Fading Signal: The Neglect of Electronic Warfare.
Old April 9th 08, 05:25 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
Default Fading Signal: The Neglect of Electronic Warfare.
"Paul J. Adam" wrote in message
In message , William Black
writes
"BlackBeard" wrote in message
Not according to the article.
"Thomas said the technology works by "basically providing a protective
bubble around a vehicle," jamming incoming signals and blocking the
remote detonation of bombs."
If that's the case then expect the lull to last for only a couple of
months,
until the bad guys get hold of a technology that works.
Whereupon the ECM gear will be modified to suit. The kit being used in
2005 is pretty much obsolete now... the WIS guys don't sit on their
laurels either.
True.
But the countermeasures people have to react. It's not something you can be
proactive about...
William Black
I've seen things you people wouldn't believe.
Barbeques on fire by the chalets past the castle headland
I watched the gift shops glitter in the darkness off the Newborough gate
All these moments will be lost in time, like icecream on the beach
Time for tea.
Old April 10th 08, 01:12 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eunometic
On Apr 10, 2:25 am, "William Black"
"Paul J. Adam" wrote in . ..
writes
months,
laurels either.
True.
I really doubt any new equipment will be needed. There might be some
reprogramming required but an aircraft like the EA-6B
could be configured, in flight, to listen to hundreds of frequencies,
analyze dozens of modulation schemes or just plain triangulate an
emitter on the basis of energy as it flies around.
There is going to be no problem jamming a cellphone in a tight radius
around the troops its protecting and no problem jamming a broad range
of frequencies commonly used. If there is an emitter within a radius
around the troops its going to be recorded for later analysis and that
particular remote detonation system is likely to be neutralized.
It's not perfect, but it will cut down casualties.
Old April 10th 08, 07:24 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
"Eunometic" wrote in message
be
You assume they'll stick to radio.
Infra red lasers, as an example, are freely available and simple to use.
So, come to think of it, is the Internet...
These people are not stupid.
William Black
Time for tea.
Old April 10th 08, 07:38 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
On Apr 10, 2:24 pm, "William Black"
be
William Black
Time for tea.
Motion detectors?
Old April 11th 08, 09:22 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Paul J. Adam
In message
Jack Linthicum writes
Motion detectors?
In use for a decade or two. Started out with Lebanese Hezbollah,
proliferated to Iraq in 2005 or so.
The nation that makes a great distinction between its scholars and its
warriors, will have its thinking done by cowards and its fighting done
by fools.
-Thucydides
pauldotjdotadam[at]googlemail{dot}.com
Old April 12th 08, 05:37 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Raytheon Wins Contract For Radar-Jamming Variant Of It's Miniature Air
Launched Decoy
See:
http://www.spacewar.com/reports/Rayt...Decoy_999.html
What advantages (if any) do expendables like this have
over regular jamming aircraft like the EA-6B?
Old April 12th 08, 02:47 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Dean A. Markley
Launched Decoy
See:
Standoff ability for one.
Dean
Old April 13th 08, 01:28 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eunometic
On Apr 11, 4:24 am, "William Black"
be
Even with an optical or acoustic link (diode laser etc) is used it
should be relatively easy to jam or predetonate
electronics itself rather than the link. I've seen airport radar
false trigger photo prox switches.
Vietnam era B-52's had a microwave system to jam infrared homing
missiles by beaming into their seeker.
T
Old April 13th 08, 11:27 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
It depends...
If you have a random digital sequence used as a trigger code they'll have to
cycle through the possibilities at the correct frequency and data rate.
A 'long cycle LRS' takes the time it takes...
William Black
Time for tea.
CG(X) And The Future Of Naval Warfare. Mike[_1_] Naval Aviation 0 December 14th 07 05:28 PM
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
GPS - losing signal Hilton Piloting 6 October 23rd 05 07:18 PM
Fading Rocker Switches O. Sami Saydjari Owning 2 February 16th 04 03:54 PM
asymetric warfare phil hunt Military Aviation 505 January 23rd 04 12:31 AM
