Should I be scared -- C172 over Gross
Old April 18th 08, 07:11 AM posted to rec.aviation.piloting
WingFlaps
Default Should I be scared -- C172 over Gross
On Apr 18, 2:43Â*pm, Bertie the Bunyip wrote:
WingFlaps wrote in news:d33d5865-938c-4cae-acb3-
On Apr 18, 9:20�am, Andrew Sarangan wrote:
Even if the airplane is perfectly airworthy, and all maintenance done
properly, you don't know if the engine is producing 160HP (or
whatever
the rated power for your airplane). There is no signature in the
logbook that certifies that the airplane engine has been tested and
found to produce the specified power. I have flown rentals that flew
like a 120HP Cessna instead of a 160 HP. RPM can't tell you the true
power because every airplane uses a different pitch prop.
Well if the renter is slappin' on any old prop then you should not go
there. How does a 120 HP 172 reach cruise airspeed at cruise RPM?
Coasely pitched props don't allow good static HP because the RPM doesn't
get up to where it needs to be to produce HP. That's what variable pitch
props are all about.
Yes, but my point is that cruise speed also tells you about HP on a
daily basis. As far as I know, there are only a very limited number of
approved props for each 172 variant. If you don't see the magic static
RPM as specified in the POH it's time to investigate not fly -right?
Cheers
Old April 18th 08, 06:02 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
WingFlaps wrote in news:cb62baf1-cf48-423f-b9c5-
acb3-
done
whatever
and
flew
true
go
doesn't
pitch
Oh, OK, yeah, that's right. But you can have an absolutely beat engine
and still get the revs in cruise for most airplanes. My father had an
old Mercedes I borrowed off him once. Went fine, but he lived in a very
flat area and I took it to a multi story parking lot and couldn't get it
up the ramp. I looked around it the next day and found the cam lobes
almost round!
Bertie
My wife getting scared Paul Tomblin Piloting 271 October 11th 07 08:19 PM
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
