On Apr 20, 6:19*pm, wrote:
On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Cheers |
On Apr 21, 2:07*am, Bertie the Bunyip wrote:
WingFlaps wrote in news:3ba51b9f-6384-43cf-9f74- : On Apr 20, 6:19*pm, wrote: On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Actually, a partial gear landing is considered safer. I've made on ( not by choice, one failed on touchdown) and damage was minimal. The airplane was flying agian the next day. S'funny you say that as I was reading some RAF stories from the war and it seemed like gear up was the way to go. The touble with one wheel down is what happens to the wing wen it catches on the ground and starts a groundloop. It seems to me that accidental gear ups do relativeley little damage to structure. Cheers |
On 21 Apr, 02:59, "Maxwell" luv2^fly99@cox.^net wrote:
"Bertie the Bunyip" wrote in 6.130... WingFlaps wrote in news:cc5e0db0-3e13-42b8-8d46- : On Apr 21, 2:07 am, Bertie the Bunyip wrote: WingFlaps wrote in news:3ba51b9f-6384-43cf- 9f74- : On Apr 20, 6:19 pm, wrote: On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Actually, a partial gear landing is considered safer. I've made on ( not by choice, one failed on touchdown) and damage was minimal. The airplane was flying agian the next day. S'funny you say that as I was reading some RAF stories from the war and it seemed like gear up was the way to go. The touble with one wheel down is what happens to the wing wen it catches on the ground and starts a groundloop. It seems to me that accidental gear ups do relativeley little damage to structure. Well, in my case it happened at high speed and we did eventually groundloop, bt at low speed and with little damage. The left prop got it, but the boss did a crank check and found it OK, so it flew the next day. Cracked drag link was the culprit. For large aircraft, even those without underslung engines, they do recommend that we take whatever is down. I know a few guys who have landed completely wheels up and the damage was pretty heavy. A Beech 99, for instance ( lots of those have been wheels up) Bertie Yeah, but you're just a liar.- Hide quoted text - - Show quoted text - Oh ouch, maxie's back and he's chewing big lumps out of me. Ouch again. Bertie |
On Apr 21, 3:17*am, Bertie the Bunyip wrote:
WingFlaps wrote in news:cc5e0db0-3e13-42b8-8d46- : On Apr 21, 2:07*am, Bertie the Bunyip wrote: WingFlaps wrote in news:3ba51b9f-6384-43cf- 9f74- : On Apr 20, 6:19*pm, wrote: On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Actually, a partial gear landing is considered safer. I've made on ( not by choice, one failed on touchdown) and damage was minimal. The airplane was flying agian the next day. S'funny you say that as I was reading some RAF stories from the war and it seemed like gear up was the way to go. The touble with one wheel down is what happens to the wing wen it catches on the ground and starts a groundloop. It seems to me that accidental gear ups do relativeley little damage to structure. Well, in my case it happened at high speed and we did eventually groundloop, bt at low speed and with little damage. The left prop got it, but the boss did a crank check and found it OK, so it flew the next day. Cracked drag link was the culprit. For large aircraft, even those without underslung engines, they do recommend that we take whatever is down. I know a few guys who have landed completely wheels up and the damage was pretty heavy. A Beech 99, for instance ( lots of those have been wheels up) For the Gulfstream III landing with any two (2) gear legs down and locked is preferred to landing with only one gear down or all gear up. Should only one gear be extended, it is recommended that the gear be retracted and an all gear up landing be performed. Landing with only the nose gear down and locked is specifically not recommended. Do you know why it would be different for heavies? Cheers |
![]() "WingFlaps" wrote in message ... On Apr 21, 3:17 am, Bertie the Bunyip wrote: WingFlaps wrote in news:cc5e0db0-3e13-42b8-8d46- : On Apr 21, 2:07 am, Bertie the Bunyip wrote: WingFlaps wrote in news:3ba51b9f-6384-43cf- 9f74- : On Apr 20, 6:19 pm, wrote: On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Actually, a partial gear landing is considered safer. I've made on ( not by choice, one failed on touchdown) and damage was minimal. The airplane was flying agian the next day. S'funny you say that as I was reading some RAF stories from the war and it seemed like gear up was the way to go. The touble with one wheel down is what happens to the wing wen it catches on the ground and starts a groundloop. It seems to me that accidental gear ups do relativeley little damage to structure. Well, in my case it happened at high speed and we did eventually groundloop, bt at low speed and with little damage. The left prop got it, but the boss did a crank check and found it OK, so it flew the next day. Cracked drag link was the culprit. For large aircraft, even those without underslung engines, they do recommend that we take whatever is down. I know a few guys who have landed completely wheels up and the damage was pretty heavy. A Beech 99, for instance ( lots of those have been wheels up) For the Gulfstream III landing with any two (2) gear legs down and locked is preferred to landing with only one gear down or all gear up. Should only one gear be extended, it is recommended that the gear be retracted and an all gear up landing be performed. Landing with only the nose gear down and locked is specifically not recommended. Do you know why it would be different for heavies? Cheers No, but I sure he will make something up. He has a better imagination than MX. |
On 21 Apr, 04:57, "Maxwell" luv2^fly99@cox.^net wrote:
"WingFlaps" wrote in message ... On Apr 21, 3:17 am, Bertie the Bunyip wrote: WingFlaps wrote in news:cc5e0db0-3e13-42b8-8d46- : On Apr 21, 2:07 am, Bertie the Bunyip wrote: WingFlaps wrote in news:3ba51b9f-6384-43cf- 9f74- : On Apr 20, 6:19 pm, wrote: On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Actually, a partial gear landing is considered safer. I've made on ( not by choice, one failed on touchdown) and damage was minimal. The airplane was flying agian the next day. S'funny you say that as I was reading some RAF stories from the war and it seemed like gear up was the way to go. The touble with one wheel down is what happens to the wing wen it catches on the ground and starts a groundloop. It seems to me that accidental gear ups do relativeley little damage to structure. Well, in my case it happened at high speed and we did eventually groundloop, bt at low speed and with little damage. The left prop got it, but the boss did a crank check and found it OK, so it flew the next day. Cracked drag link was the culprit. For large aircraft, even those without underslung engines, they do recommend that we take whatever is down. I know a few guys who have landed completely wheels up and the damage was pretty heavy. A Beech 99, for instance ( lots of those have been wheels up) For the Gulfstream III landing with any two (2) gear legs down and locked is preferred to landing with only one gear down or all gear up. Should only one gear be extended, it is recommended that the gear be retracted and an all gear up landing be performed. Landing with only the nose gear down and locked is specifically not recommended. Do you know why it would be different for heavies? Cheers No, but I sure he will make *something up. He has a better imagination than MX.- Hide quoted text - - Show quoted text - Aww, not really, I can't imagine you being a pilot, for instance. Bertie |
On 21 Apr, 03:19, WingFlaps wrote:
On Apr 21, 3:17*am, Bertie the Bunyip wrote: WingFlaps wrote in news:cc5e0db0-3e13-42b8-8d46- : On Apr 21, 2:07*am, Bertie the Bunyip wrote: WingFlaps wrote in news:3ba51b9f-6384-43cf- 9f74- : On Apr 20, 6:19*pm, wrote: On Apr 18, 5:51 pm, WingFlaps wrote: On Apr 19, 7:37 am, "tom418" wrote: This is only an emergency because it looks good on TV. A gear up is not a life threatening event. It would have been even less of a risk and done a lot less less damage to the plane if he had retracted the gear and stopped the engines and done a belly landing . Cheers Unless he had to go-around after feathering both engines. Why would he want to go around after short final? Are you saying the POH says land on on one wheel? Now apply some PIC skills. Which is safer, a belly landing with engines off or the crash landing the pilot made? Actually, a partial gear landing is considered safer. I've made on ( not by choice, one failed on touchdown) and damage was minimal. The airplane was flying agian the next day. S'funny you say that as I was reading some RAF stories from the war and it seemed like gear up was the way to go. The touble with one wheel down is what happens to the wing wen it catches on the ground and starts a groundloop. It seems to me that accidental gear ups do relativeley little damage to structure. Well, in my case it happened at high speed and we did eventually groundloop, bt at low speed and with little damage. The left prop got it, but the boss did a crank check and found it OK, so it flew the next day. Cracked drag link was the culprit. For large aircraft, even those without underslung engines, they do recommend that we take whatever is down. I know a few guys who have landed completely wheels up and the damage was pretty heavy. A Beech 99, for instance ( lots of those have been wheels up) For the Gulfstream III landing with any two (2) gear legs down and locked is preferred to landing with only one gear down or all gear up. Should only one gear be extended, it is recommended that the gear be retracted and an all gear up landing be performed. Landing with only the nose gear down and locked is specifically not recommended. Do you know why it would be different for heavies? Cheers- Hide quoted text - - Show quoted text - Nah, and it might not be like that for all of them. They don't giove us a lot of info about stuff like that these days. they only tell us what they want us to know. What they do recommned is that we shut down all engines when the airframe begins to contact the ground ( in the 757, anyway) Bertie |
