Lancair crash at SnF
Old April 25th 08, 11:36 AM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
Default Lancair crash at SnF
On Apr 25, 8:31*pm, Stefan wrote:
WingFlaps schrieb:
Try reading the statement again, here it is:
"Now we add in the energy losses from having to accelerate with the
wind and to glide speed."
To summarise your missed point, the pilot control inputs cost energy
that is not factored into simple glide/time analysis.
This is absolutely correct. But then, I dont understand the connection
to your first statement regarding the wind. Additioinal drag by control
input is completely unrelated to the presence or non-presence of wind.
Itls a turn upwind to downwind. That involves 2 direction changes, one
to reverse course and the the other to line up the runway. If there's
wind there will be an effect on line up. Try thinking about more
factors that cost altitude OK?
Cheers
Old April 25th 08, 11:45 AM posted to rec.aviation.piloting,rec.aviation.student
Stefan
All good and fine, and I'm thinking about a lot of factors, btw. also
about human ones which are usually the weak link, but you still have not
explained what you meant when you wrote: "Now we add in the energy
losses from having to accelerate with the wind."
Old April 25th 08, 12:01 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
Yes, I did. I'll explain it one last time. A direction change in a
plane is always due to acceleration (and that means more drag). That's
Newtonian physics. You go from up wind direction (takeoff is usually
up wind) to turn in the wind direction to land down wind. There's an
acceleration, it is a change in _velocity_ it creates drag, it costs
height and that's the important bit. Now do you understand -TURNS are
not free, they cost more height than the distance covered. Get it
now?
Cheers
Old April 25th 08, 12:19 PM posted to rec.aviation.piloting,rec.aviation.student
Dylan Smith
But that's got nothing to do with "having to accelerate with the wind",
that's merely the energy cost of making the turn, which will be the same
whether there's no wind on the ground, or if it's blowing 20 knots.
You're not having to "accelerate with the wind", you're just making a
turn and the energy used up in the turn will be the same whether you're
going from upwind to downwind or downwind to upwind.
Perhaps your original phrase was just a little mis-phrased, because it
does make it look like you've fallen for the "dangerous downwind turn"
myth.
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
Old April 25th 08, 12:23 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
Newtonian physics.
Right.
Wrong.
not free,
Right.
Your're mixing up two completely different things. Of course, turns are
never "free". They cost energy due to higher drag, resulting from higher
speed, higher wingload and control deflection.
*But*: It absolutely doesn't matter whether you turn from headwind into
tailwind or vice versa. Your airspeed does *not* change. (Of course the
vector does, but not its magnitude.) Your groundspeed changes, but
that's not relevant. Your sentence "Now we add in the energy losses from
having to accelerate with the wind" can only be interpreted that you
think groundspeed would matter because you somehow had to "acceleerate"
to catch up with the wind speed when turning from head to tail wind.
Which is utter nonsense, Newtonianly spoken.
Old April 25th 08, 01:00 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
Newtonian physics.
Right.
Now we are at first base!
Wrong.
I see the problem. You don't know what velocity is. It's a VECTOR. It
changes when you turn. If you don't understand this there's not much
point talking about anything that involves physics....
Cheers
Old April 25th 08, 01:12 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
Actually, I know an awful lot about physics.
In everyday's language, the word velocity stands for the _magnitude_ of
the vector. Now if you want me to realise outside some technical or
scientific environment that you use the word velocity in the vector
sense, you better say so explicitely. Still easier would be to say
"direction".
Old April 25th 08, 01:48 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
On Apr 26, 12:12*am, Stefan wrote:
changes when you turn. *If you don't understand this there's not much
So much that you mix up speed and velocity? LOL!
the vector.
Nope. Not even at high school. The magnitude is "speed".
Gosh, this isn't a technical forum? Was my post not including
"technical" terms like acceleration?
"direction".
What does "flying with the wind" imply to you, a direction or a speed?
I'd say the former but I'm only a native English speaker.
Cheers
Old April 26th 08, 09:07 PM posted to rec.aviation.piloting,rec.aviation.student
Help! I Need SomeBooty!
Talk about thick... you don't even have the slightest clue what velocity
really is.
*snicker*
You've been making a supreme fool of yourself all this time, puffing
your chest and calling other people stupid in your usual self
aggrandizing way. Read this and weep, bitch. Maybe some day you'll learn
to not be such an arrogant jackass.
John
Old April 25th 08, 01:26 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
Newtonian physics.
Right.
Wrong.
not free,
Right.
I'm not mixed up, You wanted to read something into what I wrote that
was not there and try to score some point I think Well you were wrong
and you still are. I never said airspeed did I?
One last time, as succinctly as I can: to change direction requires
more energy as extra drag = k.m.dV/dt. dV/dt is acceleration and that
is precisely the term I used. The aircraft does _accelerate_ into the
downwind direction. Airspeed may not change but _velocity_ sure as
hell does -'cos IT'S A VECTOR. Now, the energy needed for the change
in _velocity_ comes from the loss of height during the turn and that's
easy to calculate. It is much harder to estimate the extra drag loss
as this will depend on pilot skill and aircraft design. I hope you
finally understand, cos I'm really starting to find it tiresome trying
to explain to you some basic physics which you seem intent on mis-
interpreting.
I'll give you this last post, any continuance along your previous
lines of putting erroneous words into my mouth I will take as your
being a troll...
Cheers
lancair crash scapoose, OR gatt Piloting 10 October 26th 06 03:34 PM
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Owning 0 October 3rd 03 10:17 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
