Seraphim wrote:
"Tarver Engineering" wrote in news ![]() "William Hughes" wrote in message ... On Mon, 17 Nov 2003 03:22:34 GMT, in rec.aviation.military "Gord Beaman" ) wrote: William Hughes wrote: Early piston aircraft had a lot of torque generated by the engine. In a wave-off situation, the sharp increase in power would roll the aircraft slightly to port. Combined with pulling back on the stick to gain altitude, this would result in a climbing left turn. Having an island in the way when doing this could ruin your whole day. Hence, the island was placed on the other side of the filght deck. So what does one do in an a/c which has an engine turning the opposite way?... And which aircraft would that be? AFAIK, all aircraft engines rotated the same way - clockwise from the pilot's point-of-view. At least on single-engine birds; some twins may have had counter-rotating props, but I don't think they operated from carrier decks all that much. What, like a P-3? The P-3 doesn't have counter-rotating props, and AFAIK operates from land bases. So your point about the P-3 was? Come on, it's the Tarver bot. Coherence is unexpected, much less a point. -Marc -- Marc Reeve actual email address after removal of 4s & spaces is c4m4r4a4m4a4n a4t c4r4u4z4i4o d4o4t c4o4m |
| Thread Tools | |
| Display Modes | |
| B-29s & P-51s Strike Japan plus "Carrier Franklin" at Zeno's Drive-In | zeno | Home Built | 1 | October 5th 04 12:19 AM |
| B-29s & P-51s Strike Japan plus "Carrier Franklin" at Zeno's Drive-In | zeno | Instrument Flight Rules | 0 | October 4th 04 06:32 PM |
| Can the F-14 carry six AIM-54s and land on carrier? | Matthew G. Saroff | Military Aviation | 1 | October 29th 03 09:14 PM |
| C-130 Hercules on a carrier - possible ?? | Jan Gelbrich | Military Aviation | 10 | September 21st 03 05:47 PM |
| launching V-1s from an aircraft carrier | Gordon | Military Aviation | 34 | July 30th 03 12:14 AM |
