Will the V-22 Osprey be a harder RPG target?
Old November 22nd 03, 04:35 AM
Kevin Brooks
John Hairell wrote in message . ..
On Fri, 21 Nov 2003 23:03:53 +0900, Gernot Hassenpflug
(Henry J. Cobb) writes:
Will the increased cruising speed of the Osprey make it a better bet
for going downtown in the third world than the current fleet of
helicopters?
It will be a harder target because it doesn't stay in the air long
enough to get a good shot....
It will still have to come to a hover to drop off troops, and will
still be a target.
True, but which would you choose--an aircraft that remains within the
primary engagement envelope of *most* of the threat AAW systems
throughout the entire (slow) flight profile, or one that can operate
above it if necessary and flies substantially faster to boot?
Brooks
John Hairell )
Old November 22nd 03, 04:58 AM
Peter Gottlieb
"Kevin Brooks" wrote in message
om...
I just hope they make it robust enough. Let them prove me wrong, but so far
I don't have a good feeling about how complex it is.
Old November 22nd 03, 03:47 PM
Kevin Brooks
"Peter Gottlieb" wrote in message . net...
om...
The CH-46 is complex. The CH-47 is complex. Even the UH-60 is rather
complex. Heck, all modern multi-engine helos are complex, as are most
of the single engine new aircraft. If by robust you mean
bulletproof--no, it will not acheive that, but neither will any other
airframe. But I believe its survivability will be enhanced by its
ability to fly faster/higher, and I would guess that its climb rate
will be another survivability advantage versus a lot of AAW threats.
Brooks
Navy special operations command version of the V-22 Osprey tilt-rotor aircraft Larry Dighera Military Aviation 25 September 30th 03 01:05 AM
Squadron formed to test Osprey for combat readiness Otis Willie Military Aviation 0 August 30th 03 07:33 PM
Osprey vs. Harrier Stephen D. Poe Military Aviation 58 August 18th 03 03:17 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 07:31 PM
