![]() "Eunometic" wrote in message ... I note that the USN Grumman EA-6B is being used to create a jammed space around ground US patrols in Iraq. The jamming prevents the detonation of improvised explosive devices. Presumably highly directional electronically shaped antenna create temporal grace around the patrol. The British did something similar in Northern Ireland. The IRA switched to command detonated devices. After the British started looking for the wires after the bang they moved on to more sophisticated radio equipment such as that found on the dead IRA people shot in Gibraltar which required a series of thumb wheels to be set to the correct number to transmit the firing signal. The stuff is 'Radio Amateur' technology and can be picked up in any major city. It is reasonable to assume that the Iraqi bad guys have access to all this sort of thing at that technical escalation will happen in exactly the same way... -- William Black I've seen things you people wouldn't believe. Barbeques on fire by the chalets past the castle headland I watched the gift shops glitter in the darkness off the Newborough gate All these moments will be lost in time, like icecream on the beach Time for tea. .. |
![]() "Juergen Nieveler" wrote in message . .. "William Black" wrote: It is reasonable to assume that the Iraqi bad guys have access to all this sort of thing at that technical escalation will happen in exactly the same way... Or they'll stick to line-of-sight stuff like IR or lasers, or they'll switch to using mobile phones and planting the bombs in areas where people will complain abou too frequent mobile phone outages. Or they'll shift to using something that detects a jam of the radio- command-link and then activates a motion sensor... after all, jamming means "the patrol is coming, get ready". The more sophisticated jammers only switch on when a signal is detected, hopefully quickly enough to stop a detonation. Jeff |
![]() "Jeff" wrote in message . com... The more sophisticated jammers only switch on when a signal is detected, hopefully quickly enough to stop a detonation. They'll make electronic garage door openers, radio type car alarm tags and a huge assortment of other things entertaining to use... -- William Black I've seen things you people wouldn't believe. Barbeques on fire by the chalets past the castle headland I watched the gift shops glitter in the darkness off the Newborough gate All these moments will be lost in time, like icecream on the beach Time for tea. |
In message , William Black
writes "Jeff" wrote in message .com... The more sophisticated jammers only switch on when a signal is detected, hopefully quickly enough to stop a detonation. They'll make electronic garage door openers, radio type car alarm tags and a huge assortment of other things entertaining to use... You'll just have to wait for the HMMWVs to drive past before your car will unlock, your garage door open or your cordless phone ring. It's counterproductive to shut down a neighbourhood, you just need to prevent detonations within lethal distance. -- The nation that makes a great distinction between its scholars and its warriors, will have its thinking done by cowards and its fighting done by fools. -Thucydides pauldotjdotadam[at]googlemail{dot}.com |
![]() "Paul J. Adam" wrote in message ... In message , William Black writes "Jeff" wrote in message e.com... The more sophisticated jammers only switch on when a signal is detected, hopefully quickly enough to stop a detonation. They'll make electronic garage door openers, radio type car alarm tags and a huge assortment of other things entertaining to use... You'll just have to wait for the HMMWVs to drive past before your car will unlock, your garage door open or your cordless phone ring. It's counterproductive to shut down a neighbourhood, you just need to prevent detonations within lethal distance. It also gives a nice easy system to tell the snipers that they're coming. Sound of telephone ringing, a voice says "They are at point Mustapha" (or "Aunty Fatima says your washing is ready" if they're being really paranoid about things) The guy knows they'll be around the corner any minute and redies his .50 calibre sniper rifle... -- William Black I've seen things you people wouldn't believe. Barbeques on fire by the chalets past the castle headland I watched the gift shops glitter in the darkness off the Newborough gate All these moments will be lost in time, like icecream on the beach Time for tea. |
writes "Paul J. Adam" wrote in message ... You'll just have to wait for the HMMWVs to drive past before your car will unlock, your garage door open or your cordless phone ring. It's counterproductive to shut down a neighbourhood, you just need to prevent detonations within lethal distance. It also gives a nice easy system to tell the snipers that they're coming. Sound of telephone ringing, a voice says "They are at point Mustapha" (or "Aunty Fatima says your washing is ready" if they're being really paranoid about things) The guy knows they'll be around the corner any minute and redies his .50 calibre sniper rifle... You need less than that. Not much help for the snipers... -- The nation that makes a great distinction between its scholars and its warriors, will have its thinking done by cowards and its fighting done by fools. -Thucydides pauldotjdotadam[at]googlemail{dot}.com |
![]() "Juergen Nieveler" wrote in message . .. BTW, do those jammers send white noise, or are they smart enough to fake a signal? Say, I build a small detonator from RC car parts, and it depends on the transmitter sending "left, right, left..." every 30 seconds, with a timer starting on every signal, counting down until the opposite side timer is started. With a white noise jammer, no signal gets through anymore, 30 seconds later you get *bang*... All this stuff came out at the inquest into the people shot in Gib. The claim was made that the security forces should be able to jam the signal. They explained in some detail why they couldn't. It seems that the IRA people used a Trio Radio Amateur 144 MHz pocket radio system that requires a sequence of reversals transmitted by VHF FSK to trigger an open channel. The sequence is set by a row of five thumbwheels, each of ten digits. So you've got a million, minus one, possible combinations. I leave as an exercise for the reader the calculation of the linear recursive sequence necessary to trigger the thing prematurely... This, of course, assumes the security forces know the radio frequency and the FSK baud rate and frequency shift. White noise generators don't work once the bad guys get up to 'radio amateur' levels of knowledge of triggering technology... -- William Black I've seen things you people wouldn't believe. Barbeques on fire by the chalets past the castle headland I watched the gift shops glitter in the darkness off the Newborough gate All these moments will be lost in time, like icecream on the beach Time for tea. |
On Apr 8, 7:41*am, "William Black"
wrote: "Juergen Nieveler" wrote in message . .. BTW, do those jammers send white noise, or are they smart enough to fake a signal? Say, I build a small detonator from RC car parts, and it depends on the transmitter sending "left, right, left..." every 30 seconds, with a timer starting on every signal, counting down until the opposite side timer is started. With a white noise jammer, no signal gets through anymore, 30 seconds later you get *bang*... All this stuff came out at the inquest into the people shot in Gib. The claim was made that the security forces should be able to jam the signal. They explained in some detail why they couldn't. It seems that the IRA people used a Trio Radio Amateur 144 MHz pocket radio system that requires a sequence of reversals transmitted by VHF FSK to trigger an open channel. *The sequence is set by a row of five thumbwheels, each of ten digits. So you've got a million, minus one, possible combinations. I leave as an exercise for the reader the calculation of the linear recursive sequence necessary to trigger the thing prematurely... This, *of course, assumes the security forces know the radio frequency and the FSK baud rate and frequency shift. White noise generators don't work once the bad guys get up to 'radio amateur' levels of knowledge of triggering technology... Gibraltar was 20 years ago. They've learned a lot since then and deaths from IED's have dropped dramatically since the USN's EW experts have trained the soldiers to use the equipment correctly. "They called themselves "sand sailors," and they did their job well by reducing IED fatalities at their bases. Monthly U.S. troop deaths from IEDs have dropped since reaching a high of 90 in May to 17 last month, in part because of their efforts, the military said in awarding Bronze Stars to Dye and others." http://www.boston.com/news/nation/ar...ead_ied_fight/ BB I guess everybody has some mountain to climb. It's just fate whether you live in Kansas or Tibet... |
![]() "BlackBeard" wrote in message ... On Apr 8, 7:41 am, "William Black" wrote: "Juergen Nieveler" wrote in message . .. BTW, do those jammers send white noise, or are they smart enough to fake a signal? Say, I build a small detonator from RC car parts, and it depends on the transmitter sending "left, right, left..." every 30 seconds, with a timer starting on every signal, counting down until the opposite side timer is started. With a white noise jammer, no signal gets through anymore, 30 seconds later you get *bang*... All this stuff came out at the inquest into the people shot in Gib. The claim was made that the security forces should be able to jam the signal. They explained in some detail why they couldn't. It seems that the IRA people used a Trio Radio Amateur 144 MHz pocket radio system that requires a sequence of reversals transmitted by VHF FSK to trigger an open channel. The sequence is set by a row of five thumbwheels, each of ten digits. So you've got a million, minus one, possible combinations. I leave as an exercise for the reader the calculation of the linear recursive sequence necessary to trigger the thing prematurely... This, of course, assumes the security forces know the radio frequency and the FSK baud rate and frequency shift. White noise generators don't work once the bad guys get up to 'radio amateur' levels of knowledge of triggering technology... Gibraltar was 20 years ago. They've learned a lot since then and deaths from IED's have dropped dramatically since the USN's EW experts have trained the soldiers to use the equipment correctly. "They called themselves "sand sailors," and they did their job well by reducing IED fatalities at their bases. Monthly U.S. troop deaths from IEDs have dropped since reaching a high of 90 in May to 17 last month, in part because of their efforts, the military said in awarding Bronze Stars to Dye and others." ---------------------------- Almost certainly the big drop was caused by training people how to spot the bloody things. Messing with the trigger mechanism is very much a secondary thing, the best solution is not to park next door to one... -- William Black I've seen things you people wouldn't believe. Barbeques on fire by the chalets past the castle headland I watched the gift shops glitter in the darkness off the Newborough gate All these moments will be lost in time, like icecream on the beach Time for tea. |
On Apr 8, 9:15*am, "William Black"
wrote: Almost certainly the big drop was caused by training people how to spot the bloody things. Not according to the article. "Thomas said the technology works by "basically providing a protective bubble around a vehicle," jamming incoming signals and blocking the remote detonation of bombs." BB I guess everybody has some mountain to climb. It's just fate whether you live in Kansas or Tibet... |
CG(X) And The Future Of Naval Warfare. | Mike[_1_] | Naval Aviation | 0 | December 14th 07 05:28 PM |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
GPS - losing signal | Hilton | Piloting | 6 | October 23rd 05 07:18 PM |
Fading Rocker Switches | O. Sami Saydjari | Owning | 2 | February 16th 04 03:54 PM |
asymetric warfare | phil hunt | Military Aviation | 505 | January 23rd 04 12:31 AM |
