Ted,
Nice! I signed up Frank (TA) On Apr 23, 11:56*am, Tuno wrote: Okay, this is partially a plug for my own web site, but after helping a couple of WinPilot users set up their data files, I want to offer these suggetions to other users who might be struggling with the same setup questions: (1) As mentioned on WinPilot's web page, the airspace data downloaded there is based on obsolete DAFIF. Skip it! (Especially if you fly near Phoenix.) The .TXT file (OpenAir(TM) format) you get atwww.justsoar.com is what you should specify in the "Additional Airspace" field of the "FILES" setup section. That's all you need for accurate airspace. (2) If you provide a turnpoint file atwww.justsoar.comto provide your geographic area of interest (recommended), the turnpoint file you get back is the same file appended with all of the FAA's airports in the same area (i.e., those that are not already in your original turnpoint file), based on *latest* FAA airport data (a different database than the what the airspace comes from). If you do this, then do NOT specify any states under "Aeronautical Info", if you don't want redundant airport entries displayed on the map. ~ted/2NO |
NMEA+vario+ASI data stream for WinPilot Pro | Tuno | Soaring | 5 | March 28th 07 03:02 PM |
WinPilot ADV/PRO Users Group interest? | Frank | Soaring | 3 | January 26th 07 04:52 AM |
Winpilot Polar Data for LS8-18 | Jürgen Becker | Soaring | 3 | August 12th 05 12:23 PM |
How to get winpilot data base changed? | [email protected] | Soaring | 2 | August 9th 05 07:16 PM |
WinPilot polar file data points | [email protected] | Soaring | 0 | April 21st 05 03:18 AM |
