On Apr 9, 3:05 pm, wrote:
cavedweller wrote: The engineering problem for wide spread use is hydrogen embrittlement. For instance? For instance the only existing distribution plumbing that will handle hydrogen is on liquid hydrogen trucks; you can't run it down existing gas pipe lines. Hmmmm. I see that I should have asked rather "Of what?" (relative to hydrogen embrittlement) |
cavedweller wrote:
On Apr 9, 3:05 pm, wrote: cavedweller wrote: The engineering problem for wide spread use is hydrogen embrittlement. For instance? For instance the only existing distribution plumbing that will handle hydrogen is on liquid hydrogen trucks; you can't run it down existing gas pipe lines. Hmmmm. I see that I should have asked rather "Of what?" (relative to hydrogen embrittlement) If you want to use hydrogen on a large scale, you have to have some way to distribute it such as is done with natural gas. Huge fleets of liquid hydrogen tankers isn't going to cut it. Because of hydrogen embrittlement, any such distribution system will have to be built starting from zero as no existing system can handle hydrogen and building such a system will be both an engineering and economic challenge. -- Jim Pennino Remove .spam.sux to reply. |
On Apr 9, 5:15 pm, wrote:
Hmmmm. I see that I should have asked rather "Of what?" (relative to hydrogen embrittlement) If you want to use hydrogen on a large scale, you have to have some way to distribute it such as is done with natural gas. Huge fleets of liquid hydrogen tankers isn't going to cut it. Because of hydrogen embrittlement, any such distribution system will have to be built starting from zero as no existing system can handle hydrogen and building such a system will be both an engineering and economic challenge. 'mkay.. I'm well aware of the phenomenon related to hardened steels and electroplating, but have no experience with embrittlement effects on pipeline type steels (other than extreme cold) and was intrigued to learn that Hydrogen was a concern. |
My 302 and PDA are no longer on speaking terms | Dixie Sierra | Soaring | 4 | September 10th 07 05:16 PM |
Some IFR GPS's no longer useable | kevmor | Instrument Flight Rules | 2 | May 28th 07 02:27 AM |
Jepp no longer in the GA business...? | John Harper | Instrument Flight Rules | 30 | June 17th 04 10:49 PM |
Some airmen facing longer deployments | Otis Willie | Military Aviation | 0 | January 16th 04 08:34 PM |
