Lancair crash at SnF
Old April 25th 08, 02:25 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
Default Lancair crash at SnF
"Maxwell" luv2^fly99@cox.^net wrote in news:yckQj.67983$y05.63596
@newsfe22.lga:
WingFlaps wrote in news:ac05ca83-bbc8-4c3b-
9469-
On Apr 25, 8:31 pm, Stefan wrote:
WingFlaps schrieb:
Try reading the statement again, here it is:
"Now we add in the energy losses from having to accelerate with
wind and to glide speed."
To summarise your missed point, the pilot control inputs cost
energy
that is not factored into simple glide/time analysis.
This is absolutely correct. But then, I dont understand the
connection
to your first statement regarding the wind. Additioinal drag by
control
input is completely unrelated to the presence or non-presence of
wind.
Itls a turn upwind to downwind. That involves 2 direction changes,
one
to reverse course and the the other to line up the runway. If
there's
wind there will be an effect on line up. Try thinking about more
factors that cost altitude OK?
It's not so much the loss of altitude that will get you in this
manuever. it's the probable loss of control trying to manuever around
back towards the field.
Firstly, in any emergency that hasnt been drilled, you will have a
moment where you will be sitting there with your mouth open in utter
disbelief of what has just happened. in fact, even if you have
drilled
for it you will still have this moment, but if it's been practiced
moment you begine to do something about it will be sooner coming.
While you're sitting there wondering what's going on, the speed will
be
bleeding off. Not good. Then, you will have to manuever the airplane
around using rapid manuevering at a relatively high bank angle if
you're
going to make it (I'm assuiming you're still pretty low) and if you
aren't 100% au fait with this sort of flying you're going to be very
lucky to be able to maintain control of the airplane before the
ground
reaches up and smites you. This is less about the maths than the
pilot;'s proficiency. The pilot who is proficient enough to do this
will
have determined an altitude above which he knows it is possible to do
it
and so the question will not be one of whether it's within the
performance capabilities of the airplane, but one of whether the
pilot
can accurately control the airplane through the required manuever.
Here is what you'll have to do the instant the engine gives up:
Smooothly lower the nose as you roll just as smoothly, but as quickly
as
possible, towards the crosswind, if any. You will have to continue to
lower the nose as the turn, which should ideally have at least 60 deg
of
bank, is completed. you should be just nibbling the stall during
this,
and , needless to say, perfectly co-ordinated. Pitch control is now
critical as what you're trying to do is cheat physics by offloading
wing as you turn. a 60 degree bank in level flight will give you a
stall
speed of 1.4 VSO and you should be below that so you're right on the
edge. This is all about having very good seat of the pants capability
based on experience. As you approach the desired heading to your
landing
spot, you have to smoothly roll out and get the nose up and back to a
good glide attitude. You'll have sacrificed some altitude doing the
sharp turn, but far less than you would have making a wider turn with
a
gentle bank. As you level the wings, you should be on, or close to,
your
desired glide speed. This is a difficult manuever to pull off. Even
practicing at a bit of altitude has some risks. you're going to pull
a
bit of G and it's easy to lose the plot and either spin out of it or
overstress the airframe praciticing it unless you know what you're
doing. It's not really something that most pilots should even
consider.
Someone flying 25 hours a year s unlikely ever to become sharp enough
to
do this reliably. I certainly wouldn't try it now unless there was no
choice.
There's a lot of crap talked about turning back and most of the
accidents occuring as a result of this are because the pilot has
heard
it's possible and decides to learn how to do it when it actually
happens. Most modern flight manuals tell you it isn't possible but
this
advice is ignored by guys who reckon they're a cut above because they
did the math or tried it once or twice at altitude or because they
read
about it here.
Bertie
Now come on, Dudley wrote this for you, didn't he?
Nope.
Bertie
lancair crash scapoose, OR gatt Piloting 10 October 26th 06 03:34 PM
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Owning 0 October 3rd 03 10:17 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
