Should I be scared -- C172 over Gross
Old April 23rd 08, 03:33 AM posted to rec.aviation.piloting
Peter Dohm
Default Should I be scared -- C172 over Gross
"gatt" wrote in message
news:jrudnQw6Ec_OGpPVnZ2dnUVZ_hSdnZ2d@integraonlin e...
Peter Dohm wrote:
I got the same impression. God knows a few of us tried to accomplish
this anyway. My read was that hr ended up not making the flight with the
pax???
That was my read as well. He still had a front seater and some of the
luggage, which left him comfortably withing both weight and CG limits.
The temperature on the day of the flight was higher that he had hoped
when planning a week ahead and apparently still well within the
acceptable range for the aircraft and airport; but, when combined with a
normally rather than lightly loaded aircraft, resulted in a "bite sized"
learning experience.
Given the altitude, the hot weather and the trees it goes to show how bad
things could have gone if the airplane had been more overgross than
expected.
The point is that he ultimately rose to his responsibility, took command,
and off-loaded the necessary pax and stores. Admittedly, the advice given
early in the thread would have been very well advised--to fly with an
instructor at near maximum weight and near the aft CG limit. However,
personal belief (or supposition if you insist) about the high temperature is
that he had simply trained in a lightly loaded aircraft at cooler
temperatures and actually had a more than adiquate safety margin--it was
simply a different sight picture and he is now a little more experienced and
none the worse for wear.
My own experience was nearly the opposite. I trained mainly in a Cessna
150M, the weather was nearly always warm, and we were probably below gross
by about the weight of whatever trinkets (such as extra pencils) we forgot
to bring. I also had some time in each of the four seats of a Cessna
172--which was also nearly always maxed out. The first time I soloed a 172,
I was really amazed--it climbed like a homesick angel, was reluctant to come
back down, and seemed to nearly stop before the wheels would touch the
pavement on landing.
OK, I exagerate; but probably no worse that the OP's takeoff. :-)
Pax are a dime a dozen, but, who wants to waste a perfectly-good Cessna?
Now, there's a good place to restart the Piper vs Cessna debate! ;-)
-c
Peter
Old April 23rd 08, 06:04 AM posted to rec.aviation.piloting
Mxsmanic
gliderguynj writes:
He ended up with a PAX and Luggage heavier than assumed, an airport
higher than thought and a day 20F hotter than expected.
Assuming this most recent post wasn't sarcasm at length, we also were
treated to a nice description of how he almost didn't clear the trees.
And this group says Well Done? Oh the Humanity!
Exactly.
Old April 23rd 08, 06:34 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
gliderguynj writes:
Exactly.
Again, since we only have your word and no further evidence that you are
human, it has nothing to do with you.
Bertie
My wife getting scared Paul Tomblin Piloting 271 October 11th 07 08:19 PM
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
