How much longer?
Old April 9th 08, 05:25 PM posted to rec.aviation.piloting
Jay Honeck[_2_]
Default How much longer?
I will admit it is a bit out of the ordinary but I brought it up to show
a little of what is possible.
I think it's great (we, too, have a manual hangar door), and wish more
places would do this.
I'm curious how they are getting 110 volts for your outlets. I thought that
was unattainable with current (sorry!) technology.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 9th 08, 06:59 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Jay Honeck" wrote in
news:M56Lj.112941$yE1.87006@attbi_s21:
show a little of what is possible.
thought that was unattainable with current (sorry!) technology.
That's because you're an idiot.
Bertie
Old April 9th 08, 07:01 PM posted to rec.aviation.piloting
Martin Hotze[_2_]
*hihi*
230V is doable. without problems. *doohhhh*
#m
Old April 9th 08, 07:15 PM posted to rec.aviation.piloting
From what, solar cells?
A big ass inverter.
Jim Pennino
Remove .spam.sux to reply.
Old April 10th 08, 11:09 AM posted to rec.aviation.piloting
Dylan Smith
It's been attainable to get 110vac from DC probably for the best part of
a century or more. The magic device is called an inverter.
I have a little solar photovoltaic panel on my shed roof for powering the
electric stuff in the garden, like lighting, pond pump etc. It currently
has 3 outlets - 12 volt DC, 6 volt DC (a DC-DC converter I built myself
for charging 6 volt lead acid batteries, for use with my bike), and 240
volts AC off an inverter.
Technology to make AC from DC, DC from AC, high voltage DC from low
voltage DC and all the combinations has existed for decades. It's very
basic stuff. I've made 1000 volts DC from 12 volts DC. It's not even
hard to do.
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
Old April 11th 08, 12:35 AM posted to rec.aviation.piloting
Matt Whiting
But how useful is 10 microA at 240V? :-)
Matt
Old April 11th 08, 06:38 AM posted to rec.aviation.piloting
Morgans[_2_]
hard to do.
Right, not hard; just expensive and inefficient as hell, and in some cases,
almost unusable.
Most of the home level inverters are what they call "modified sine wave"
inverters. All that says is that the innards of the inverter cut the power
on and off rapidly, so if you read the voltage, it rises and falls in a
choppy square notched "sort-a-looks-like-a-sine-wave" if you squint real
hard.
The more sophisticated ones are more than three times the cost, which makes
them very expensive.
The modified sine wave converters will power most stuff without permanent
damage, but don't try to use your DeWalt cordless drill battery charger.
Anything that reads like a high voltage until you put the load on it will
fry, and it says so in the inverter's instructions, if you take the time to
read the fine print. Don't ask me how I know that.
They also put out a good bit of heat, and guess what. That heat is power
going out the window, in a big efficiency loss. Oh, and don't try to power
a refrigerator, or AC, unless you really want to see a big time efficiency
hit. They don't work very well, at all.
So, the long and short is that if you are using battery or Solar DC, you had
better be using as many DC units as at all possible, or your batteries will
not last very darn long.
I'm not against Solar, but everyone needs to know the limitations of doing
so. You need a specially designed system using mostly straight DC, or lots
of money, if you expect to get much useful power out of the system.
Jim in NC
Jim in NC
Old April 11th 08, 05:25 PM posted to rec.aviation.piloting
hard to do.
almost unusable.
hard.
You do realize that most computer rooms and some entire buildings
have battery backup and huge inverters for power failure protection?
These are true sine wave inverters, are quite efficient, regulated, and
phase synchronized to the grid so switchover is transparent.
However, you are correct about the cheap Chinese junk you get at places
like Pep Boys; they put out crap wave forms, are inefficient, and
seldom have regulated outputs.
And you are correct about the cost; decent inverters cost a lot more
than the junk.
There is no potential technology to lower the cost of such inverters
other than economies of scale, and the installation and maintenance
cost of such inverters is usually ignored by solar energy proponents.
Jim Pennino
My 302 and PDA are no longer on speaking terms Dixie Sierra Soaring 4 September 10th 07 05:16 PM
Some IFR GPS's no longer useable kevmor Instrument Flight Rules 2 May 28th 07 02:27 AM
Jepp no longer in the GA business...? John Harper Instrument Flight Rules 30 June 17th 04 10:49 PM
Some airmen facing longer deployments Otis Willie Military Aviation 0 January 16th 04 08:34 PM
