On Sun, 16 Nov 2003 16:37:15 -0500, in rec.aviation.military Cub Driver
wrote: Early piston aircraft had a lot of torque generated by the engine. In a wave-off situation, the sharp increase in power would roll the aircraft slightly to port. Combined with pulling back on the stick to gain altitude, this would result in a climbing left turn. Having an island in the way when doing this could ruin your If so, then British carriers would have the island to port. Do they? Why would they? Their aircraft engines rotated in the same direction as the American's, thus generating the same port-biased torque. |
Why would they? Their aircraft engines rotated in the same direction as the American's, thus generating the same port-biased torque. No, British aircraft engines turned the other way. Still do, I believe. They famously emasculated the Lightning by burdening it with two left-turning engines. all the best -- Dan Ford email: (put CUB in subject line) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"Cub Driver" wrote in message news ![]() Why would they? Their aircraft engines rotated in the same direction as the American's, thus generating the same port-biased torque. No, British aircraft engines turned the other way. Still do, I believe. They famously emasculated the Lightning by burdening it with two left-turning engines. The problem with the version of the P-38 supplied to the RAF was the inferior supercharger supplied on the export version not the fact that it had 2 engines turning the same way. Keith |
Why would they? Their aircraft engines rotated in the same direction as the American's, thus generating the same port-biased torque. No, British aircraft engines turned the other way. Still do, I believe. They famously emasculated the Lightning by burdening it with two left-turning engines. The problem with the version of the P-38 supplied to the RAF was the inferior supercharger supplied on the export version not the fact that it had 2 engines turning the same way. The supercharger supplied (actually just a low pressure blower) was what was specified by the British, and what was a standard feature on the Allison. The Allison was intended to use a separate turbosupercharger for high altitude work, but the British didn't feel that high altitude performance was necessary at the time they wrote the specification. In addition, turbosuperchargers were not a high-volume production item, so including them might have delayed deliver. By the time the aircraft were delivered, however, the RAF had learned through experience that high altitude performance was indeed important. The poor handling of the aircraft, however, was indeed due to the fitting of same-direction rotating engine and propeller combinations, which was done to minimize the logistics tail, by using an engine which was already in use by the RAF (in export P-40s, IIRC). This engine also developed less horsepower, even at sea level, than did the V-1710F series engine used in all P-38s since the XP. A final possible reason for the British refusing to accept the Lightning (and especially the follow-on Lightning II, with turbosupercharging and counter-rotating V-1710F engines) was due to the method under which they were ordered. The original order for these aircraft was prior to lend-lease coming into being, and the British would have had to pay cash for them, unlike other aircraft ordered later. Given the changed requirements making the Lightning I less useful than expected, and the availability of other aircraft under lend-lease, buying the aircraft probably didn't seem a very economical way to spend their treasure. The Lightning II, if not for the cash requirement, probably would have been very useful to the British. Mike |
"Keith Willshaw" wrote in
: "Cub Driver" wrote in message news
They famously emasculated the Lightning by burdening it with two left-turning engines. The problem with the version of the P-38 supplied to the RAF was the inferior supercharger supplied on the export version not the fact that it had 2 engines turning the same way. While this is true, the previos Dan was correct. The P-38 had significant tail flutter problems with "inword" rotateing engines. This was fixed on American P-38's by having the engines rotate "outword" in opposite directions, however the British version had two engines which in addition to lacking the General Electric B-5 turbosuperchargers also rotated in the same direction. This lead to one of the engines generating the same effect that had been a problem with the P-38 prototypes. |
The problem with the version of the P-38 supplied to the RAF was the inferior supercharger supplied on the export version not the fact that it had 2 engines turning the same way. How would you like to have to turn a fighter to the left to avoid a Japanese fighter when you have two 1200-hp Allisons pouring on the torque to the right? This was an all-but-impossible task. I think your grasp of the subject leaves something to be desired, Keith. British engines did turn anti-clockwise as seen from the cockpit; the export Lightning was all but useless as a result of two engines turning the same way; and carrier islands to starboard had little or nothing to do with engine rotation. all the best -- Dan Ford email: (put CUB in subject line) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"Cub Driver" wrote in message ... The problem with the version of the P-38 supplied to the RAF was the inferior supercharger supplied on the export version not the fact that it had 2 engines turning the same way. How would you like to have to turn a fighter to the left to avoid a Japanese fighter when you have two 1200-hp Allisons pouring on the torque to the right? This was an all-but-impossible task. You couldnt out turn a Japanes fighter in any Lightning and the RAF never tried to do so. I think your grasp of the subject leaves something to be desired, Keith. British engines did turn anti-clockwise as seen from the cockpit; I never said otherwise. the export Lightning was all but useless as a result of two engines turning the same way; That was not the reason the RAF rejected them however, they did so because of the extremely poor performance achievable with the engines supplied. I am aware that was what the British purchasing commission ordered but the factory guaranteed a minimum speed of 400 mph at 16,900 ft with the original engines. As the aircraft as delievered could barely achieve 350 mph it was rejected by the RAF. The USAAF took over the 140 aircraft remaining and even after fitting handed engines relegated them to a training role. and carrier islands to starboard had little or nothing to do with engine rotation. They did in 1918 when the Island location was fixed on the 1st generation carriers and of course P-38's didnt operate from carriers so their situation is irrelevant. Keith |
On Mon, 17 Nov 2003 22:22:08 -0000, "Keith Willshaw"
wrote: You couldnt out turn a Japanes fighter in any Lightning Before I put you in the kill file, Keith, let me remind you that AmericanLightning pilots did in fact out-maneuver Japanese fighters by chopping one engine and firewalling the other. Now: plonk! all the best -- Dan Ford email: (put CUB in subject line) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"Cub Driver" wrote in message ... On Mon, 17 Nov 2003 22:22:08 -0000, "Keith Willshaw" wrote: You couldnt out turn a Japanes fighter in any Lightning Before I put you in the kill file, Keith, let me remind you that AmericanLightning pilots did in fact out-maneuver Japanese fighters by chopping one engine and firewalling the other. Now: plonk! How sad Keith |
"Cub Driver" wrote in message ... On Mon, 17 Nov 2003 22:22:08 -0000, "Keith Willshaw" wrote: You couldnt out turn a Japanes fighter in any Lightning Before I put you in the kill file, Keith, let me remind you that AmericanLightning pilots did in fact out-maneuver Japanese fighters by chopping one engine and firewalling the other. Now: plonk! Dan, you seem to have suffered a sever attitude change lately. Something wrong? |
| Thread Tools | |
| Display Modes | |
| B-29s & P-51s Strike Japan plus "Carrier Franklin" at Zeno's Drive-In | zeno | Home Built | 1 | October 5th 04 12:19 AM |
| B-29s & P-51s Strike Japan plus "Carrier Franklin" at Zeno's Drive-In | zeno | Instrument Flight Rules | 0 | October 4th 04 06:32 PM |
| Can the F-14 carry six AIM-54s and land on carrier? | Matthew G. Saroff | Military Aviation | 1 | October 29th 03 09:14 PM |
| C-130 Hercules on a carrier - possible ?? | Jan Gelbrich | Military Aviation | 10 | September 21st 03 05:47 PM |
| launching V-1s from an aircraft carrier | Gordon | Military Aviation | 34 | July 30th 03 12:14 AM |
