Nav Light Graphic
Old May 6th 08, 09:52 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Stuart & Kathryn Fields
Default Nav Light Graphic
"RST Engineering" wrote in message
m...
OK, I've been googling, wikiing, and reading FAR gobbledygook all morning
and I still don't have a clear picture of what the nav light requirements
(in both azimuth and elevation) are as regards brightness.
If anybody has a point to a clear post of the brightness requirements, I'd
sure be interested in seeing it. Sarangen's article on wingtip lights is
about the best I can find, but he duplicates the alpha graph and says
nothing about the theta graph.
"If you think you can, or think you can't, you're right."
--Henry Ford
Jim: I found the following to have quite a bit of information regarding nav
lite intensities. FAR Part 25 sub part F and Sec. 25.1391 and beyond.
I hope this is of some use
Stuart & Kathryn Fields, Publishers
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
(760) 608-1299 technical cell
www.experimentalhelo.com
www.vksupportservice.com
Old May 6th 08, 10:09 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
A couple of things, Stu. One, Part 25 has to do with transport category
aircraft. Two, the corresponding sections in Part 23 (light aircraft) are
what I was referring to when I mentioned "gobbledygook" in my original post.
My hit is that they gave this section to a newly graduated engineer with a
specialty in optics and (s)he wanted to show the boss how much a good
engineer can obfuscate matters.
A simple set of graphs would make things SO much easier to interpret.
--Henry Ford
"Stuart & Kathryn Fields" wrote in message
nav lite intensities. FAR Part 25 sub part F and Sec. 25.1391 and beyond.
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
Old May 7th 08, 05:35 AM posted to rec.aviation.homebuilt,rec.aviation.owning
On May 6, 3:09*pm, "RST Engineering" wrote:
A couple of things, Stu. *One, Part 25 has to do with transport category
aircraft. *Two, the corresponding sections in Part 23 (light aircraft) are
Old May 7th 08, 04:44 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Because IDK WTF or WTF the SAE is or WTF the AS docs are.
Why do you persist in using contractions that are not commonly understood?
--Henry Ford
Why don't you just buy the AS documents from the SAE. They state the
requirements pretty clearly...
Old May 7th 08, 06:59 PM posted to rec.aviation.homebuilt,rec.aviation.owning
* * * * --Henry Ford
Why don't you just buy the AS documents from the SAE. *They state the
SAE is the Society for Automotive Engineers. I thought all engineers
knew that one, it is on every oil can out there.
Know what a TSO is? Read the TSO's and you find the AS documents.
Old May 8th 08, 12:26 AM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Because he's got a whole library shelf full of TSOs that he's been designing
to for about forty years now. Most TSOs are comprehensible; the FAR is not.
Regarding the SAE documents, sixty bucks for a couple of simple line graphs
seems a little on the high side, and since you can't get the documents until
you pay the fee, you have no idea if those graphs are even included.
He doesn't know the difference between an acronym and a contraction so how
would he figure out TSO?????
Nav Light Graphic RST Engineering Owning 15 May 20th 08 11:04 AM
FSX best graphic card Syucomm Simulators 5 December 4th 06 10:37 PM
Two monitors and graphic card set up Stephen Ford Simulators 2 January 18th 05 07:00 PM
great graphic card Shaun Products 0 November 14th 04 12:43 AM
graphic card for sale Shaun Aviation Marketplace 0 November 14th 04 12:42 AM
