Fading Signal: The Neglect of Electronic Warfare.
Old April 8th 08, 04:59 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
Default Fading Signal: The Neglect of Electronic Warfare.
On Apr 8, 7:41*am, "William Black"
"Juergen Nieveler" wrote in message
BTW, do those jammers send white noise, or are they smart enough to
fake a signal? Say, I build a small detonator from RC car parts, and it
depends on the transmitter sending "left, right, left..." every 30
seconds, with a timer starting on every signal, counting down until the
opposite side timer is started.
With a white noise jammer, no signal gets through anymore, 30 seconds
later you get *bang*...
All this stuff came out at the inquest into the people shot in Gib. The
claim was made that the security forces should be able to jam the signal.
They explained in some detail why they couldn't.
It seems that the IRA people used a Trio Radio Amateur 144 MHz pocket radio
system that requires a sequence of reversals transmitted by VHF FSK to
trigger an open channel. *The sequence is set by a row of five thumbwheels,
each of ten digits.
So you've got a million, minus one, possible combinations.
I leave as an exercise for the reader the calculation of the linear
recursive sequence necessary to trigger the thing prematurely...
This, *of course, assumes the security forces know the radio frequency and
the FSK baud rate and frequency shift.
White noise generators don't work once the bad guys get up to 'radio
amateur' levels of knowledge of triggering technology...
Gibraltar was 20 years ago. They've learned a lot since then and
deaths from IED's have dropped dramatically since the USN's EW experts
have trained the soldiers to use the equipment correctly.
"They called themselves "sand sailors," and they did their job well by
reducing IED fatalities at their bases. Monthly U.S. troop deaths from
IEDs have dropped since reaching a high of 90 in May to 17 last month,
in part because of their efforts, the military said in awarding Bronze
Stars to Dye and others."
http://www.boston.com/news/nation/ar...ead_ied_fight/
BB
I guess everybody has some mountain to climb.
It's just fate whether you live in Kansas or Tibet...
Old April 8th 08, 05:15 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
"BlackBeard" wrote in message
On Apr 8, 7:41 am, "William Black"
radio
trigger an open channel. The sequence is set by a row of five thumbwheels,
each of ten digits.
This, of course, assumes the security forces know the radio frequency and
Almost certainly the big drop was caused by training people how to spot the
bloody things.
Messing with the trigger mechanism is very much a secondary thing, the best
solution is not to park next door to one...
William Black
I've seen things you people wouldn't believe.
Barbeques on fire by the chalets past the castle headland
I watched the gift shops glitter in the darkness off the Newborough gate
All these moments will be lost in time, like icecream on the beach
Time for tea.
Old April 9th 08, 06:52 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
On Apr 8, 9:15*am, "William Black"
bloody things.
Not according to the article.
"Thomas said the technology works by "basically providing a protective
bubble around a vehicle," jamming incoming signals and blocking the
remote detonation of bombs."
BB
Old April 9th 08, 01:09 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
On Apr 8, 9:15 am, "William Black"
bloody things.
If that's the case then expect the lull to last for only a couple of months,
until the bad guys get hold of a technology that works.
William Black
Time for tea.
Old April 9th 08, 04:59 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Paul J. Adam
In message , William Black
writes
Whereupon the ECM gear will be modified to suit. The kit being used in
2005 is pretty much obsolete now... the WIS guys don't sit on their
laurels either.
The nation that makes a great distinction between its scholars and its
warriors, will have its thinking done by cowards and its fighting done
by fools.
-Thucydides
pauldotjdotadam[at]googlemail{dot}.com
Old April 9th 08, 05:25 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
"Paul J. Adam" wrote in message
writes
months,
laurels either.
True.
But the countermeasures people have to react. It's not something you can be
proactive about...
William Black
Time for tea.
Old April 10th 08, 01:12 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eunometic
On Apr 10, 2:25 am, "William Black"
"Paul J. Adam" wrote in . ..
writes
months,
laurels either.
True.
I really doubt any new equipment will be needed. There might be some
reprogramming required but an aircraft like the EA-6B
could be configured, in flight, to listen to hundreds of frequencies,
analyze dozens of modulation schemes or just plain triangulate an
emitter on the basis of energy as it flies around.
There is going to be no problem jamming a cellphone in a tight radius
around the troops its protecting and no problem jamming a broad range
of frequencies commonly used. If there is an emitter within a radius
around the troops its going to be recorded for later analysis and that
particular remote detonation system is likely to be neutralized.
It's not perfect, but it will cut down casualties.
Old April 8th 08, 05:32 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jeff[_11_]
But that is not a system that you would want to use for real, any kind of
failure or signal interuption would cause a detonation.
They certainaly could jam the signal, what they could not do eaisly is
detonate the device when they wished.
radio
each of ten digits.
White noise will *allways* work as long as you can get a loud enough signal,
its just a matter of power and range.
However, the more intelligent jammers use other signal patterns to jam known
types of transmission, and "look through" their own transmissions to analyze
the target signal.
Jeff
Old April 8th 08, 05:42 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jeff[_11_]
radio
thumbwheels,
each of ten digits.
As a matter of interest the bomb intended for Gibraltar was NOT radio
controlled, it was a timer device that was found in the car (still in
Spain).
The SAS did not know this, however, and were acting on what had become
common practise for the IRA in N Ireland from the mid 70's, which was to use
radio control.
Jeff
Old April 9th 08, 02:54 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Andrew Swallow[_2_]
[snip]
Providing they kill someone they do not care. Terrorist organisations
have repeatedly show that they consider local civilians to be targets.
Western soldiers are just higher valuse targets.
Andrew Swallow
CG(X) And The Future Of Naval Warfare. Mike[_1_] Naval Aviation 0 December 14th 07 05:28 PM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
GPS - losing signal Hilton Piloting 6 October 23rd 05 07:18 PM
Fading Rocker Switches O. Sami Saydjari Owning 2 February 16th 04 03:54 PM
asymetric warfare phil hunt Military Aviation 505 January 23rd 04 12:31 AM
