(USA) Data suggestion for WinPilot users
Old May 1st 08, 04:14 AM posted to rec.aviation.soaring
Frank[_1_]
Default (USA) Data suggestion for WinPilot users
Ted,
Since you are obviously responding to one of the many WinPilot
frustrations that the developer won't respond to, would you consider
expanding your website to include an 'unofficial' WinPilot users
forum?
Just a thought.... ;-)
Frank
On Apr 23, 11:56*am, Tuno wrote:
Okay, this is partially a plug for my own web site, but after helping
a couple of WinPilot users set up their data files, I want to offer
these suggetions to other users who might be struggling with the same
setup questions:
(1) As mentioned on WinPilot's web page, the airspace data downloaded
there is based on obsolete DAFIF. Skip it! (Especially if you fly near
Phoenix.) The .TXT file (OpenAir(TM) format) you get atwww.justsoar.com
is what you should specify in the "Additional Airspace" field of the
"FILES" setup section. That's all you need for accurate airspace.
(2) If you provide a turnpoint file atwww.justsoar.comto provide
your geographic area of interest (recommended), the turnpoint file you
get back is the same file appended with all of the FAA's airports in
the same area (i.e., those that are not already in your original
turnpoint file), based on *latest* FAA airport data (a different
database than the what the airspace comes from). If you do this, then
do NOT specify any states under "Aeronautical Info", if you don't want
redundant airport entries displayed on the map.
~ted/2NO
NMEA+vario+ASI data stream for WinPilot Pro Tuno Soaring 5 March 28th 07 03:02 PM
WinPilot ADV/PRO Users Group interest? Frank Soaring 3 January 26th 07 04:52 AM
Winpilot Polar Data for LS8-18 Jürgen Becker Soaring 3 August 12th 05 12:23 PM
How to get winpilot data base changed? [email protected] Soaring 2 August 9th 05 07:16 PM
WinPilot polar file data points [email protected] Soaring 0 April 21st 05 03:18 AM
