Lancair crash at SnF
Old April 24th 08, 11:16 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
Default Lancair crash at SnF
WingFlaps schrieb:
(the stall is now damn close -better
hope there's no significant wind)
Now we add in the energy losses from having to
accelerate with the wind and to glide speed.
Arrrgh! Not the old "turn into downwind" legend again! Better work out
your understanding of physics before publicly reasoning about turns.
There is nearly always somewhere flat to put the plane
The operative word in this sentence is "nearly".
Old April 24th 08, 11:40 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
Try reading the statement again, here it is:
"Now we add in the energy losses from having to accelerate with the
wind and to glide speed."
Now perhaps you would like to revise some physics and try to critcise
it for us?
I await your stumbling analysis of my words with mild amusement.
Cheers
Old April 24th 08, 11:48 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
it for us?
It's the "having to accelerate with the wind" part which is complete BS
unless I completely misunderstand what you are trying to say.
Old April 25th 08, 12:00 AM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
it for us?
The latter I think. The imposed accelerations associated with the
change in direction (from upwind to downwind) require control inputs
that add drag and increased energy loss (from drag).
To summarise your missed point, the pilot control inputs cost energy
that is not factored into simple glide/time analysis.
Cheers
Old April 25th 08, 12:58 AM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
WingFlaps wrote in news:80a95935-4492-4d7d-95c1-
critcise
it for us?
BS
Nope, the wind is going to help you in almost every way if you're
turning back. Firstly, your climnb gradient will have improved from the
headwind, leaving you higher for a given distance from the field. Also,
your glide is going to be improved by the tailwind when you do turn
downwind. also, your best LD speed is going to occur at a lower
airspeed, which will give you a couple of extra seconds if you have the
presence of mind to take advantage of it. You'll probably be a little on
the slow side after having made the turn anyway, so that's a help there.
If there is any crosswind element to the wind, you have another plus if
you turn towards the wind. The x-wind will minimise the radius of the
manuevering turns you will have to make.
There is no inertia involved in making a downwind turn. None. What does
cause trouble during a climbout is twofold. the wind gradient can cause
trouble, as it will for any tailwind/climb situation because inertia
does play a role there, and two, the perceived acceleration to the
eyeball can cause the pilot to do some untoward things. That's how that
particular old wive's tale came about.
However, the gradient is also your friend in the turnback/tailwind on
approach situation. the decreasing tailwind will bump your airspeed up
on approach and cut your G/S as you descend back to the runway.
I'd consider a turnback with some headwind on takeoff and the calmer it
is the less consideration I'd give to that avenue, depending of course
on the other circumstances.
Bertie
Old April 25th 08, 01:41 AM posted to rec.aviation.piloting,rec.aviation.student
Tman
Hold on while I try to correct some nits in what Bertie said and see
what happens
turning back.
[ many good points supporting this assertion, but... ]
airspeed,
Well, technically, your best LD speed is related to angle of attack, and
not the groundspeed, so that won't change. Your best glide speed
certainly will be less...
Here's why I wonder about that. Let's suppose 65 KAS before and after a
180 turn from a 10 KT headwind. OK, before the turn, your groundspeed
is 55KTS and after the turn your groundspeed is 75KTS. Your intertial
frame of reference is tied to the g/speed, not the a/speed. So -- the
kinetic energy of the aircraft and contents is about 33% higher
(75/55)^2. That energy is only going to come from one place with no
power -- trading in altitude (potential energy) for kinetic energy.
Old April 25th 08, 01:56 AM posted to rec.aviation.piloting,rec.aviation.student
tman inv@lid wrote in
what happens
turning back.
airspeed,
and
OK, not the LD, you're right. but your best glide speed is realted to
your ground speed. To take an extreme example to illustrate this point,
imagine that your published best glide is 70 and you're trying to glide
into a 70 knot headwind. You're going nowhere. Increase your speed and
you will make headway.
In the tailwind scenario, your best glide distance over the ground will
be better at a lower speed than published. the stronger the wind, the
lower the speed required until you arive at your min sink speed.
a
Nope, your inertial frame of reference owes nothing to the ground
whatsoever. None. Zero, nil zilch zippo. You ar entirely a creature of
the air and owe nothing to the ground whatsoever ( except in the
vertical, of course) The earth simply isn't that important in the bigger
scheme of things! If it were, you'd have trouble making left or right
hand tunrs in your car....
Bertie
Old April 25th 08, 02:02 AM posted to rec.aviation.piloting,rec.aviation.student
what happens
See the previous post. There's a change in kinetic energy, but
very, very little. Many people make the mistake of thinking that the
earth has an effect on the airplane. It does, but only vertically, by
gravity. Gravity has no horizontal Component. Like a gyroscope, which
is rigid with respect to space and cares not one bit about the earth,
the airplane's mass, as it moves in the horizontal, is affected only
by its relationship to space and the air it flies in.
That isn't to say that the earth isn't going to get in the
way a little harder. Landing downwind, as with landing into the wind,
involves transferring the weight from the wings to the wheels, and
downwind means much more groundspeed and maybe loss of control as the
roll continues at higher speed while the flight controls feel a
decreasing airspeed, or maybe the airplane will run out of runway.
Bang.
We do illusions created by drift turns with students, usually
in a strong wind and at around 500 feet, so that they can see that the
ball stays centered in the turn while they get the visual impression
that the airplane is skidding or slipping on the downwind and upwind
sides of the turn. The airspeed does not change. Not so's you could
read it. If we put the student under the hood and make him fly on
instruments while we do this, he can't tell us when he's turning into
the wind or out of it. Can't feel anything, can't see any performance
changes on the gauges.
Dan
Old April 25th 08, 02:20 AM posted to rec.aviation.piloting,rec.aviation.student
In your world, it's gonna be pretty hard for a sailplane to circle in
a drifting thermal. In my world, it's not a problem.
Old April 25th 08, 03:41 AM posted to rec.aviation.piloting,rec.aviation.student
Michael Ash
This simply does not make any sense.
Kinetic energy, like velocity, is a relative quantity. You cannot look at
an object and say, "it has X joules of KE". You can only talk about KE
relative to some frame of reference. Just like velocity.
So forget about KE. It's in the same boat as velocity, so look at
velocity. You make a turn and suddenly you gain a bunch of groundspeed.
Where does the extra speed come from? It comes because you're maneuvering
relative to a medium, the air, which is itself moving. Your KE relative to
that medium is exactly the same as it was, so no energy has to come from
anywhere.
Michael Ash
Rogue Amoeba Software
lancair crash scapoose, OR gatt Piloting 10 October 26th 06 03:34 PM
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Owning 0 October 3rd 03 10:17 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
