#11
![]() "Sliker" wrote in message ... On the older Glasair kits like mine, it's covered with the dark gray gelcoat that contains 2% carbon black for UV resistance. I wonder if the carbon interferes with radio reception? I've read that cabon fiber structures block signals, but how much carbon it takes to do that I don't know. But for the Glasair folks to say the radios worked so much better when the moved the antennas outside, makes me think some part of the structure was blocking radio signals.. I could be wrong, but I recall that Jim Weir has done extensive testing on airplanes, and what structures block radio signals, and carbon fiber has been found to not be a problem. I hope I remembered right, and Jim will probably jump in here and clarify the situation. When it comes to antenna mounting and performance, I think we are lucky to have a resource such as Jim to help us get on the right path. He is an expert on the subject, IMHO. -- Jim in NC |
"Morgans" wrote in message
... "Sliker" wrote in message ... On the older Glasair kits like mine, it's covered with the dark gray gelcoat that contains 2% carbon black for UV resistance. I wonder if the carbon interferes with radio reception? I've read that cabon fiber structures block signals, but how much carbon it takes to do that I don't know. But for the Glasair folks to say the radios worked so much better when the moved the antennas outside, makes me think some part of the structure was blocking radio signals.. I could be wrong, but I recall that Jim Weir has done extensive testing on airplanes, and what structures block radio signals, and carbon fiber has been found to not be a problem. I hope I remembered right, and Jim will probably jump in here and clarify the situation. When it comes to antenna mounting and performance, I think we are lucky to have a resource such as Jim to help us get on the right path. He is an expert on the subject, IMHO. -- Jim in NC That's very true, and the little that I did was 20 years ago. Jim Weir is current. Peter |
On Tue, 1 Apr 2008 16:34:13 -0400, Morgans wrote:
I could be wrong, but I recall that Jim Weir has done extensive testing on airplanes, and what structures block radio signals, and carbon fiber has been found to not be a problem. I hope I remembered right, and Jim will probably jump in here and clarify the situation. This is concurred in F1 racing now for better than a decade. -- Remove numbers for gmail and for God's sake it ain't "gee" either! I hesitate to add to this discussion because I'm not an instructor, just a rather slow student who's not qualified to give advice that might kill someone. |
There are hundreds of variations of carbon fiber "mixes". Some have
absolutely no effect on internal antennas, and some that are absolutely wonderful Faraday shields (blocks) of radiation performance. My work with Rutan on Voyager pretty much proved that. HOWEVER, having said that, we proved in the Bellanca experiments that regular old silver UV dope on fiber has absolutely no effect on internal antennas. Even the FAA accepted our experiments on that. On the other hand, mixing carbon black, which is not a conductor, nor an insulator, but a lossy medium is in fact an antenna attenuator. For some manufacturer of kits to come out and say, "hey, we started putting in carbon black to our mix and now we've got internal antenna problems" isn't a great surprise. I work real cheap. I'm not a thousand dollar an hour consultant. You'da thought that all you who are spending tens of thousands of dollars a kit would have had professional antenna consulting from these yahoos who are all of a sudden discovering that moving this or changing that is having an effect on their antenna performance would come to the source for advice. Not a one of them, other than Bellanca and Beech. Cheap *******s. To the person that asked whether carbon black has an influence with internal antennas, I pose the following question: We proved at Bellanca that reflection from aluminum particle to aluminum particle to the outside world didn't affect transmission through "silver dope" UV protectant to any measurable degree. However, carbon black is not a reflector, but an absorber. Signals don't get reflected in carbon; they get converted to heat and absorbed. That ain't rocket science; that's what I teach to my freshman engineering students. Is that understood? You folks that are paying tens of thousands of dollars for your kits need to have your vendors take my freshman engineering class. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Morgans" wrote in message ... "Sliker" wrote in message ... On the older Glasair kits like mine, it's covered with the dark gray gelcoat that contains 2% carbon black for UV resistance. I wonder if the carbon interferes with radio reception? I've read that cabon fiber structures block signals, but how much carbon it takes to do that I don't know. But for the Glasair folks to say the radios worked so much better when the moved the antennas outside, makes me think some part of the structure was blocking radio signals.. I could be wrong, but I recall that Jim Weir has done extensive testing on airplanes, and what structures block radio signals, and carbon fiber has been found to not be a problem. I hope I remembered right, and Jim will probably jump in here and clarify the situation. When it comes to antenna mounting and performance, I think we are lucky to have a resource such as Jim to help us get on the right path. He is an expert on the subject, IMHO. -- Jim in NC |
Sounds like the carbon black mixed into the gelcoat could have been
the culprit. But I know how to fix that! the 'ole power sander in the areas where the antenna's are. That carbon black will sand off, and is not structural at all. And a good layer of primer and paint will provide enough UV resistance, especially for a plane stored in hangar. I've noticed that the tech support folks at the old Stoddard-Hamilton would advise to sand off the gray primer at the drop of a hat for just about any issue. Such as possible fuel leaks over the spar, they would just say to sand off the gray primer to make the structure underneath transparent, and the leak easier to find. Or if any laminates needed to be applied in areas of the primer, off it comes again. The carbon black was probably a bad idea in hindsight, and no doubt why they quietly stopped using it. Thanks for the great insight! The main negative to sanding off the gray gelcoat is it opens up the pinholes. And I'm just getting into dealing with those. I hear so many different ways to cover them up. Some say mix some dynalight bondo with acetone and use a razor blade to sqeege it inside the holes. I just wish that carbon black was never used in the first place. More work for us builders. Rich On Tue, 1 Apr 2008 23:47:30 -0700, "RST Engineering" wrote: There are hundreds of variations of carbon fiber "mixes". Some have absolutely no effect on internal antennas, and some that are absolutely wonderful Faraday shields (blocks) of radiation performance. My work with Rutan on Voyager pretty much proved that. HOWEVER, having said that, we proved in the Bellanca experiments that regular old silver UV dope on fiber has absolutely no effect on internal antennas. Even the FAA accepted our experiments on that. On the other hand, mixing carbon black, which is not a conductor, nor an insulator, but a lossy medium is in fact an antenna attenuator. For some manufacturer of kits to come out and say, "hey, we started putting in carbon black to our mix and now we've got internal antenna problems" isn't a great surprise. I work real cheap. I'm not a thousand dollar an hour consultant. You'da thought that all you who are spending tens of thousands of dollars a kit would have had professional antenna consulting from these yahoos who are all of a sudden discovering that moving this or changing that is having an effect on their antenna performance would come to the source for advice. Not a one of them, other than Bellanca and Beech. Cheap *******s. To the person that asked whether carbon black has an influence with internal antennas, I pose the following question: We proved at Bellanca that reflection from aluminum particle to aluminum particle to the outside world didn't affect transmission through "silver dope" UV protectant to any measurable degree. However, carbon black is not a reflector, but an absorber. Signals don't get reflected in carbon; they get converted to heat and absorbed. That ain't rocket science; that's what I teach to my freshman engineering students. Is that understood? You folks that are paying tens of thousands of dollars for your kits need to have your vendors take my freshman engineering class. Jim |
Metallic paint and composite antenna signal strength | firstflight | Home Built | 23 | July 26th 05 09:10 PM |
Antennas | Terry | Home Built | 3 | April 24th 05 06:42 PM |
Antennas | Terry | Home Built | 3 | April 22nd 05 03:14 AM |
Hello, kingbee, Do not release, its the internal rls! | Frank Laczko | Home Built | 0 | February 13th 04 06:59 PM |
Tost internal Winch | HL Falbaum | Soaring | 3 | September 24th 03 02:31 PM |
