Will the V-22 Osprey be a harder RPG target?
Old November 22nd 03, 03:47 PM
Kevin Brooks
"Peter Gottlieb" wrote in message . net...
"Kevin Brooks" wrote in message
om...
True, but which would you choose--an aircraft that remains within the
primary engagement envelope of *most* of the threat AAW systems
throughout the entire (slow) flight profile, or one that can operate
above it if necessary and flies substantially faster to boot?
I just hope they make it robust enough. Let them prove me wrong, but so far
I don't have a good feeling about how complex it is.
The CH-46 is complex. The CH-47 is complex. Even the UH-60 is rather
complex. Heck, all modern multi-engine helos are complex, as are most
of the single engine new aircraft. If by robust you mean
bulletproof--no, it will not acheive that, but neither will any other
airframe. But I believe its survivability will be enhanced by its
ability to fly faster/higher, and I would guess that its climb rate
will be another survivability advantage versus a lot of AAW threats.
Brooks
Old November 24th 03, 12:47 AM
Simmsac
The composite body is
hell for stout. The surviving AC at the Marana AZ crash hit the ground
at more than 600 ft/min vertical speed. No damage.
Dana, that airframe is now a maintanance trainer. It was so badly damaged it
was not repairable...AL
Old November 25th 03, 05:15 PM
Chad Irby
(robert arndt) wrote:
(Henry J. Cobb) wrote in message
. com...
Will the increased cruising speed of the Osprey make it a better bet
for going downtown in the third world than the current fleet of
helicopters?
Absolutely not. The V-22 is a transitional flight machine that will
have to transition to achieve level flight and land, making it highly
vunerable.
So, in your world, an aircraft coming in fast then landing slow is
supposed to be *more* vulnerable than one coming in slow and landing
slow? Apparently, you've found a gap in the basis of modern warfare...
"speed is good."
The helicopter, by comparison might be slower in level
flight but it takes a lot less skill and time to land.
Not really. The V-22 is supposed to be very nice to fly, and only has a
couple of tricky flight regimes, like the vortex ring state problem (as
long as you keep it below 800 feet per minute descent rates at slow
forward aispeeds, you're not going to run into that). VRS can affect
some normal copters at the same high sink rates, too...
The helicopter also has the advantage of not falling out of the sky
like a brick everytime there is a inflight mechanical failure.
Wow, you really are trying here. But the kinds of things that could
make the Osprey fall out of the sky are the same things that can make
big copters fall out of the sky. Lose a rotor, lose a transmission, et
cetera.
BTW, there is nothing new about the V-22. The Germans had two
transitional flight aircraft in the design stage at the end of WW2-
from Focke Achgelis and WeserFlug.
A cartoon on a piece of drafting paper is not what most people call
"design stage."
It's kind of sad, really. Your whole point seem to be "the Osprey
sucks, but the Germans thought of this sucky aircraft first and never
built one."
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Navy special operations command version of the V-22 Osprey tilt-rotor aircraft Larry Dighera Military Aviation 25 September 30th 03 01:05 AM
Squadron formed to test Osprey for combat readiness Otis Willie Military Aviation 0 August 30th 03 07:33 PM
Osprey vs. Harrier Stephen D. Poe Military Aviation 58 August 18th 03 03:17 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 07:31 PM
