#61
Larry Dighera wrote in
: On Fri, 25 Apr 2008 01:27:52 +0000 (UTC), Bertie the Bunyip wrote in : The best way to do it is with a steep bank. Very steep. The bank angle may be quantified: Good grief Larry, you really are an idiot. Of course it can be quatified, but the numbers only tell a minute part of the story. I can categorically state that I can do a 180 with 70 deg bank at VSO 1.2 deadstick and come out the other end in one piece. Can you? Try it using those figures and send my the answer via my Ouiji board. Bertie |
#62
#63
Stefan wrote in news:23401$4811996a$54487369
: Brian schrieb: My mantra to pilots is "an emergency is not the place to be practicing little used skills, try to make an emergency landing as normal as possible" I absolutely agree. But my conclusion is: Practice, practice, practice. Of course this also includes discussing the options during the departure briefing. It's the only way to do it, but you'll still probably break your neck on the day. Bertie |
#64
On 2008-04-24, WingFlaps wrote:
Let's work some real numbers for a 172 at 500'. Say climb was a Vx 59 knots. Firstly, I don't know anyone who routinely climbs out at Vx - certainly not at 500'. Secondly, this is 100 feet below the altitude I stated. IIRC, Vy is for a C172 is in the region of 65 knots - or best glide, and many pilots accelerate to around 70-75kts at 500 feet to get a better view forward, since best rate in many parts of the world isn't critical to maintain once you're above a couple of hundred feet. pilot carries out some trouble checks say 10s. Calls on the radio =10 s and plans his return. The sequence is aviate, navigate, communicate. Most pilots I know won't touch the radio with a problem at low altitude. The pilot I know who did make the turnback from 600 feet certainly didn't, he just turned back. However, in his situation it was pretty obvious the engine had lunched itself so there was no time spent 'debugging' the problem. (For the record, the only engine stoppage I had on takeoff was at 50 feet - the decision to land straight ahead was very easy and fast to make). Note that 20s have probably elapsed. The plane has already travelled ~0.4 miles and at a 10:1 glide ratio has lost 200' (assuming he did get it to best glide in the first place). Can he make 2 turns and land back -no way! If the pilot does that, then yes - no way. However, the pilots I've know who've had low engine failures have never yakked on the radio, nor have they spent 10s debugging the problem! you 35 seconds. 45 seconds lost = 450 feet! Now we add in the energy losses from having to accelerate with the wind and to glide speed. You do NOT have to accelerate with the wind! You are a creature of the air, turning downwind does not involve a loss of airspeed! I agree that the primary concern is to not stall. However, pilots must be prepared to make a decision rather than 'default straight ahead' - the decision, whatever it is, must be made quickly and you must not stall. And yes, sometimes, turning back to the runway is possible and this will depend on the situation - altitude and the suitability of terrain, pilot proficiency etc. When you're about to push the throttle forwards, you SHOULD have some kind of a plan if it goes pear shaped. What's the wind doing? Is there a crosswind? What's the terrain surrounding the airfield like? If you lose power at point X what is the best course of action, and at point Y what is the best course of action? The best courses of action (other than 'do not stall') may not be a fixed prescription. -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
#65
On Apr 25, 8:31*pm, Stefan wrote:
WingFlaps schrieb: Try reading the statement again, here it is: "Now we add in the energy losses from having to accelerate with the wind and to glide speed." To summarise your missed point, the pilot control inputs cost energy that is not factored into simple glide/time analysis. This is absolutely correct. But then, I dont understand the connection to your first statement regarding the wind. Additioinal drag by control input is completely unrelated to the presence or non-presence of wind. Itls a turn upwind to downwind. That involves 2 direction changes, one to reverse course and the the other to line up the runway. If there's wind there will be an effect on line up. Try thinking about more factors that cost altitude OK? Cheers |
#66
On Apr 25, 9:31*pm, Dylan Smith wrote:
On 2008-04-24, WingFlaps wrote: Let's work some real numbers for a 172 at 500'. Say climb was a Vx 59 knots. Firstly, I don't know anyone who routinely climbs out at Vx - certainly not at 500'. Secondly, this is 100 feet below the altitude I stated. IIRC, Vy is for a C172 is in the region of 65 knots - or best glide, and many pilots accelerate to around 70-75kts at 500 feet to get a better view forward, since best rate in many parts of the world isn't critical to maintain once you're above a couple of hundred feet. I can see you missed the point entirely. By the way, Vy is never at best glide (it is above that ~69knots in a 172) -perhaps you would like to revise what determines Vy? My point was to ilustrate the impossible turn with some concrete numbers instead of the handwaving BS that seems pervasive in this topic. Good luck on your first engine failure during climb out, if you turn back I hope you make it. but you'll have a better chance going straight ahead... Cheers . |
#67
WingFlaps schrieb:
Itls a turn upwind to downwind. That involves 2 direction changes, one to reverse course and the the other to line up the runway. If there's wind there will be an effect on line up. Try thinking about more factors that cost altitude OK? All good and fine, and I'm thinking about a lot of factors, btw. also about human ones which are usually the weak link, but you still have not explained what you meant when you wrote: "Now we add in the energy losses from having to accelerate with the wind." |
#68
On Apr 25, 10:45*pm, Stefan wrote:
WingFlaps schrieb: Itls a turn upwind to downwind. That involves 2 direction changes, one to reverse course and the the other to line up the runway. If there's wind there will be an effect on line up. Try thinking about more factors that cost altitude OK? All good and fine, and I'm thinking about a lot of factors, btw. also about human ones which are usually the weak link, but you still have not explained what you meant when you wrote: "Now we add in the energy losses from having to accelerate with the wind." Yes, I did. I'll explain it one last time. A direction change in a plane is always due to acceleration (and that means more drag). That's Newtonian physics. You go from up wind direction (takeoff is usually up wind) to turn in the wind direction to land down wind. There's an acceleration, it is a change in _velocity_ it creates drag, it costs height and that's the important bit. Now do you understand -TURNS are not free, they cost more height than the distance covered. Get it now? Cheers |
#69
#70
Shirl wrote:
WingFlaps wrote: I've also heard a lot of BS in this thread about not having good palces to put the plane. There is nearly always somewhere flat to put the plane within 90 degrees of the runway centerline -even a road. Malls have big parking lots! I don't know about where you live, but malls here have lots of light poles, concrete islands, park-and-rest benches and ... and ... vehicles everywhere. And having gone through it once, I'm no longer fooled by what *looks* "flat" at 500, or even 50 feet. I'd rather hit a bus shelter or light poles @ 40-50 MPH than go in inverted after a stall/spin @ 200-300 AGL. |
lancair crash scapoose, OR | gatt | Piloting | 10 | October 26th 06 03:34 PM |
Lancair IV | Dico Reyers | Owning | 6 | October 19th 04 11:47 PM |
Lancair 320 ram air? | ROBIN FLY | Home Built | 17 | January 7th 04 11:54 PM |
Lancair 320/360 kit wanted!!! | Erik W | Owning | 0 | October 3rd 03 10:17 PM |
Lancair IVP | Peter Gottlieb | Home Built | 2 | August 22nd 03 03:51 AM |
