Tauno Voipio wrote in
: Airbus wrote: In article , says... Robert M. Gary wrote: On Mar 23, 2:25 pm, Cubdriver usenet AT danford DOT net wrote: Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -Robert The engine is made by Thielert in Germany. It is a modified Mercedes common-rail diesel engine. For more information, go to http://www.centurion-engines.com/. By the way, it runs on the big-airplane food: JET-A1. -- I am personally aware of two such planes (Thielert-powered C-172's) which have been removed from service due to unexpected, and as yet unexplained engine stoppages. . . Anyone else heard of this? Thielert has had its portion of new-design woes: - problems in fuel and cooling plumbing, - gearbox / clutch problems, - broken high-pressure pumps. AFAIK, no real problems with the most feared component, FADEC (Full Authority Digital Engine Control). One twin with Thielerts came down immediately after take-off in Germany, when its electrical system collapsed. The engines had been started with external power and the battery was not in system at all. The procedure was prohibited in the operation manual. The electrical systems have been changed so that it is not anymore possible to repeat the preformance. This was actually more an airframe problem than an engine problem. Bull****. Engine installation problem. Bertie |
On Wed, 26 Mar 2008 07:48:30 +0000 (UTC), Bertie the Bunyip
wrote: Tauno Voipio wrote in : Airbus wrote: In article , says... ME,? I want a big, honkin' 350 to 360 HP that will fit nicely into the Deb and cost about as much as a new IO-360:-)) Can you tell the hours are getting close to TBO? Bull****. Engine installation problem. Bertie Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Bertie the Bunyip wrote:
Tauno Voipio wrote in : Airbus wrote: In article , says... Robert M. Gary wrote: On Mar 23, 2:25 pm, Cubdriver usenet AT danford DOT net wrote: Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -Robert The engine is made by Thielert in Germany. It is a modified Mercedes common-rail diesel engine. For more information, go to http://www.centurion-engines.com/. By the way, it runs on the big-airplane food: JET-A1. -- I am personally aware of two such planes (Thielert-powered C-172's) which have been removed from service due to unexpected, and as yet unexplained engine stoppages. . . Anyone else heard of this? Thielert has had its portion of new-design woes: - problems in fuel and cooling plumbing, - gearbox / clutch problems, - broken high-pressure pumps. AFAIK, no real problems with the most feared component, FADEC (Full Authority Digital Engine Control). One twin with Thielerts came down immediately after take-off in Germany, when its electrical system collapsed. The engines had been started with external power and the battery was not in system at all. The procedure was prohibited in the operation manual. The electrical systems have been changed so that it is not anymore possible to repeat the preformance. This was actually more an airframe problem than an engine problem. Bull****. Engine installation problem. Bertie Please explain - what is the difference with an airframe problem and an engine installation problem here? As far as I understand, the electrical system design is an airframe part. -- Tauno Voipio, avionics engineer tauno voipio (at) iki fi |
Tauno Voipio wrote in news:L7sGj.157$3J.112
@read4.inet.fi: Please explain - what is the difference with an airframe problem and an engine installation problem here? As far as I understand, the electrical system design is an airframe part. No, it's an electrical system part. Airframe parts are wings and what not.... Bertie |
Wind limits - small single engine aircraft | [email protected] | Piloting | 30 | February 7th 07 07:36 AM |
Help ! SMALL Radial engine | Chris Wertman | Home Built | 12 | July 18th 05 02:46 PM |
Small 4 stroke engine? | Ron Wanttaja | Home Built | 35 | July 2nd 05 07:25 PM |
What is the single-engine small plane with the best range? | Bob | Owning | 24 | February 19th 04 04:15 AM |
Help ! SMALL Radial engine | Chris Wertman | Military Aviation | 11 | January 4th 04 08:22 AM |
