limit of trim = limit of travel?
Old April 28th 08, 05:04 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
Default limit of trim = limit of travel?
"Maxwell" luv2^fly99@cox.^net wrote in
"Buttman" wrote in message
Bertie the Bunyip wrote:
Buttman wrote in
WingFlaps wrote:
On Apr 27, 7:03 am, Mxsmanic wrote:
I just tried a few experiments
No, that doesn't sound right.
The stall horn is supposed to sound before the stall speed is
reached.
Cheers
"supposed to", but doesn't always. I've flown planes (especially
cessnas with their crappy cereal-box-toy-quality plastic stall
horns) that don't go off at all, but will test fine on the ground.
What, you didn't stick chewing gum in them to fail them so your
students would learn what it was like when they failed?
Bertie
Oh bertie, you're such a card
Na, not really. Just a self made prick.
Moi? never. Nope. I just treat people exactly as the expect to be
treated.
Fjukktard.
Bertie
  #53
Old April 28th 08, 05:06 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Default limit of Maxwell's understanding. pretty small..
Mxsmanic wrote in
Bertie the Bunyip writes:
I've flown a few that couldn't even be trimmed for slow flight or
approach ( pre war stuff) The trim was apparently only considered
to be useful for cruise.
Interesting. I was flying my simulated Cessna 182 and it didn't
seem like the pitch trim fully deflected the elevators even with the
trim all the way over (that is, I could still move the yoke to get
even further deflection). It sounds like this is true to life.
Nothing about a sim is true to life. It's a toy. Different airplanes
have different authorits. i can loop my Citabira with the pitch trim.
Bertie
YEAH!!!! Sure ya can lamer.
As if your belief one way or another makes a difference.
Bertie
  #54
Old April 28th 08, 05:27 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Default limit of Squirty's understanding. pretty small..
"Maxwell" luv2^fly99@cox.^net wrote in news:HncRj.58645$QC.35221
@newsfe20.lga:
Mxsmanic wrote in
airplanes
trim.
Bertie
Bertie
Yeah, no ****. As if yours does either wannabe.
Mine? mine doesn't matter at all...Only your performance matters...
Bertie
  #55
Old April 28th 08, 05:28 AM posted to rec.aviation.piloting
Maxwell[_2_]
Mxsmanic wrote in
Bertie
Bertie
  #56
Old April 28th 08, 01:58 PM posted to rec.aviation.piloting
Peter Dohm
"Maxwell" luv2^fly99@cox.^net wrote in message
Mxsmanic wrote in
Bertie
Bertie
Well, Max, in addition to my other doubts, I now doubt that you ever even
flew a "thrown" model as a kid!
Peter
  #57
Old April 28th 08, 02:39 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Peter Dohm" wrote in
Mxsmanic wrote in
or approach ( pre war stuff) The trim was apparently only
considered to be useful for cruise.
the trim all the way over (that is, I could still move the yoke
to get even further deflection). It sounds like this is true to
life.
airplanes have different authorits. i can loop my Citabira with
the pitch trim.
Bertie
Bertie
even flew a "thrown" model as a kid!
They're properly called a Hand Launched Glider, or HLG or "chuck"
glider.
Bertie
  #58
Old April 28th 08, 04:29 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Sat, 26 Apr 2008 10:09:16 -0800, Scott Skylane
Stealth Pilot wrote:
/snip/
trim has nothing to do with the movement limits on control surfaces.
/snip/
Stealth,
This is not universally true. On the Douglas DC-6, for instance,
elevator "up" travel is limited by the elevator trim position. Dialing
in the last 5 degrees of nose up trim allows an extra 3 degrees of
elevator "up" travel. This was done to limit elevator "up" movement
with aft CG loading conditions.
Happy Flying!
Scott Skylane
ok you successfully cite the one instance possibly :-) I defer to your
knowledge of the obscure.
stops of the type I mentioned are a mandated requirement in my country
for the environment I play in.
Stealth Pilot
  #59
Old April 28th 08, 04:36 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Sun, 27 Apr 2008 10:39:26 -0700 (PDT),
On Apr 26, 3:56 pm, Buttman wrote:
"supposed to", but doesn't always. I've flown planes (especially cessnas
with their crappy cereal-box-toy-quality plastic stall horns) that don't go
That's not hard to fix. The plastic fitting inside the leading
edge cracks and leaks. Sometimes the sun's heat warps and shrinks the
fitting so that it no longer seals against the LE and leaks at that
point, too. Any leakage will kill the horn. The horn itself has a
little replaceable reed in it, costs something like 79 cents from
Cessna. And I think that leaky cabin doors sometimes have something to
do with it; the horn uses suction to drive it, and a leaky door (among
other things) can drop the cabin pressure a little, reducing the
differential so that the horn doesn't sound well. The older and better
system (still used on more expensive Cessnas and other airplanes) has
the vane that works a $300 microswitch assembly to fire an electric
horn. The microswitch gets dust in it and doesn't contact properly, so
you soak it in some brake cleaner or isopropyl and blow it out,
clicking it all the while.
Dan
$300 ????????????
the microswitch in my Tailwind cost $1.25 from Tandy. it is held in
with tape to make a jamb fit.
been working perfectly for 300 hours flying.
Stealth Pilot
  #60
Old April 28th 08, 04:43 PM posted to rec.aviation.piloting
Peter Dohm
"Stealth Pilot" wrote in message
/snip/
/snip/
Stealth,
Happy Flying!
Scott Skylane
Stealth Pilot
Not nearly so obscure as you sugest. Aircraft with a fully trimming
stabilizer have a result result of adding to the effective elevator
authority--examples are the Piper Cub and all of the "straight tail"
Mooneys.
Peter
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
speed limit in class B Andrey Serbinenko Piloting 0 July 23rd 06 04:05 AM
Pegasus life limit Mark628CA Soaring 2 March 30th 06 10:37 PM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
Pushing the limit Dan Shackelford Military Aviation 20 September 14th 03 10:27 PM
