
a Wills Wing. Eight good steps on a decent slope and you're airborne.
Ease the throttle open, ease the bar out, climb out, **** off the
gaggle of paraglider pilots circling overhead, earn a lifetime ban
from the launch site. Oh yeah, somebody will probably call the cops
and the FAA. No problem being part 103 legal, but somebody will still
try to pick a bone with you. BUT, I'm sure it would qualify for some
sort of record.
Harry
Can I modify a used homebuilt aircraft? [email protected] Home Built 4 June 24th 07 09:09 PM
Worlds smallest FlyBaby! cavelamb himself Home Built 0 March 27th 07 04:37 PM
Biggest and smallest aviators José Herculano Naval Aviation 23 February 7th 05 02:12 PM
I'm STILL trying to ID a homebuilt aircraft Phillip Rhodes Restoration 1 November 27th 03 06:59 AM
I'm still trying to ID a homebuilt aircraft Phillip Rhodes Home Built 1 November 26th 03 08:43 PM
