Sharpen up your german and follow this link. You'll learn more about
maintaining your glider's finish than you're getting here. http://www.rall-guitars.de/andreashp...chine_eng.html Look around the website for anything on polishing. Though the menus are in english (and some of the pages), patience and Babelfish will get you the info lacking in this thread. Think of your hard bar "wax" as finishing off the swirls left by 1200 wet sanding. Yes, it reduces and fills in the "gaps" while polishing, but it doesn't seal, so be sure to apply wax afterwards if you want to preserve the finish. I suspect the reason so many have objections to the hard wax and buffing wheel is based on lack of knowledge, trying to use it where cleaning and sanding would be natural precursors to polishing and sealing. Again, the results are exceptional. If you use the right tools for the appropriate steps in the process, you'll wind up with a brilliant finish that outshines anything from a bottle... and find that each step is really pretty simple and largely foolproof. There's no mystery in this stuff, save that it's tough to find valid information from a single, reliable source. "Tuno" wrote in message ... I've never used hard wax before, but since the factory recommends it on the gelcoat, I'm going to give it a try. I just have no clue how to go about it. (My Google search results are great -- for hair removal!) I have a Makita 0-3000rpm variable speed polisher, a brick of hard wax, and a mandrel and other accessories I got from the dealer. Is there a technique writeup on the web somewhere? ~ted/2NO |
I've never used hard wax but it sure sounds like a pain in the rear.
3M products are all I have used and if all your after is a final gloss "Finesse It" works great and is easy to use. As previously warned a buffer can do a lot of damage but I think if the person is smart enough to learn how to fly and understands power hand tools they could easily master it. |
Hard wax application is a lot easier than some make it out to be. John
Murray gave me a little demonstration, but it's pretty much a common sense thing anyway. Just keep moving and make sure the rotation is correct when you get near trailing edges and control surfaces. It works beautifully for me. I'm not scared of it, but I do have some respect for the danger it presents near trailing edges. Just take your time and think before applying. |
Tuno, you are getting good advice.
Machine "hardwaxing" is a skill and teaching yourself to do this as PIC the first time would be unwise for most mortals. If you are going the self-taught method, maybeyou could sell tickets to watch. The thin fiberglass/carbon skins of modern ships are especially sensitive to excess heat and pressure and a control surface can be ripped in half instantly if you get the wrong edge of the buffer in the wrong place. A friend working in a glider factory observed his 55 kg girlfriend get yanked completely over a wing when she caught the buffer on the leading edge. If you want to do this, the Makita variable spped buffer is the "gold standard" tool. As was mentioned previously, hardwaxing accomplishes a couple of things. First, it is mildly abrasive and thus removes fine scratches from the surface. Secondly, the heat of the buffer opens the porous structure of the gelcoat and the gets the wax down into the coating, "moisturizing" it. I know of a glider that was almost impossible to repair as the gelcoat was saturated with wax from repeated hardwaxing and nothing would stick to it. It is noteworthy that this ship's finish was nearly perfect even though this make and model is notorious for finish crazing. Negative issues associated with hardwaxing: 1) It will NOT protect the ship from UV. The ship mentioned above was very yellow despite the hardwaxing 2) It does remove material. 3) If done excessively and you soak the finish with wax, the gelcoat can be very difficult to repair. What protective wax to use is problematic. To my knowledge no independent research has been conducted and we thus rely on anectotal evidence and the manufactuer's claims. I currently favor and use the WX Block / Seal as the "topcoat" after final buffing of the surface. New Finish apparently does a good job as well. A Grob that was semi- annually coated (by hand) with this product sat out in the Tehachapi sun and weather 24/7 for a decade and looked great. [Rat On] Of course, it started with good gelcoat as opposed to the swill that some manufacturers pass off as a surface coating on $100K toys [Rant Off]. 100% carnuba seals the surface and does not interfere with repairs but I do not beleive it offers UV protection. Finally, I believe an optimal system would be: Buffing with Finessette to get a good surface, hardwax to get wax into the gelcoat, and WX Block for UV protection. As a side note, several studies, notably Dick Johnson, show that, while they are more difficult to keep clean, a 600 or 800 grit finish yields performance benefits and the mirror-like 1000+ grit finishes currently in vogue measurably degrade performance. I finish sand my own gliders to 800 grit and everyone else's to 1200. ![]() |
Gary,
You are right, "Finesse It II" is great stuff (as are most 3M products) and I use it too, but my inquiry is about *hard wax* application, not polishing. Those are two different things. My finish is already smooth and shiny -- but now I want to protect it from moisture, using the factory's recommendations (ergo, hard wax). I had a reply by e-mail saying that my glider received a hard wax application at the factory. I'm trying to verify this. If so, I'm not going to worry about it this year. I'll hard wax the trailer instead! 2NO |
Best Weather application | Scott | Products | 0 | January 7th 07 11:14 PM |
Application letter | Michael Baldwin, Bruce | Products | 0 | December 2nd 06 11:08 AM |
CANPASS application | Paul Tomblin | Piloting | 8 | April 25th 05 04:22 AM |
B-100 PC application | [email protected] | Soaring | 1 | December 29th 04 01:08 PM |
crazy talk - 320 into a 360 application? | [email protected] | Owning | 1 | August 6th 03 03:32 PM |
