On Wed, 19 Mar 2008 21:04:46 -0400, John
wrote: Does anybody still do the old technique of drilling holes before tacking tubes together to interconnect them for oiling the fuse when it's finished? I've been told that's not done any more, because of the realization that as long as the welds are air tight, the oxygen trapped in the tube is consumed in a small amount of oxydation of the metal surface inside until all that's left is nitrogen and then it's fine without any oil inside. Comments? John my old Auster had a section where the drain holes in the fabric had been forgotten. the rudder particularly had been flying around for years with about 9" of water in the bottom of it. there were lots and lots and lots of tide marks in the fabric where the rusty water had partially dried out then refilled. needless to say the entire lower tube frame of the rudder was corroded through in a number of places. when we cut the corroded section away and looked into the tube, an eighth of an inch away from the rusted through area on into the rest of the tube the tube was pristine. the poms had swabbed out the inside of the tube with lanoline. skimp on the little eighth inch holes all you like and dont bother to put tube seal in the tubes. they're such a bother. ....might just bite you in the arse one day. soaking all the auster fuselage tubes took less than half a can of tube seal and even with our import costs was under $20. for that I have a totally corrosion free fuselage and it will stay that way. experimenting is such fun. go for it. Stealth Pilot |
KR-2 fuse for sale | Turbo Tiger | Home Built | 3 | December 17th 05 06:27 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
Fuse the Wire or Fuse the Device? | ContestID67 | Soaring | 11 | April 27th 05 03:13 AM |
Cambridge Fuse Question | Brian Iten | Soaring | 9 | January 4th 05 02:43 PM |
Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 23rd 03 11:08 PM |
