injected planes, no more owner oil changes, contact AOPA
Old April 2nd 08, 02:43 AM posted to rec.aviation.piloting
Jim Burns
Default injected planes, no more owner oil changes, contact AOPA
It's a rather fluid situation. Precision's latest revision to PRS-107 is
dated 3/21/08
http://www.precisionairmotive.com/Pu...107%20Rev2.pdf
and lists terminating action for their company SB by installing a new
2577258 gasket via their instructions and stamping the hex plug with a
letter "G". In a round-about way this action terminates the AD because when
completed, the servo will no longer contain the 365533 gasket to which the
AD refers.
"BT" wrote in message
if you do not have RSA-5 or RSA-10 injection servos or have not had maint
done on that engine since Aug 2006.
A one time inspection to confirm the part numbers and log inspection, then
write it off as N/A by the A&P.
I did not see any reference to a permanent fix to do away with the 50hr
repetitive inspection. For those that need it.
BT
AD 2008-06-51 prohibits injected (mostly Lycoming) aircraft owners
from changing their own oil (really makes the plane unairworthy after
an oil change until you get an A&P sign off).
Talking to AOPA about this I really don't get the impression that they
think this is very important. I would encourage everyone to send a
quick email to AOPA and let them know that the FAA needs to find
another way to do this AD other than restricting oil changes.
-Robert
Old April 2nd 08, 04:54 AM posted to rec.aviation.piloting
BT
true.. that is a "round about way".. I would expect that there would be a
revised AD forthcoming from the good ole FAA to recognize the "AD
Terminating" procedure.
BT
"Jim Burns" wrote in message
dated 3/21/08
when completed, the servo will no longer contain the 365533 gasket to
which the AD refers.
then write it off as N/A by the A&P.
BT
-Robert
A week ago I became a new co-owner bdl Owning 16 April 9th 05 12:37 AM
172RG are any injected or are all carburated? Daniel L. Lieberman Piloting 2 September 30th 04 02:06 AM
Corporation or LLC as Owner? robin Owning 1 March 26th 04 01:05 AM
Fuel-Injected Continental O-200 Calvin R. Walker Home Built 1 November 22nd 03 02:50 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
