Excellent post..
I was taught to normally turn cross wind at 500 ft AGL.. if taking off on a short single runway. Long runway - keep it in front of you as long as it is usable.. Dave On Fri, 25 Apr 2008 01:17:48 -0700 (PDT), Brian wrote: One way to practice this would be to establish a "runway altitude" at, say, 1000ft AGL, get the airplane into takeoff configuration on heading at that altitude over a road or something, simulate a failure at a specified altitude--say, 1,500 feet--and see what altitude you're at when you get back to your reciprocal heading. If it's above your starting altitude, you made it. Actually this is very similar to how I do have pilots simulate this. However it is often not quite realistic for a couple of reasons. 1. The illusion of speed. When done for real the airplane will seem to be fly much faster than when done close to the ground, especially if there is much wind. I am thoroughly convinced the most stall spin accidents happen for two reasons. A. is the illusion of speed when the pilot thinks the are going faster than the are. B. Is the pilot isn't thinking they are in a situation where a stall is possible, and thus does not recognize it as a stall when it occurs. (Very similar to A) 2. Decent rate. It may be possible to get back to the runway and line up on the runway but not arrest the descent rate. This is especially important in aircraft with higher wing loadings. Make sure that when you about 100 feet above your runway altitude that you are still at you minimum (normal) power off approach speed. True this may be a better option than putting it into the trees but hitting the runway at a high decent rate because you are too slow to round out and flare will probably only be a Fair landing. (Good = Airplane will need some repair, Fair = occupants may need some repair as well) 3. Proficiency. Look back through the group at the arguments for and against power on landings VS full power off. Also look at the arguments for Full Flaps vs Flaps as Needed.vs. No Flaps. If you are one of the pilots where less than 50% of your landings (in the airplane you are flying(Gliders fit here)) are power off then Land Straight ahead should be your only option. Same thing applies if you land with full flaps more that 50% of the time. Again the same should apply if you are not thoroughly familiar with the airplane you are flying. Are you beginning to see why as a rule landing straight ahead is almost always the best option? My mantra to pilots is "an emergency is not the place to be practicing little used skills, try to make an emergency landing as normal as possible" 4. Options. One of the biggest problems with trying to go back to the runway is the commitment to it. Once you commit to it there are usually little else available for options that will have a good outcome. If open fields surround the airport you may have the option of landing somewhere else. But in order to make it back to the runway you will have little time to evaluate any other options, and by the time you figure out it isn’t going to work you will likely be out of airspeed, altitude and ideas. 5. The Pattern. My practice of the maneuver has shown that usually it can be done from 500 feet in most training aircraft if the pilot is proficient in the maneuver and the aircraft. This is why I generally teach to start the crosswind turn at 500 feet. Once you are at 500 feet and have your turn established your chances of making back to the runway usually change from slim to good and it is much more likely that you will be able to make the runway as an option. At this point you are not longer climbing straight ahead and are entering the crosswind. Usually from this point on the runway should be an option if you have a power failure in the pattern. Again proficiency and practice are the key as you will be landing power off, downwind and using flaps as required. 6. Semantics. We tend to say land straight ahead, But I don’t know of any flight instructor that does not teach that a 45 degree change in heading left or right is not appropriate and often desirable when dealing with a power failure immediately after takeoff to take advantage of more desirable terrain. Brian CFIIG/ASEL |
lancair crash scapoose, OR | gatt | Piloting | 10 | October 26th 06 03:34 PM |
Lancair IV | Dico Reyers | Owning | 6 | October 19th 04 11:47 PM |
Lancair 320 ram air? | ROBIN FLY | Home Built | 17 | January 7th 04 11:54 PM |
Lancair 320/360 kit wanted!!! | Erik W | Owning | 0 | October 3rd 03 10:17 PM |
Lancair IVP | Peter Gottlieb | Home Built | 2 | August 22nd 03 03:51 AM |
