limit of trim = limit of travel?
Old May 6th 08, 04:59 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default limit of trim = limit of travel?
WingFlaps wrote in
On May 6, 3:36*pm, Bertie the Bunyip wrote:
WingFlaps wrote
innews:4c947801-0112-4fa1-92e7-09f00
On May 6, 2:19*am, Bertie the Bunyip
On May 5, 6:06*am, WingFlaps wrote:
On May 5, 8:48*am, Bertie the Bunyip wrote:
WingFlaps wrote
innews:49efc4b4-8ede-40cd-9ad3-5
On May 5, 3:19*am, Bertie the Bunyip wrote:
Stealth Pilot wrote
innews:u8kr141dp0o1e
On Fri, 2 May 2008 12:32:28 -0700 (PDT), WingFlaps
On May 3, 12:40*am, Stealth Pilot
.au
On Wed, 30 Apr 2008 00:12:54 +0000 (UTC), Bertie the
Bunyip wrote:
WingFlaps wrote in
news:ad8fc9c9-57cb-4733-9e97-
On Apr 30, 9:37*am,
On Apr 29, 2:24 pm, WingFlaps
I don't follow this. The trim surface operates in
the opposite direction to the trimmed surface and
takes area away from it.
Explain
please?
What area stuff?
Cheers
that area stuff. ...which shows a total lack of
aerodynamic understanding.
Still don't know what you're talking about! Most of that
thread has
spooled off my main server now..
He's trolling.
Cheers
He's not, he's right. Deflecting a tab in the oppostie
direction doesn
't
remove area.
It reduces effective area.
No, it doesnīt. The area is stil there. The tab isnīt "hiding"
because
itīs going the other way, itīs just doing something different. it
m
ay
be reducing the effectiveness of the surface, but that isnīt the
same
thing as reducing the area.
Nope. Effectiveness is proportional to area -from the old lift
equation.
Sure, but the area hasn't changed.
OK, then if the AOA of the stabilator is constant, and the elevator
angle is constant, why does the lift reduce when the trim tab is
deflected in the opposite direction? It's as I said, the effect is as
if the _effective_ area is reduced. You could say that CL is altered
but then it gets more messy as you have to consider different CL's and
areas for each section of the stabilator. It's much simpler to just
subtract the area taken by the trim from the calculation and that will
give a very good first order approximation for longitudinal stability
calculations.
It's not correct to do it that way, and if you're actuasly talking about
calculations, then you're going to be way off the mark.
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
speed limit in class B Andrey Serbinenko Piloting 0 July 23rd 06 04:05 AM
Pegasus life limit Mark628CA Soaring 2 March 30th 06 10:37 PM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
Pushing the limit Dan Shackelford Military Aviation 20 September 14th 03 10:27 PM
Copyright Đ2004-2025 AviationBanter.
