USAF F-16 Instructor Discusses Flying Into MOAs
Old April 23rd 08, 06:07 PM posted to rec.aviation.piloting
Larry Dighera
Default USAF F-16 Instructor Discusses Flying Into MOAs
On Wed, 23 Apr 2008 10:05:21 -0500, "Steven P. McNicoll"
wrote in
"Larry Dighera" wrote in message
[snip]
Lacking that, I believe § 91.119 to be applicable in this case.
How do you interpret the intent of this sentence?
In those cases, the aircraft may not be operated closer than 500
feet to any person, vessel, vehicle, or structure.
I infer 'closer' to include laterally as well as vertically. If
that's not correct, then the word 'above' or 'over' would have been
used.
Yeah, but you also believe six hundred feet is markedly less than 500 feet,
so your beliefs carry little weight.
I believe that 20% is a significant difference. In this case it
provides a cushion that arguably places the military aircraft far
enough beyond the 500 foot limit of 91.119(b), that there is little
chance of the AF incriminating themselves.
Why do you believe that 20% diminishes the weight of my belief? What
distance do you believe would be adequate to overcome your disregard
for my belief?
I infer it to mean there is a hemisphere of 500' radius centered on any
person, vessel, or structure on the surface within which an aircraft may not
be flown.
That is also a reasonable and non-contradictory interpretation. Your
inference may be implicit in the "In those cases, the aircraft may not
be operated closer than 500 feet to any person, vessel, vehicle, or
structure." wording of 91.119(b), but it's not explicit.
Old April 23rd 08, 07:03 PM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
Ya think? Please explain how you determined 600 feet is 20% less than 500
feet. I wanna see your math.
for my belief?
The fact that you believe six hundred feet is markedly less than 500 feet is
what diminishes the weight of your belief.
Altitude is explicitly a distance upward, not laterally.
Old April 23rd 08, 07:30 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 23 Apr 2008 13:03:47 -0500, "Steven P. McNicoll"
wrote in
Oops! Thanks for pointing out my error.
Altitude isn't mentioned in that sentence. The word used is "closer."
Old April 23rd 08, 08:05 PM posted to rec.aviation.piloting
news
Larry, if you'd pull your head out of your ass and took a look at the title
of FAR 91.119 you'd find altitude mentioned there.
Old April 23rd 08, 09:12 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 23 Apr 2008 14:05:35 -0500, "Steven P. McNicoll"
wrote in
news
Mr. McNicoll, if you're unable to keep a civil tongue in your head,
you'll force me to ignore you.
I am well aware of the title.
Old April 23rd 08, 09:15 PM posted to rec.aviation.piloting
wrote in
news
title
So ignore me.
Then clearly, you do not understand what it means.
Old April 23rd 08, 10:15 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 23 Apr 2008 15:15:57 -0500, "Steven P. McNicoll"
wrote in
I understand what § 91.119(c) says. An attorney will understand it
too.
§ 91.119 Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may
operate an aircraft below the following altitudes:
(c) Over other than congested areas. An altitude of 500 feet
above the surface, except over open water or sparsely
populated areas. In those cases, the aircraft may not be
or structure.
It says that over open water or sparsely populated areas an aircraft
may not be operated closer than 500 feet to any person, vessel,
vehicle, or structure. Implicit in that statement is the lack of any
lower altitude limit, with the exception of being in the proximity of
a person, vessel, vehicle, or structure. But there is some ambiguity.
The fact that the first sentence states that an aircraft may not be
operated below the following altitudes can not possibly apply to
operation laterally distant from a person, vessel, vehicle, or
structure, because a lateral distance is not an altitude. If the
wording had included 'person, vessel, vehicle, or structure LOCATED ON
THE GROUND', perhaps it's intent would have been clearer, but the
language as written fails to restrict the implied 500' lateral limit
from being applied at altitude, IMO.
In the subject case (presumably over a sparsely populated area) the
F-16 was alleged to have been operated in less than 500' lateral
proximity to a vehicle, another aircraft in this case. I would say
you are naïve if you believe, that the attorney pilot will fail to
read § 91.119(c) the way I have? Most judges are attorneys. ...
Old April 23rd 08, 07:37 PM posted to rec.aviation.piloting
Al G[_1_]
m...
Or in the case of a pilot, downward.
Least important a
The altitude above me
The runway behind me
The gas in the fuel truck
and 1 second ago...
Al G
USAF F-16 Instructor Discusses Flying Into MOAs Larry Dighera Piloting 39 April 8th 08 07:03 PM
US Military now wants more northern NY airspace to expand those MOAs Peter R. Piloting 7 June 14th 07 01:30 PM
Gliders, transponders, and MOAs Greg Arnold Soaring 2 May 26th 06 05:13 PM
There has _got_ to be a book that discusses 'practical welding' Mike Owning 2 April 16th 06 11:15 PM
Mayor Daley discusses airport on Today Show 2/26 Jenny Wrinkler Piloting 4 February 28th 04 05:15 AM
