"Morgans" wrote in message
... "Sliker" wrote in message ... On the older Glasair kits like mine, it's covered with the dark gray gelcoat that contains 2% carbon black for UV resistance. I wonder if the carbon interferes with radio reception? I've read that cabon fiber structures block signals, but how much carbon it takes to do that I don't know. But for the Glasair folks to say the radios worked so much better when the moved the antennas outside, makes me think some part of the structure was blocking radio signals.. I could be wrong, but I recall that Jim Weir has done extensive testing on airplanes, and what structures block radio signals, and carbon fiber has been found to not be a problem. I hope I remembered right, and Jim will probably jump in here and clarify the situation. When it comes to antenna mounting and performance, I think we are lucky to have a resource such as Jim to help us get on the right path. He is an expert on the subject, IMHO. -- Jim in NC That's very true, and the little that I did was 20 years ago. Jim Weir is current. Peter |
Metallic paint and composite antenna signal strength | firstflight | Home Built | 23 | July 26th 05 09:10 PM |
Antennas | Terry | Home Built | 3 | April 24th 05 06:42 PM |
Antennas | Terry | Home Built | 3 | April 22nd 05 03:14 AM |
Hello, kingbee, Do not release, its the internal rls! | Frank Laczko | Home Built | 0 | February 13th 04 06:59 PM |
Tost internal Winch | HL Falbaum | Soaring | 3 | September 24th 03 02:31 PM |
