I think you are over-analyzing this issue. The difference between flaps
and no flaps is so small that you won't notice it. What difference does it make if a recreational flight is 300 km (no flaps) rather than 315 km (flaps)? In contrast, you will notice if your glider is hard to rig, has a poor trailer, or isn't comfortable or fun to fly. Those are the things that you should be focusing on. noel.wade wrote: Thanks All, On the flaps vs. no-flaps argument, I guess it would be best to use a hypothetical situation: Imagine you have cloudbases that are 3000' to 4000' AGL. Terrain is somewhat mountainous, but the cloudbases rise with the terrain (20 miles east of the airport you might have 7000' - 8000' MSL bases over a 5000' MSL mountain). The lift is maxing out between 4 knots and 6 knots, with a lot of 2 to 3 knotters mixed in. The Cu are 4 - 6 miles apart. Winds are 5 - 10 knots, with the best soaring areas downwind from your home field (so you face a mild upwind glide home). Your total "window" for soaring is a 5 hour period during the day when conditions are going to be generating lift. The lift is workable from 1000' AGL to cloudbase, but staying within 1500' of cloubase seems much more comfortable. This is a pretty typical "decent" soaring day in Western Washington. So the question for you flapped pilots is: Would you be pushing your speed up enough in this situation to actually be using your flaps? ...Assume you're trying to do good cross-country flying - not super- agressive contest-like flying, but also not just puttering around within 15 miles of the airport either. Thanks! --Noel |
Greg Arnold wrote:
I think you are over-analyzing this issue. The difference between flaps and no flaps is so small that you won't notice it. What difference does it make if a recreational flight is 300 km (no flaps) rather than 315 km (flaps)? In contrast, you will notice if your glider is hard to rig, has a poor trailer, or isn't comfortable or fun to fly. Those are the things that you should be focusing on. Amen, Brother Arnold! Especially in the conditions Noel describes, speeds will be low, and flaps will make an insignificant difference in the soaring performance. Where flaps can make an important difference is in landing. You will be able to put an ASW 20 into a shorter field than an Standard Class glider. The landing flaps (60 degree deflection on the original 20, 40 degree deflection on the B and C models) let you arrive more steeply, more slowly, and stop more quickly than an unflapped glider of similar soaring performance. My experience in Western Washington (2 flights) isn't enough to advise you about field size! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Just to assuage everyone's concerns: I am very familiar with the
importance of a trailer and good rigging. This is why I'm especially keen on automatic hookups and something like a Cobra trailer. I've SEEN the difference a trailer makes when I help certain people at my field rig (even just in the difference between bracing / tie-down methods in similar trailers can have a big impact), and understand this point very well. As for flapped performance: The reason I talk about speed is because if you look at things like Idaflieg test data, the polar of say a DG-300 and an ASW-20 are nearly identical at similar wing-loadings, at about 55 knots and below. Above that the ASW-20 starts winning out by a small margin to around 75 knots, and then above that the negative flap settings seem to make a pretty noticeable difference in the polar and the ASW-20 is the clear winner. As another example: Look at the Johnson review of the ASW-20. Check out the composite polar diagrams. Looks like you have to get up over 75 knots before the negative flaps really start becoming superior to the 0-degree flap position. This is why I'm phrasing things in terms of speed or XC distance/ aggressiveness. The "climb" flaps of the ASW-20 are certainly superior (in small but noticeable ways) to the standard-class ships of the late-70's. But the 80's standard-class ships seem to be equal to the ASW-20 in terms of minimum sink and low-speed polar curves. Newer airfoils seem to have a smaller "knee" in the polar curve at middling speeds, but its still there for any standard-class ship. However its the upper end of the polar that really seems to be the difference (ignoring the landing-flaps deal). Am I off-base here? *shrug* My longest XC flight so far is ~130 miles total distance-over- ground on a 4 hour flight that didn't actually get too far from home- base (low clouds in the mountains kept me from going where I wanted). I'd like to be able to push a little harder to get from cloud to cloud and cover more ground - but I'm not eager to risk landouts like one or two "aggressive" pilots in my club who get low a lot, and land out a good 3 - 4 times every year. My XC experience to date is in a Russia AC-4 so I'm not sure how huge of a jump its going to be when I move up to a 40:1 ship; maybe that increase in performance alone will be enough to make me feel better about cloud-hopping at slightly higher than best-L/D speed, or stretching out a bit further to find lift. I just don't have the experience to know if I'm really going to be jonesing for that flap handle after I fly a standard-class ship for a year... I thrive on challenges and new experiences - being bored with my ship would be a nightmare! Take care, --Noel P.S. Brad - I already looked at an Apis kit. Price of the Euro has killed that for me! :-P |
On Apr 16, 10:23*pm, "noel.wade" wrote:
Just to assuage everyone's concerns: *I am very familiar with the importance of a trailer and good rigging. *This is why I'm especially keen on automatic hookups and something like a Cobra trailer. *I've SEEN the difference a trailer makes when I help certain people at my field rig (even just in the difference between bracing / tie-down methods in similar trailers can have a big impact), and understand this point very well. As for flapped performance: *The reason I talk about speed is because if you look at things like Idaflieg test data, the polar of say a DG-300 and an ASW-20 are nearly identical at similar wing-loadings, at about 55 knots and below. *Above that the ASW-20 starts winning out by a small margin to around 75 knots, and then above that the negative flap settings seem to make a pretty noticeable difference in the polar and the ASW-20 is the clear winner. As another example: *Look at the Johnson review of the ASW-20. *Check out the composite polar diagrams. *Looks like you have to get up over 75 knots before the negative flaps really start becoming superior to the 0-degree flap position. This is why I'm phrasing things in terms of speed or XC distance/ aggressiveness. *The "climb" flaps of the ASW-20 are certainly superior (in small but noticeable ways) to the standard-class ships of the late-70's. *But the 80's standard-class ships seem to be equal to the ASW-20 in terms of minimum sink and low-speed polar curves. *Newer airfoils seem to have a smaller "knee" in the polar curve at middling speeds, but its still there for any standard-class ship. *However its the upper end of the polar that really seems to be the difference (ignoring the landing-flaps deal). *Am I off-base here? *shrug* *My longest XC flight so far is ~130 miles total distance-over- ground on a 4 hour flight that didn't actually get too far from home- base (low clouds in the mountains kept me from going where I wanted). I'd like to be able to push a little harder to get from cloud to cloud and cover more ground - but I'm not eager to risk landouts like one or two "aggressive" pilots in my club who get low a lot, and land out a good 3 - 4 times every year. My XC experience to date is in a Russia AC-4 so I'm not sure how huge of a jump its going to be when I move up to a 40:1 ship; maybe that increase in performance alone will be enough to make me feel better about cloud-hopping at slightly higher than best-L/D speed, or stretching out a bit further to find lift. I just don't have the experience to know if I'm really going to be jonesing for that flap handle after I fly a standard-class ship for a year... *I thrive on challenges and new experiences - being bored with my ship would be a nightmare! Take care, --Noel P.S. *Brad - I already looked at an Apis kit. *Price of the Euro has killed that for me! :-P We understand your reasons. Hopefully you uderstand what we are all saying, flaps or no flaps will not make much of a differece to your XC results, as handicap shows. Almost everything else matter much more to your overall experience. Either the 300 or the 20 will perform much better than your Russia, and will look much better as well. Ramy |
I was looking for an ASW20 and ended up buying a DG300, for different
reasons: the easy rigging as you mention, the amazing visibility (it's sooo cool), the price - with the restrictions introduced in europe prices went down significantly, the good condition of the one i found, the reports from friends on how much pleasure it is to fly one. For an ASW20 the only version i could find at the time in the same price range was the F, and i was told this is not exactly the same as a B or C. I was told the F demands more attention and experience from the pilot as it has a bigger tendency to stall when not flown properly. Considering my experience i feel better now knowing my DG would never treat me in such a way... and i give her the same caring treatment in return. If i would find an ASW20 and a DG300 on the same price range, i would pick the one in best condition and better equipped. I got an LX5000, a FLARM, a Komet trailer and a nice interior which i now value a lot. Seriously... you think you would get bored with a non-flapped 15m ship that has 40+ glide ratio? Ricardo On Apr 17, 7:23 am, "noel.wade" wrote: Just to assuage everyone's concerns: I am very familiar with the importance of a trailer and good rigging. This is why I'm especially keen on automatic hookups and something like a Cobra trailer. I've SEEN the difference a trailer makes when I help certain people at my field rig (even just in the difference between bracing / tie-down methods in similar trailers can have a big impact), and understand this point very well. As for flapped performance: The reason I talk about speed is because if you look at things like Idaflieg test data, the polar of say a DG-300 and an ASW-20 are nearly identical at similar wing-loadings, at about 55 knots and below. Above that the ASW-20 starts winning out by a small margin to around 75 knots, and then above that the negative flap settings seem to make a pretty noticeable difference in the polar and the ASW-20 is the clear winner. As another example: Look at the Johnson review of the ASW-20. Check out the composite polar diagrams. Looks like you have to get up over 75 knots before the negative flaps really start becoming superior to the 0-degree flap position. This is why I'm phrasing things in terms of speed or XC distance/ aggressiveness. The "climb" flaps of the ASW-20 are certainly superior (in small but noticeable ways) to the standard-class ships of the late-70's. But the 80's standard-class ships seem to be equal to the ASW-20 in terms of minimum sink and low-speed polar curves. Newer airfoils seem to have a smaller "knee" in the polar curve at middling speeds, but its still there for any standard-class ship. However its the upper end of the polar that really seems to be the difference (ignoring the landing-flaps deal). Am I off-base here? *shrug* My longest XC flight so far is ~130 miles total distance-over- ground on a 4 hour flight that didn't actually get too far from home- base (low clouds in the mountains kept me from going where I wanted). I'd like to be able to push a little harder to get from cloud to cloud and cover more ground - but I'm not eager to risk landouts like one or two "aggressive" pilots in my club who get low a lot, and land out a good 3 - 4 times every year. My XC experience to date is in a Russia AC-4 so I'm not sure how huge of a jump its going to be when I move up to a 40:1 ship; maybe that increase in performance alone will be enough to make me feel better about cloud-hopping at slightly higher than best-L/D speed, or stretching out a bit further to find lift. I just don't have the experience to know if I'm really going to be jonesing for that flap handle after I fly a standard-class ship for a year... I thrive on challenges and new experiences - being bored with my ship would be a nightmare! Take care, --Noel P.S. Brad - I already looked at an Apis kit. Price of the Euro has killed that for me! :-P |
noel.wade wrote:
As for flapped performance: The reason I talk about speed is because if you look at things like Idaflieg test data, the polar of say a DG-300 and an ASW-20 are nearly identical at similar wing-loadings, at about 55 knots and below. Above that the ASW-20 starts winning out by a small margin to around 75 knots, and then above that the negative flap settings seem to make a pretty noticeable difference in the polar and the ASW-20 is the clear winner. I typically cruise at 70-80 knots in Eastern Washington conditions, and that's in a 50:1, 18 meter, 8.3 pound wing loading glider. With your experience and Western Washington conditions, I think it will be a rare day when you will want to cruise at even 70 knots in 15 meter glider, flapped or not. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Wed, 16 Apr 2008 22:23:24 -0700, noel.wade wrote:
This is why I'm phrasing things in terms of speed or XC distance/ aggressiveness. The "climb" flaps of the ASW-20 are certainly superior (in small but noticeable ways) to the standard-class ships of the late-70's. As a some-time 20 driver I found that I almost never used thermal flap. The glider felt a lot livelier and climbed almost as well in zero flap. I only used thermal flap when digging myself out of a hole in very weak lift. I've been told that a 20 spins more easily in thermal flap though didn't experience that. If it helps any, read what Andreas Maurer had to say about flying the 20. I found it very helpful. Mine was an early version with the Jesus flap setting. A copy of his notes is he http://www.gregorie.org/gliding/asw2..._handling.html If you do go for the 20 you'll find that learning to fly a flapped glider is rather like the experience that somebody who learnt to drive an automatic car has when converting to a manual gearbox: the mechanics of using the flaps is easy enough but the business of being in the right flap setting at all times takes time and practise. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
I am not convinced that a flapped glider will land in a much smaller
field than non flapped glider. I owned a Discus2, and I landed it out...more times than I would like to discuss in this forum. I am not going to go into field landing techniques, but I could land very low energy, nose high, and stop in amazingly short fields, without hitting the nose on the ground. When taking the glider to the hanger I would touchdown before the beginning of the hanger and pull around the corner. total rolling distance is under 130ft in light wind conditions. How many times do you pick a field with that little distance? I cleaned my brake regularly to keep it in good working order. I know own a flapped glider. Would I go back sure. However I like 25.5meters and anything under is just no fun. So looking at the gliders that you listed. What fits your wallet? What fits your body? What looks sexy (to you)? What finish is in good condition (unless you like sanding and painting)? They are all good gliders, if not they would be sitting on the market cheap...but there is not much sitting on the market, and it is not cheap. On the trailer topic. Nimbus 3 in Pfieffer trailer vs last generation Cobra trailer....time difference to rig is about 3min. You could get rid of that with a trailer ramp jack. |
g l i d e r s t u d wrote:
I am not convinced that a flapped glider will land in a much smaller field than non flapped glider. I owned a Discus2, and I landed it out...more times than I would like to discuss in this forum. I am not going to go into field landing techniques, but I could land very low energy, nose high, and stop in amazingly short fields, without hitting the nose on the ground. When taking the glider to the hanger I would touchdown before the beginning of the hanger and pull around the corner. total rolling distance is under 130ft in light wind conditions. Are you sure about that? The Road & Track Road Test Summary shows that 130' is the typical emergency stopping distance of most cars from 60 mph (52 knots). The Porsche Carrera GT, for example, stops in 124'. I would like to see you stop that D2 as quickly as a Porsche! How many times do you pick a field with that little distance? I cleaned my brake regularly to keep it in good working order. I know own a flapped glider. Would I go back sure. However I like 25.5meters and anything under is just no fun. So looking at the gliders that you listed. What fits your wallet? What fits your body? What looks sexy (to you)? What finish is in good condition (unless you like sanding and painting)? They are all good gliders, if not they would be sitting on the market cheap...but there is not much sitting on the market, and it is not cheap. On the trailer topic. Nimbus 3 in Pfieffer trailer vs last generation Cobra trailer....time difference to rig is about 3min. You could get rid of that with a trailer ramp jack. |
I am not convinced that a flapped glider will land in a much smaller field than non flapped glider. I owned a Discus2, and I landed it out...more times than I would like to discuss in this forum. I am not going to go into field landing techniques, but I could land very low energy, nose high, and stop in amazingly short fields, without hitting the nose on the ground. When taking the glider to the hanger I would touchdown before the beginning of the hanger and pull around the corner. total rolling distance is under 130ft in light wind conditions. How many times do you pick a field with that little distance? I cleaned my brake regularly to keep it in good working order. In my experience, the big advantage of certain flapped gliders (those with 40+ degree landing position, or incorporating trailing edge dive brakes like the Ventus A/B) isn't the reduction in stopping distance. It's the fact that I can make very steep approaches into short obstructed fields without a significant increase in airspeed. This allows taking full advantage of whatever stopping distance is available. Non-flapped gliders require a shallower approach, which is a problem if there are wires, trees, or a hillside in the way... Marc |
Bearing and Course, differences? | Allen Smith | Piloting | 27 | September 2nd 07 03:28 PM |
Rep vs. Dem Differences | Jim Weir | Piloting | 212 | September 8th 04 04:02 PM |
Aluminum differences | Lou Parker | Home Built | 16 | August 25th 04 06:48 PM |
ASW 20, ASW 20B, ASW 20C DIFFERENCES | Ventus B | Soaring | 8 | July 18th 04 10:28 AM |
Differences between Garmin 295 and 196? | carlos | Owning | 17 | January 29th 04 08:55 PM |
