Lancair crash at SnF
Old April 27th 08, 10:23 PM posted to rec.aviation.piloting
Big John
Default Lancair crash at SnF
On Thu, 24 Apr 2008 15:40:55 -0700 (PDT), WingFlaps
On Apr 25, 10:16*am, Stefan wrote:
WingFlaps schrieb:
(the stall is now damn close -better
hope there's no significant wind)
Now we add in the energy losses from having to
accelerate with the wind and to glide speed.
Arrrgh! Not the old "turn into downwind" legend again! Better work out
your understanding of physics before publicly reasoning about turns.
Try reading the statement again, here it is:
"Now we add in the energy losses from having to accelerate with the
wind and to glide speed."
Now perhaps you would like to revise some physics and try to critcise
it for us?
I await your stumbling analysis of my words with mild amusement.
Cheers
Long time ago in the 30's I saw on a couple of occasions a Cub take
off in a strong head wind 25+ mph and make a 180 degree turn to down
wind. They then started losing altitude and mushed into the ground
nose high. Any idea why? Pilot's said they had full throttle and
proper RPM showed on engines until impact.
Big John
Big John
Old April 27th 08, 10:43 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Big John wrote in
out
it for us?
Cheers
Wind gradient. As they climbed, the wind would increase and they'd lose
some airspeed until they were on the backside of the power curve.same
thing would happen if you took off with strong tailwind in the first
place. Also, the poorer climb angle even without the wind gradient would
cause many to get the nose up a bit too much as well if they were not
used to it.
Bertie
Old April 28th 08, 05:23 AM posted to rec.aviation.piloting
Maxwell[_2_]
Big John wrote in
out
it for us?
Cheers
used to it.
Bertie
Turn your head 90 degrees and it will change the dynamics of all of it.
That's the way wind tunnels work, child.
Old April 28th 08, 05:24 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
Default maxwell crashes agin..
"Maxwell" luv2^fly99@cox.^net wrote in news:3jcRj.58626$QC.41863
@newsfe20.lga:
Big John wrote in
out
turns.
critcise
it for us?
Cheers
lose
would
used to it.
Bertie
it.
Yeh, sure fjukktard.
Bertie
Old April 28th 08, 03:02 PM posted to rec.aviation.piloting
out
it for us?
Cheers
used to it.
Bertie
I think someone screwed up. As he turned, his airspeed would
remain constant and in the turn he would begin to move sideways over
the ground, and as he completed the turn his groundspeed would be much
higher but his airspeed the same as before. The airplane has lots of
time to make the shift in direction and it's not an instantaneous
change in vectors.
The sideways drift over the ground (which is mentioned here
only as a reference for visual flying, not that the airplane cares
about the earth's mass) might have caused him to think he was slipping
big time, so he pumped in a bunch of rudder, skidding it badly and
spun it in. And that's the reason we teach "Illusions Caused by
Drift."
Dan
Old April 28th 08, 03:12 PM posted to rec.aviation.piloting
wrote in
work
out
turns.
critcise it for us?
Cheers
down wind. They then started losing altitude and mushed into the
ground nose high. Any idea why? Pilot's said they had full throttle
and proper RPM showed on engines until impact.
lose some airspeed until they were on the backside of the power
curve.same thing would happen if you took off with strong tailwind in
the first place. Also, the poorer climb angle even without the wind
gradient would cause many to get the nose up a bit too much as well
if they were not used to it.
Bertie
change in vectors.
Drift."
Yeah, that's a big factor in the downwind turn scenario, but I also find
few really appreciate the wind gradient element as well. It's quite
significant close to the ground and it's a big problem with downwind
takeoffs as well.
Bertie
lancair crash scapoose, OR gatt Piloting 10 October 26th 06 03:34 PM
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Owning 0 October 3rd 03 10:17 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
