if you do not have RSA-5 or RSA-10 injection servos or have not had maint
done on that engine since Aug 2006. A one time inspection to confirm the part numbers and log inspection, then write it off as N/A by the A&P. I did not see any reference to a permanent fix to do away with the 50hr repetitive inspection. For those that need it. BT "Robert M. Gary" wrote in message ... AD 2008-06-51 prohibits injected (mostly Lycoming) aircraft owners from changing their own oil (really makes the plane unairworthy after an oil change until you get an A&P sign off). Talking to AOPA about this I really don't get the impression that they think this is very important. I would encourage everyone to send a quick email to AOPA and let them know that the FAA needs to find another way to do this AD other than restricting oil changes. -Robert |
It's a rather fluid situation. Precision's latest revision to PRS-107 is
dated 3/21/08 http://www.precisionairmotive.com/Pu...107%20Rev2.pdf and lists terminating action for their company SB by installing a new 2577258 gasket via their instructions and stamping the hex plug with a letter "G". In a round-about way this action terminates the AD because when completed, the servo will no longer contain the 365533 gasket to which the AD refers. Jim "BT" wrote in message ... if you do not have RSA-5 or RSA-10 injection servos or have not had maint done on that engine since Aug 2006. A one time inspection to confirm the part numbers and log inspection, then write it off as N/A by the A&P. I did not see any reference to a permanent fix to do away with the 50hr repetitive inspection. For those that need it. BT "Robert M. Gary" wrote in message ... AD 2008-06-51 prohibits injected (mostly Lycoming) aircraft owners from changing their own oil (really makes the plane unairworthy after an oil change until you get an A&P sign off). Talking to AOPA about this I really don't get the impression that they think this is very important. I would encourage everyone to send a quick email to AOPA and let them know that the FAA needs to find another way to do this AD other than restricting oil changes. -Robert |
true.. that is a "round about way".. I would expect that there would be a
revised AD forthcoming from the good ole FAA to recognize the "AD Terminating" procedure. BT "Jim Burns" wrote in message ... It's a rather fluid situation. Precision's latest revision to PRS-107 is dated 3/21/08 http://www.precisionairmotive.com/Pu...107%20Rev2.pdf and lists terminating action for their company SB by installing a new 2577258 gasket via their instructions and stamping the hex plug with a letter "G". In a round-about way this action terminates the AD because when completed, the servo will no longer contain the 365533 gasket to which the AD refers. Jim "BT" wrote in message ... if you do not have RSA-5 or RSA-10 injection servos or have not had maint done on that engine since Aug 2006. A one time inspection to confirm the part numbers and log inspection, then write it off as N/A by the A&P. I did not see any reference to a permanent fix to do away with the 50hr repetitive inspection. For those that need it. BT "Robert M. Gary" wrote in message ... AD 2008-06-51 prohibits injected (mostly Lycoming) aircraft owners from changing their own oil (really makes the plane unairworthy after an oil change until you get an A&P sign off). Talking to AOPA about this I really don't get the impression that they think this is very important. I would encourage everyone to send a quick email to AOPA and let them know that the FAA needs to find another way to do this AD other than restricting oil changes. -Robert |
On Apr 1, 6:02*pm, "BT" wrote:
if you do not have RSA-5 or RSA-10 injection servos or have not had maint done on that engine since Aug 2006. A one time inspection to confirm the part numbers and log inspection, then write it off as N/A by the A&P. Yea, as in remove the service (4 hrs labor) send it to a fuel shop then reinstall it (4 hours labor). Removing the nut by anyone other than a fuel service shop voids the warranty and disrupts the correct flow. I did not see any reference to a permanent fix to do away with the 50hr repetitive inspection. For those that need it. No one will do this every 50 hours. Since you have to do it oil change it will already be done. Now you have to pay an A&P to do your oil change (or just pay him the 1/2 hr labor to do the 5 min AD and have him sit the other 25 minutes on your dime). -Robert |
A week ago I became a new co-owner | bdl | Owning | 16 | April 9th 05 12:37 AM |
172RG are any injected or are all carburated? | Daniel L. Lieberman | Piloting | 2 | September 30th 04 02:06 AM |
Corporation or LLC as Owner? | robin | Owning | 1 | March 26th 04 01:05 AM |
Fuel-Injected Continental O-200 | Calvin R. Walker | Home Built | 1 | November 22nd 03 02:50 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
