Fading Signal: The Neglect of Electronic Warfare.
Old April 9th 08, 02:54 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Andrew Swallow[_2_]
Default Fading Signal: The Neglect of Electronic Warfare.
Jeff wrote:
BTW, do those jammers send white noise, or are they smart enough to
fake a signal? Say, I build a small detonator from RC car parts, and it
depends on the transmitter sending "left, right, left..." every 30
seconds, with a timer starting on every signal, counting down until the
opposite side timer is started.
With a white noise jammer, no signal gets through anymore, 30 seconds
later you get *bang*...
But that is not a system that you would want to use for real, any kind of
failure or signal interuption would cause a detonation.
[snip]
Providing they kill someone they do not care. Terrorist organisations
have repeatedly show that they consider local civilians to be targets.
Western soldiers are just higher valuse targets.
Andrew Swallow
Old April 9th 08, 05:39 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
beausabre
[snip]
Andrew Swallow
SNIP
Actually, a paper I read points out to the fanatic of any stripe, it's
the act, not the result that's important. If I get killed before I can
kill the enemy, that's unfortunate, but I 'm still a hero/martyr since
I died in the attempt.
Old April 9th 08, 05:44 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
[snip]
Andrew Swallow
SNIP
could you? would you?
CG(X) And The Future Of Naval Warfare. Mike[_1_] Naval Aviation 0 December 14th 07 05:28 PM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
GPS - losing signal Hilton Piloting 6 October 23rd 05 07:18 PM
Fading Rocker Switches O. Sami Saydjari Owning 2 February 16th 04 03:54 PM
asymetric warfare phil hunt Military Aviation 505 January 23rd 04 12:31 AM
