On Apr 30, 4:52 pm, Pat Russell wrote:
WHY DOES IT REPORT ONLY TWO OF THEM? Because this is a rescue device. When is it ever necessary to rescue someone floating in mid air? SPOT was designed for HIKERS, and I'm sure they think it's perfect. I carry mine in the car when driving between Denver and Colorado Springs, as mobile phone coverage is spotty if you get more than a few miles from I-25. If I need help while soaring, it will be on the ground. If it was designed for pilots, it would cost at least 3 (10?) times as much and do half of what this one does... :-( But there's always hope that a more pilot friendly device can be built on top of this one by adding a few more buttons or at least changing the firmware. They will likely charge a bit more for the service as we'd like to have a better chance of our live track getting received, so it will need to send more position reports, thus cluttering the bandwidth, etc... -Tom |
5Z wrote:
But there's always hope that a more pilot friendly device can be built on top of this one by adding a few more buttons or at least changing the firmware. They will likely charge a bit more for the service as we'd like to have a better chance of our live track getting received, so it will need to send more position reports, thus cluttering the bandwidth, etc... I looked at implementing a SPOT-like device using this technology years before SPOT was announced, the main problem (aside from being transmit only) is that data messages to the Globalstar network contain only a small number of bits (56?). After one encodes latitude and longitude at a useful resolution, about all that is left is a few bits to encode "OK", "HELP", etc. I suspect an upgrade would require more satellites, something which Globalstar may not be able to afford... Marc |
I phoned England where the provider of the 911 is located
asking to test my SPOT,s 911 I was told that there are not willing and able to have the system tested ! So if I can not test the 911 like a ELT what is the use, all it provides me with is a false security. By the way just try the SPOT warranty system, make sure you have your credit card on hand because you pay for everything even if it fails when you take it out of the box "Marc Ramsey" wrote in message news ![]() 5Z wrote: But there's always hope that a more pilot friendly device can be built on top of this one by adding a few more buttons or at least changing the firmware. They will likely charge a bit more for the service as we'd like to have a better chance of our live track getting received, so it will need to send more position reports, thus cluttering the bandwidth, etc... I looked at implementing a SPOT-like device using this technology years before SPOT was announced, the main problem (aside from being transmit only) is that data messages to the Globalstar network contain only a small number of bits (56?). After one encodes latitude and longitude at a useful resolution, about all that is left is a few bits to encode "OK", "HELP", etc. I suspect an upgrade would require more satellites, something which Globalstar may not be able to afford... Marc |
On Apr 30, 7:56 pm, "D.Rizzato" wrote:
I phoned England where the provider of the 911 is located asking to test my SPOT,s 911 I was told that there are not willing and able to have the system tested ! So if I can not test the 911 like a ELT what is the use, all it provides me with is a false security. Except for a few bits in the message itself, there is no difference between 911, HELP, or OK. You can test it to your heart's content by sending either of the latter messages to yourself or friends. I don't know about the UK, but in the US, dialing 911 from my house just to see if it works is not permitted. So I have to trust that if I get a dial tone, I'll be able to reach 911. It's possible that the connection between the SPOT message handling center and their 911 center is down, but I assume the message handling system will keep trying until a human acknowledges the request. It's also possible the 911 button on your unit is broken, but then the LED won't flash, and you'll know it. If the LED flashes, and if a recent OK message went out, you can be fairly confident that the 911 will go out as well. As for customer support, I've had excellent response with general and technical questions. Every business, no matter how good, will occasionally **** someone off and with the internet, we find out about it much more often that in the past. Bottom line, this device is damned inexpensive for what it provides. -Tom |
5Z wrote:
Except for a few bits in the message itself, there is no difference between 911, HELP, or OK. You can test it to your heart's content by sending either of the latter messages to yourself or friends. I don't know about the UK, but in the US, dialing 911 from my house just to see if it works is not permitted. So I have to trust that if I get a dial tone, I'll be able to reach 911. Nor do you turn on your ELT and wait for search and rescue to show up, to see if it "works". It's possible that the connection between the SPOT message handling center and their 911 center is down, but I assume the message handling system will keep trying until a human acknowledges the request. It's also possible the 911 button on your unit is broken, but then the LED won't flash, and you'll know it. If the LED flashes, and if a recent OK message went out, you can be fairly confident that the 911 will go out as well. If you don't trust their 911 service, make the "send help" button your personal 911, with a friend/wife/employee with email or a cell phone ready to call search and rescue. Not as elegant, but you can "test" it. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Apr 30, 6:30*pm, Marc Ramsey wrote:
5Z wrote: But there's always hope that a more pilot friendly device can be built on top of this one by adding a few more buttons or at least changing the firmware. *They will likely charge a bit more for the service as we'd like to have a better chance of our live track getting received, so it will need to send more position reports, thus cluttering the bandwidth, etc... I looked at implementing a SPOT-like device using this technology years before SPOT was announced, the main problem (aside from being transmit only) is that data messages to the Globalstar network contain only a small number of bits (56?). *After one encodes latitude and longitude at a useful resolution, about all that is left is a few bits to encode "OK", "HELP", etc. *I suspect an upgrade would require more satellites, something which Globalstar may not be able to afford... Marc dont you just need 1 bit to encode "okay" vs "/okay" alright, 2 bits if you want "okay", "/okay", "fallen can't get up" |
SPOT | D.Rizzato | Piloting | 0 | February 5th 08 12:42 AM |
SPOT | D.Rizzato | Owning | 0 | February 5th 08 12:42 AM |
SPOT | D.Rizzato | Home Built | 0 | February 5th 08 12:39 AM |
Bush is ashamed of what was written in his military records | WalterM140 | Military Aviation | 0 | August 12th 04 11:49 PM |
It's ashamed that vOX POOPuli... | B2431 | Military Aviation | 0 | February 13th 04 07:10 PM |
