basic club logger suggestions
Old March 24th 08, 04:29 PM posted to rec.aviation.soaring
ContestID67
Default basic club logger suggestions
P3 had it right about the fragility of some logger or PDA systems in a
club environment. I tried to bullet-proof the system I made for our
club (which I mentioned in a previous post).
I uploaded my club's manual on the use of our EW Recorder flight
logger system to http://www.geocities.com/jhderosa/av...lightrecorders.
Enjoy, John "67" DeRosa
Old March 24th 08, 05:23 PM posted to rec.aviation.soaring
Cats
club environment. *I tried to bullet-proof the system I made for our
logger system tohttp://www.geocities.com/jhderosa/aviation/flightrecorders..
I read your documentation, and noticed you are recommending mounting
the antennae on the canopy in your club gliders. Have you checked to
see it won't impede ejecting the canopy?
Old March 24th 08, 05:48 PM posted to rec.aviation.soaring
vontresc
the antennae on the canopy in your club gliders. *Have you checked to
I don't remember seeing anything with regards to the IGC meeting and
off the shelf GPS use for badge flying. What was the outcome of that?
Pete
Old March 25th 08, 03:20 AM posted to rec.aviation.soaring
ContestID67
I Originally Wrote: I uploaded my club's manual on the use of our EW
Recorder flight
"Cats" Commented I read your documentation, and noticed you are
I reply:: A valid concern. The antenna bracket is held to the canopy
with 4 small suction cups.
While they do stay suck quite well (as the antenna is very light
weight), the cups come
off very easily with only a modicum of force and the canopy will
certainly eject quite
fast when it encounters a high wind load.. As you can imagine, I
haven't tested this.
Along the same idea, I have seen PDA's attached to the canopy and
feel
that this is an especially bad idea for the same reason you mention,
the canopy might not
eject properly. The PDA is typically firmly mechanically mounted to
the canopy rail or
large suction devices to the canopy itself. Either way it will NOT
give way at all easily.
The PDA cable is generally pretty stought and firmly connected to the
PDA to
prevent it from dislodging during flight. If you think that the cable
will break, try it
yourself. You will find it more difficult than you imagine.
The extreme case of all this would be the canopy ejecting to the side
and staying attached, which would fairly quickly put you into a tight
turn, spiral or even a spin.
All in all, not the situation you want to be in while trying to bail
out. If you must do this, then
please put in a slide disconnect of some sort which will easily pull
free during an eject
but stay connected during flight.
Good luck and stay safe.
- John "67" DeRosa
Old March 25th 08, 08:18 AM posted to rec.aviation.soaring
Cats
On Mar 25, 3:20*am, ContestID67 wrote:
I Originally Wrote: *I uploaded my club's manual on the use of our EW
Recorder flight
"Cats" Commented *I read your documentation, and noticed you are
I reply:: A valid concern. *
snip
I ask because of the eventual outcome of a fatal accident in the UK:
http://www.aaib.gov.uk/sites/aaib/pu... der__gdp.cfm
or
http://preview.tinyurl.com/2q95u7
Also there is a report on an accident to a DG505:
http://www.aaib.gov.uk/sites/aaib/pu...a_4432_jdn.cfm
or
http://preview.tinyurl.com/32zz5y
Club Class suggestions nimbusgb Soaring 6 January 12th 08 09:13 PM
Club Class Suggestions David Smith Soaring 0 January 12th 08 08:37 PM
Basic Training Gliders Justin Craig Soaring 0 December 6th 05 10:07 PM
A very basic question Ramapriya Piloting 45 November 9th 04 01:57 PM
Cheapest Club (was Best Gliding Club Website) Clint Soaring 20 November 15th 03 04:49 AM
