Alan wrote:
Other factors include the output voltage under load at discharge -- a lead acid battery is rated to 10.2 to 10.5 volts for a "12 volt" battery at discharge. Powersonic uses 10.5 volts for 5 to 20 hour discharge rates. Unfortunately, most 12 volt radios and devices are designed for a charging electrical system, with a voltage of about 14 volts. Most panel mounted radios (definitely for Dittel and Becker radios) bought new in the last 20 years (and even some older ones) meet the current requirements to function properly to 10.5 volts, and at even lower voltages, but with reduced power output. "Very old" radios likely will have problems at 10.5 volts. I have no idea what the percentage of "old" and "new" are. When the battery is down to 75% of the expected voltage for the radio, not all of them work. I have had aircraft radios that would not transmit below about 11.5 volts, at which point the battery would be still above 50% charged. Powersonic shows it's batteries have only 25% capacity left at 11.5 volts. I haven't checked other brands, but believe they are the same for the batteries we use in our gliders. Lead acid batteries are normally rated for capacity at a 20 hour rate of discharge. A 7 AH battery would deliver 7000 / 20 = 350 mA for 20 hours. Faster discharge rates result in less capacity being available (look up Peukerts exponent for more details). Discharging faster than that, reduces the amp-hour capacity of the battery. At a current drain of 700 ma (10 hour rate) that you might have with transponder, radio, etc, Powersonic shows a capacity of 90% of the 20 hour rate. That's not a show-stopper, but worth taking into account. Lead acid batteries have less capacity when cold. One guide suggests that for every 10 degrees centigrade below room temperature, you should add 10% to the battery capacity needed. High altitude flight tends to get up into cold places. This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() "Eric Greenwell" wrote This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. Put a insulated cover around the battery, and the heat of discharge will keep it warm and the capacity up, unless it is seriously freakin' cold. -- Jim in NC |
Morgans wrote:
"Eric Greenwell" wrote This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. Put a insulated cover around the battery, and the heat of discharge will keep it warm and the capacity up, unless it is seriously freakin' cold. Insulating it will keep if from cooling off as quickly, but I'm skeptical about the amount of self-heating. Do you know how much it is, or where I can find a reference to it that applies to the batteries we us? Insulating my battery is difficult due to it's location, so I'd like to know it's worth the effort before attempting it. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
In article "Morgans" writes:
"Eric Greenwell" wrote This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. Put a insulated cover around the battery, and the heat of discharge will keep it warm and the capacity up, unless it is seriously freakin' cold. With a resistance of a few milliohms, a 1 amp discharge will only give a few milliwatts of heat. I really doubt the battery will keep itself warm. (After all warming the battery would consume energy from its stored capacity.) Alan |
"Alan" wrote in message
... In article "Morgans" writes: "Eric Greenwell" wrote This corresponds with the Powersonic chart, so at -10C (15F), you have a 30% loss of capacity. For winter flying, and spring or fall flying in places where you can climb to, say, 10,000' agl, it's an important factor. Especially so, when you know your encoder will likely be using it's heater, adding 50-150 milliamps to your current drain. Put a insulated cover around the battery, and the heat of discharge will keep it warm and the capacity up, unless it is seriously freakin' cold. With a resistance of a few milliohms, a 1 amp discharge will only give a few milliwatts of heat. I really doubt the battery will keep itself warm. (After all warming the battery would consume energy from its stored capacity.) Alan The greater problem might be a need to remove the problem during charging, when a lot more heat is likely to be generated. Peter |
On Sun, 04 May 2008 09:37:13 -0400, Peter Dohm wrote:
The greater problem might be a need to remove the problem during charging, when a lot more heat is likely to be generated. I use an automatic charger with bulk charge and float modes. This unit is designed for 12v batteries in the 6-15Ah capacity range. It outputs 14.7v at 1.5 amps in bulk mode. My batteries never even get warm to the touch when on charge. I'd suggest that if your batteries get hot on charge then there are only three possibilities: - you're using a fixed-rate charger with far too high a rate for the battery. - you're overcharging with a fixed-rate changer. - your automatic charger is faulty. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
![]() (After all warming the battery would consume energy from its stored capacity.) Sure, but a warm battery can deliver more power than a really cold battery. Tony V. |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
Cessna forced down by the Feds | C J Campbell | Piloting | 51 | February 8th 05 01:29 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 06:10 PM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
