Should I be scared -- C172 over Gross
Old April 23rd 08, 11:05 AM posted to rec.aviation.piloting
WingFlaps
Default Should I be scared -- C172 over Gross
On Apr 23, 5:39*pm, Mxsmanic wrote:
writes:
Sure it is in a simulatated world.
Or if you hit the ground just beyond the runway in the real world because you
took off overweight.
I've flown a 172 more loaded that!
Cheers
Old April 23rd 08, 08:50 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
WingFlaps wrote in
writes:
because
you
Cheers
I've flown one on a ferry that was probably about 300 or 400 lbs
overweight, but off very long runways and in a quite cold region. No
problem, but I wouldn't do it as routine and I wouldn't do it if
performance was an issue. A couple of pounds overweight is one thing,
but it doesn't take much to reach a point where the airplane won't go up
at all, particularly if it's a relatively low powered aircraft like a
172 in the first place. The degradation is not linear, so if there's a
100 FPM loss with a 100lb overload, it does not mean that there will be
a 200 lb loss with a 200 lb overload. Obvious, I know, but it's
something often forgotten when wishful thinking takes the place of a
rational approach to the problem.
Bertie
Bertie
My wife getting scared Paul Tomblin Piloting 271 October 11th 07 08:19 PM
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
