On Wed, 16 Apr 2008 11:07:53 +0000 (UTC), Dylan Smith
wrote in : On 2008-04-15, Larry Dighera wrote: Another limitation is that for something the size of a C-172, your battery has to deliver around 120 kW to get off the ground and climb to altitude. I don't see that fact as being too limiting. Why do you feel that's an issue? 120kW, or about 160 horsepower, at any sane voltage is going to be a tremendous amount of current. If your supply voltage to the motor was 600 volts, you'd need to deliver 200 amps. This requires a serious piece of cable to do efficiently (i.e. without getting insanely hot). I would use bus bar instead of cable. Here's a chart showing the ampacity for copper bus bar: http://www.stormcopper.com/design/Am...uick-Chart.htm It indicates that 1/4" X 1" copper would conduct 400 amps with a 30 °C temperature rise. It also needs batteries or a power source with a very low resistance to not also get very hot. Internal resistance is a serious issue, and deserves serious consideration. The battery internal resistance is considerably better than that of the fuel cell. From the battery specification sheet here http://a123systems.textdriven.com/product/pdf/1/ANR26650M1_Datasheet_MARCH_2008.pdf it would appear that it's not impossible (10 m0hms typical). The fuel cell internal resistance is considerably higher, but I took that into consideration in my previous rough calculations. With typical high current motive applications like trains or cars you can just add more metal to the conductors to the motors. You have a weight issue with aircraft, though, with both the control circuitry and the high voltage, high current wiring. That is true. To decrease conductor weight silver might be substituted for copper, but it would only provide about a 10% improvement. It seems fuel-cells have a rather high internal resistance at high currents. That's where most of the losses will be. Of course gasoline also requires tanks, but they are often just sealed parts of the wing structure, so their weight isn't really significant. I don't know the strength of carbon-fiber or Kevlar composite, but pressure cylinders constructed of them are about 60% lighter than comparable Al cylinders It's not just the tanks - you also have to make an idiot proof fuelling system that can be operated by the typical 17 year old line boy, but is capable of handling *five tonnes* per square inch of pressure. It would appear that has already been done: http://www.fuelcells.org/info/charts...ngstations.pdf http://www.sciencedirect.com/science...1eb7fca01a8c1d http://biz.yahoo.com/prnews/080331/lam082.html?.v=101 http://www.ieahia.org/pdfs/honda.pdf To put that into perspective, that's like two SUVs sitting on each square inch of pipe, connector and tank. Without even considering the energy content of the actual fuel, the potential energy of even an inert gas at those sorts of pressure would result in very bad stuff happening if someone got careless with the fuelling equipment. It's currently being done, so evidently the technology exists. While the engineering challenges can be solved, it's never going to be anything remotely resembling low cost due to the enormous pressures involved, and the safety issues with handling anything at those enormous pressures. It appears that it's currently cost effective enough to be viable in the marketplace. Perhaps you are able to provide some information that supports your assertion. Thanks for your input, Dylan. |
Well, It flies! | Doug Palmer | Home Built | 8 | June 17th 07 04:58 PM |
it flies and is huge. | Jim Macklin | Piloting | 12 | October 2nd 06 09:39 PM |
Antares Electric Motorglider | [email protected] | Soaring | 11 | July 15th 05 11:03 PM |
Jet Sailplane Flies! | Mhudson126 | Soaring | 10 | January 5th 04 09:10 PM |
C-119 flies again | Ron | Military Aviation | 9 | December 22nd 03 08:44 AM |
