Thin Airfoil and Climb Performance
Old March 29th 08, 03:43 PM posted to rec.aviation.soaring
Eric Greenwell
Default Thin Airfoil and Climb Performance
Eric Greenwell wrote:
I attended Boerman's lecture. The problem isn't thin, laminar flow
airfoils in general, but some specific designs over the last two decades
or so that have a "flat spot" in the lift coefficient (Cl) curve as the
angle of attack (AOA) approaches stall. Normally, the Cl increases with
increasing AOA, but in the flat spot region, it remains constant (or
nearly so) even as the AOA increases. Past this region, Cl begins to
increase again with AOA at the usual rate.
I should add that designers were aware of the flat spot years ago, but
did not appreciate the problems it could cause in gusty conditions.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old April 1st 08, 02:20 AM posted to rec.aviation.soaring
* Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4
* "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org
If I understood Loek correctly, "gusty" isn't perhaps the right
description. Better "high frequency changes in vertical velocity,
causing momentary increases in required CL" ? Its not something
you'd necessarily feel as a pilot if I understood correctly.
Eric ?
Old April 2nd 08, 06:02 AM posted to rec.aviation.soaring
Eric Greenwell
Eric ?
I don't recall the presentation well enough to say for sure, but my
impression is the pilot would be aware that it's not smooth air,
probably enough that the pilot would be making some control corrections.
It would be better to ask Loek, or someone like Dan Somers or Mark
Maughmer, who are also aware of it.
climb performance Jet vs Prop xerj Piloting 11 July 7th 06 06:31 AM
Duo Turbo Climb / Altitude performance Gary Emerson Soaring 16 November 28th 05 08:19 AM
relative climb performance Soaring 8 September 17th 05 07:21 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
172 N Climb Performance Roger Long Piloting 6 September 10th 03 11:18 PM
