On Apr 24, 12:23*am, Mxsmanic wrote:
Dave Doe writes: How would that happen, given you are (see OP) 75 or 100 pound overweight - COG is not mentioned, so assume we're inside the envelope (fwd/aft envelope). Not enough lift. Well, you'd have a hard time understaning how a 172 can fly to Haiwaii then. Try simulating a 172 300# over MTOW? Vheers |
On Apr 23, 5:39*pm, Mxsmanic wrote:
writes: Sure it is in a simulatated world. Or if you hit the ground just beyond the runway in the real world because you took off overweight. I've flown a 172 more loaded that! Cheers |
WingFlaps wrote in
: On Apr 23, 5:39*pm, Mxsmanic wrote: writes: Sure it is in a simulatated world. Or if you hit the ground just beyond the runway in the real world because you took off overweight. I've flown a 172 more loaded that! Cheers I've flown one on a ferry that was probably about 300 or 400 lbs overweight, but off very long runways and in a quite cold region. No problem, but I wouldn't do it as routine and I wouldn't do it if performance was an issue. A couple of pounds overweight is one thing, but it doesn't take much to reach a point where the airplane won't go up at all, particularly if it's a relatively low powered aircraft like a 172 in the first place. The degradation is not linear, so if there's a 100 FPM loss with a 100lb overload, it does not mean that there will be a 200 lb loss with a 200 lb overload. Obvious, I know, but it's something often forgotten when wishful thinking takes the place of a rational approach to the problem. Bertie Bertie |
On Apr 23, 5:39 pm, Mxsmanic wrote:
writes: Sure it is in a simulatated world. Or if you hit the ground just beyond the runway in the real world because you took off overweight. You are demonstrating as to why you are the group clown. If an aircraft impacts the ground after takeoff it will be engine failure or loss of control (spin off departing turn) nothing to do with load.. Mate of mine is an ag pilot.At 72+ |
george writes:
You are demonstrating as to why you are the group clown. If an aircraft impacts the ground after takeoff it will be engine failure or loss of control (spin off departing turn) nothing to do with load.. I've already pointed this out: http://www.alexisparkinn.com/photoga...loaded-172.wmv Doesn't look like an engine failure or spin to me. The aircraft was overweight, though. |
Mxsmanic wrote in
news ![]() george writes: You are demonstrating as to why you are the group clown. If an aircraft impacts the ground after takeoff it will be engine failure or loss of control (spin off departing turn) nothing to do with load.. I've already pointed this out: http://www.alexisparkinn.com/photoga...12-Overloaded- 1 72.wmv Doesn't look like an engine failure or spin to me. The aircraft was overweight, though. Nothing looks like anythign to you, fjukktard, you don't fly and have no idea of what you're talking about. You may as well be commenting on a Star trek sequence as though it were reality. Bertie |
On Apr 24, 12:24 pm, Mxsmanic wrote:
Doesn't look like an engine failure or spin to me. The aircraft was overweight, though. How the hell would you know what either engine failure or a spin looks like? Remember. You can't and don't fly. I'd guess that this was an aft CofG.with all that that implies to the pilots here... |
Mxsmanic wrote:
writes: Sure it is in a simulatated world. Or if you hit the ground just beyond the runway in the real world because you took off overweight. You have no idea why what you just said is nonsensical, and I'm not going to bother to explain it to you. -c |
On Apr 23, 5:01 pm, Mxsmanic wrote:
george writes: Uh. 30 pound over is burned off in about 30 minutes. Unfortunately, take-off is over in 30 seconds. With a modern runway in front of me around 700m long and no obstructions above 200 feet for a km or so I will be safely off the ground and established in the climb at 30 seconds. 30 minutes I will be clear of the circuit at my (C172) cruising altitude and on track for my destination. |
My wife getting scared | Paul Tomblin | Piloting | 271 | October 11th 07 08:19 PM |
Scared of mid-airs | Frode Berg | Piloting | 355 | August 20th 06 05:27 PM |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
