#81
![]() "Larry Dighera" wrote in message ... The lesson all involved can take from this incident is to comply with the regulations and commonsense good-practices contained in the appropriate aviation documents (AIM for civil). VFR civil flights need to contact the MOA controlling authority to coordinate transition through the MOA before departure as part of flight planning while on the ground, and the military needs to comprehend the concept of joint-use airspace. There's nothing to coordinate, VFR aircraft are free to transit MOAs if they so choose. Radar traffic advisories may be available and are certainly a good idea, but that's true in or out of a MOA. ATC may not be in communications with military aircraft in the MOA or have ready communications with the using agency to make them aware of the presence of VFR aircraft in the MOA. If the military finds a VFR civil flight in the MOA with them, and they feel that it unnecessarily hinders their training missions, they need to work through the system to have the procedures, regulations or airspace classification modified. The military should not use their taxpayer funded hardware to audaciously intimidate the very citizen taxpayers whom they serve, _legally_ (but perhaps imprudently) operating within the NAS, least they bring dishonor upon themselves. Have the airspace modified in what way? |
#82
![]() "Larry Dighera" wrote in message ... Do you believe MARSA was, or should have been, employed in this incident? MARSA couldn't have been employed in this incident. |
#83
![]() "Larry Dighera" wrote in message ... On Wed, 23 Apr 2008 09:18:04 -0500, "Steven P. McNicoll" wrote in : "Larry Dighera" wrote in message news ![]() Six hundred feet is markedly less than 500 feet: Uhh, no it isn't. Six hundred feet is more than 500 feet. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. I fail to see the connection between minimum safe altitudes and lateral separation between aircraft. Perhaps you know of other separation criteria that may have applied in the situation under discussion. There are none. FAR 91.111(a) says only, "No person may operate an aircraft so close to another aircraft as to create a collision hazard." FAR 91.111(b) says, "No person may operate an aircraft in formation flight except by arrangement with the pilot in command of each aircraft in the formation.", but to my knowledge there is no definition of "formation flight" in 14 CFR Part 1. Lacking that, I believe § 91.119 to be applicable in this case. How do you interpret the intent of this sentence? In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. I infer 'closer' to include laterally as well as vertically. If that's not correct, then the word 'above' or 'over' would have been used. Yeah, but you also believe six hundred feet is markedly less than 500 feet, so your beliefs carry little weight. I infer it to mean there is a hemisphere of 500' radius centered on any person, vessel, or structure on the surface within which an aircraft may not be flown. |
#84
Gig 601Xl Builder writes:
The party making the claim has the burden of proof. So why hasn't the Air Force provided the tapes that would prove its claims? |
#85
Mxsmanic wrote:
Gig 601Xl Builder writes: You are doing exactly that. You are believing the civilian pilot because of his position as NOT an Air Force officer. No, I'm believing the civilian pilotS because there were two of them. As far as evidence the civilian isn't offering any either. Why would two different pilots make it up? There were 4 F16s. That's 4 against 2 so by your logic they must be the ones telling the truth. I have no doubt the Platypus' and the Beech's TCAS were going ape **** but that doesn't mean the F16s violated the regs. |
#86
On Wed, 23 Apr 2008 09:42:10 -0500, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . The lesson all involved can take from this incident is to comply with the regulations and commonsense good-practices contained in the appropriate aviation documents (AIM for civil). VFR civil flights need to contact the MOA controlling authority to coordinate transition through the MOA before departure as part of flight planning while on the ground, and the military needs to comprehend the concept of joint-use airspace. There's nothing to coordinate, I have found, that when the MOA is scheduled to be active, that alerting the military to the proposed time and route of your VFR transition is prudent, courteous, and facilitates coordination of your flight with their maneuvers. It often also provides you with a frequency to use to contact the MOA military controller, so that he can provide you with traffic advisories if he chooses. VFR aircraft are free to transit MOAs if they so choose. I completely understand that. However making an effort to facilitate cooperaton is simple and makes for better relations if nothing else, IMO. Radar traffic advisories may be available and are certainly a good idea, but that's true in or out of a MOA. I couldn't agree more. ATC may not be in communications with military aircraft in the MOA or have ready communications with the using agency to make them aware of the presence of VFR aircraft in the MOA. Unfortunately, that is too true, and it is part of the reason for my taking responsibility for the situation myself to the extent that I am able. If the military finds a VFR civil flight in the MOA with them, and they feel that it unnecessarily hinders their training missions, they need to work through the system to have the procedures, regulations or airspace classification modified. The military should not use their taxpayer funded hardware to audaciously intimidate the very citizen taxpayers whom they serve, _legally_ (but perhaps imprudently) operating within the NAS, least they bring dishonor upon themselves. Have the airspace modified in what way? Whatever way may be appropriate in a given situation. The point is, that it's important to work THROUGH the system, not bypass it with unilateral disregard for regulations/instructions. |
#87
On Wed, 23 Apr 2008 10:05:21 -0500, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . [snip] Lacking that, I believe § 91.119 to be applicable in this case. How do you interpret the intent of this sentence? In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. I infer 'closer' to include laterally as well as vertically. If that's not correct, then the word 'above' or 'over' would have been used. Yeah, but you also believe six hundred feet is markedly less than 500 feet, so your beliefs carry little weight. I believe that 20% is a significant difference. In this case it provides a cushion that arguably places the military aircraft far enough beyond the 500 foot limit of 91.119(b), that there is little chance of the AF incriminating themselves. Why do you believe that 20% diminishes the weight of my belief? What distance do you believe would be adequate to overcome your disregard for my belief? I infer it to mean there is a hemisphere of 500' radius centered on any person, vessel, or structure on the surface within which an aircraft may not be flown. That is also a reasonable and non-contradictory interpretation. Your inference may be implicit in the "In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure." wording of 91.119(b), but it's not explicit. |
#88
On Wed, 23 Apr 2008 09:42:58 -0500, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . Do you believe MARSA was, or should have been, employed in this incident? MARSA couldn't have been employed in this incident. I didn't ask you for your belief. I wanted to hear what Viperdoc had in mind when he brought up MARSA. |
#89
On 2008-04-23, Larry Dighera wrote:
I have found, that when the MOA is scheduled to be active, that alerting the military to the proposed time and route of your VFR transition is prudent, courteous, and facilitates coordination of your flight with their maneuvers. What method do you use to make sure the right military user gets the information? -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June) |
#90
![]() "Larry Dighera" wrote in message ... I have found, that when the MOA is scheduled to be active, that alerting the military to the proposed time and route of your VFR transition is prudent, courteous, and facilitates coordination of your flight with their maneuvers. It often also provides you with a frequency to use to contact the MOA military controller, so that he can provide you with traffic advisories if he chooses. That's fine, but you're using incorrect terminology. The military is not the MOA "controlling authority". The military would be the using agency, the controlling agency is typically an ARTCC. The controlling agency for the Gladden 1 MOA is Albuquerque Center, the using agency is the 56thFW, Luke AFB. Whatever way may be appropriate in a given situation. What way might be appropriate in the situation we're discussing? |
USAF F-16 Instructor Discusses Flying Into MOAs | Larry Dighera | Piloting | 39 | April 8th 08 07:03 PM |
US Military now wants more northern NY airspace to expand those MOAs | Peter R. | Piloting | 7 | June 14th 07 01:30 PM |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
There has _got_ to be a book that discusses 'practical welding' | Mike | Owning | 2 | April 16th 06 11:15 PM |
Mayor Daley discusses airport on Today Show 2/26 | Jenny Wrinkler | Piloting | 4 | February 28th 04 05:15 AM |
