Cambridge 302A CFR questions
Old April 22nd 08, 08:30 PM posted to rec.aviation.soaring
Default Cambridge 302A CFR questions
I thought this would be simple, but I can't find the answers in the
manual.
1. How many turnpoints can I load into the memory (not the task, but
the turnpoint file)?
2. What NMEA sentences are output to the serial port?
3. Not that I will do it, but can I change the data output to NMEA
sentences other than the default?
Questionable minds want to know.....
Old April 22nd 08, 09:13 PM posted to rec.aviation.soaring
manual.
1. *How many turnpoints can I load into the memory (not the task, but
According to the articles page on the Cambridge website, the 300
series holds up to 250 "turnpoints".
The Cambridge articles only mention NMEA-0183 output. No mention of
anything else or of any "options" to change it.
Old April 22nd 08, 09:27 PM posted to rec.aviation.soaring
Hmmm... Now that I look closer, it seems that info is for earlier GPS-
NAV models. I don't see anything for the newer 300 series.
Old April 22nd 08, 09:31 PM posted to rec.aviation.soaring
manual.
Here's some good details regarding the data port and NMEA sentences:
http://www.cambridge-aero.com/manual...v517_rev21.pdf
Old April 22nd 08, 10:22 PM posted to rec.aviation.soaring
manual.
Here's some good details regarding the data port and NMEA sentences:http://www.cambridge-aero.com/manual...v517_rev21.pdf
Excellent reference! EXACTLY what I was looking for, THANKS!
Old April 23rd 08, 04:38 AM posted to rec.aviation.soaring
Paul Remde
Hi James,
The 302 and 302A support up to 1500 waypoints.
I don't think there is a way to change the output NMEA sentences.
Below is a data capture from a 302. The 302 send similar data, but no wind
or airspeed data. I believe the !w sentence is not sent by the 302A. It
contains the 302 air data.
!w,000,000,0000,500,01287,01020,-0668,191,199,191,000,000,100*44
$GPRMC,163805,V,4448.5614,N,09333.0117,W,000.0,000 .0,260304,002.1,E*7D
$GPRMB,V,,,Stanton ,,4308.8388,N,09300.9833,W,,,*47
$GPGGA,163805,4448.5614,N,09333.0117,W,0,00,00.0,0 .0,M,0.0,M,,*5F
$PCAIB,00280,00067
$PCAID,N,+00224,000,128*05
I created an Excel spreadsheet a while back that compares the data output
from a 302 and 302A. I'd be glad to e-mail it to you if you send me a note
asking for it.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
manual.
Old April 23rd 08, 02:24 PM posted to rec.aviation.soaring
Tony Verhulst
I'm pretty sure that that's the model 20/25 limit.
Tony V.
Old April 23rd 08, 03:44 PM posted to rec.aviation.soaring
On Apr 22, 8:38*pm, "Paul Remde" wrote:
Hi James,
Below is a data capture from a 302. *The 302 send similar data, but no wind
or airspeed data. *I believe the !w sentence is not sent by the 302A. *It
$GPRMB,V,,,Stanton * * ,,4308.8388,N,09300.9833,W,,,*47
$PCAIB,00280,00067
from a 302 and 302A. *I'd be glad to e-mail it to you if you send me a note
asking for it.
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
manual.
Questionable minds want to know.....- Hide quoted text -
- Show quoted text -
Thanks Paul,
I was wondering about the waypoint limitation because I used to have
the impression there was a 250 waypoint limit (don't know where I got
that idea) and had already exceeded that by loading 456 waypoints.
Thanks also for sending the data stream. I'll hook mine up tonight
and play little. I am particularly interested in the PCAID
sentence. I use XCSoar, and it currentlly doesn't properly display
the pressure altitude (always shows zero). I wasn't sure if cambridge
included that in the output datastream, or just recorded it in
the .igc file.
.... and thanks for having so much great information on your
website!
Cambridge 302A Data integrity. Bob Soaring 4 June 6th 07 02:04 PM
FOR SALE: Cambridge 302A ContestID67 Soaring 2 March 17th 07 11:21 PM
For Sale: Used Cambridge 302A Paul Remde Soaring 1 October 8th 05 03:37 AM
cambridge 302a Nicola Botta Soaring 2 January 25th 05 11:17 PM
For Sale - Demo Cambridge 302 and 302A Paul Remde Soaring 1 November 20th 04 09:41 PM
